Old Mar 07, 2011, 01:18 PM
IdahoAir is offline
Find More Posts by IdahoAir
IdahoAir's Avatar
South Central Idaho
Joined Mar 2009
That's great to hear! I haven't been active on Sketchucation for the last 4 or 5 months so I wouldn't be surprised to hear of the problematic ones updated. The issue, IIRC, had to do mostly with a change in the Ruby version that caused incompatibilities in some scripts.
As for specific, well, if I'm still using the older ones, I guess I'd still have issues. I need to update my plugins a bit it seems.
So, for anyone who wishes to take my advice on SU7, please do so with a grain of salt ... lol
Cheers.
IdahoAir is offline Find More Posts by IdahoAir
Old Mar 07, 2011, 01:43 PM
larryross is offline
Find More Posts by larryross
Registered FFF Addict
larryross's Avatar
Grand Junction, Colorado
Joined Dec 2007
Has anyone had this problem? I try to use SU7 and it just tells me to get SU8 and won't load the file in to SU7.
larryross is offline Find More Posts by larryross
Old Mar 07, 2011, 03:05 PM
Wilfor is online now
Find More Posts by Wilfor
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
Larry if its been opened in 8 it wont open in 7 not backwards compatible
I still have 7 as it will import more file types
Wilfor is online now Find More Posts by Wilfor
Old Mar 07, 2011, 07:22 PM
springer is online now
Find More Posts by springer
treefinder
springer's Avatar
SE MI
if you are extruding a complex surface, you may need to press the control key to create a new starting face. That leaves the original face in place and extrudes with a new face. I'm using V7, and just checked, looks like most of the time it creates a new face automatically, but I know I've had to use the control key to get a face on both ends.
springer is online now Find More Posts by springer
Old Mar 07, 2011, 11:56 PM
larryross's Avatar
Joined Dec 2007
Ya I figured out that it was created in SU 8. So downloaded 8 and it worked great. Thanks Wilfor
Regards
Larry
Old Mar 08, 2011, 12:37 AM
mxspode is online now
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Just had the same problem. I have been running SU7 quit happily until a friend sent me a file to work on that he had created in SU8. Finally had to break down and download it and install. I will probably primarily use 7 myself still for my own work.
Rob...
mxspode is online now Find More Posts by mxspode
Old Mar 08, 2011, 01:09 AM
7up is offline
7up
Find More Posts by 7up
7up
,ɯǝ ʇoƃ ɐʎ ɟı ,ɯǝ ǝʞoɯs
7up's Avatar
USA, KY, West Liberty
Joined Jun 2001
Tip
For any file created in SU8 that you'd like converted to SU7, simply open the file in SU8 goto File>Save As and at the bottom of the dialog box click the "Save as type" drop down box and select the version of SU to save the file as.
-Buk
7up is offline Find More Posts by 7up
Old Mar 08, 2011, 10:04 PM
mxspode's Avatar
True, but I still had to download and install SU8. No big, I am working with it now and so far so good. I just need to get all of my plug-ins installed.
Rob...
Old Mar 15, 2011, 12:32 PM
fuelsguy is online now
Find More Posts by fuelsguy
fuelsguy's Avatar
Seattle
Joined Dec 2001
I just started with SketchUp, lots to learn but this thread does help.
Ivor
fuelsguy is online now Find More Posts by fuelsguy
Old Mar 17, 2011, 03:28 PM
msev is offline
Find More Posts by msev
Joined Sep 2010
Does anyone know how to stitch back an already tiled plan in pdf?
msev is offline Find More Posts by msev
Old Mar 17, 2011, 11:58 PM
mxspode's Avatar
You can do it in Photoshop if you have it. It is a pain though but can be done.
Rob...
Old Mar 21, 2011, 07:05 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
Here is a super program that will convert pdf to an image...its free and works a treat...download here with info or its also in the zip
http://www.filetransit.com/download.php?id=116543
davereap is offline Find More Posts by davereap
Old Mar 25, 2011, 06:36 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
here is a useful .rb which gives you a set of buttons to change the units on screen with a simple click...ie go from mm to inches ...
Old Mar 25, 2011, 11:45 AM
segraves is offline
Find More Posts by segraves
Joined Jan 2007
Yes. There is a Java-iText program, UPDF_GUI, written by Bill Segraves, that can untile a tiled PDF It is packaged as an executable JAR file, similar to the packaging of ScaleAndTile3.
You should also be able to use a graphics-editing program that can import PDFs, importing the pages, one-at-a-time, and pasting them into your workspace.
Cheers,
Bill Segraves
segraves is offline Find More Posts by segraves
Old Mar 25, 2011, 11:58 AM
Quick61 is offline
Find More Posts by Quick61
Just call me crash for short
Quick61's Avatar
United States, OH, The Plains
Joined Jan 2011
Thank you davereap! I have been looking for that for a while now. Just what I needed. Now if I can only fix the glue tabs errors.....
Quick61 is offline Find More Posts by Quick61
Any advantage using AE cells for receiver batteries? dvint Electric Plane Talk 8 Jan 12, 2003 10:34 AM
Using Lithium Batteries for Receiver Pack stevek Radios 7 Jun 24, 2002 08:52 PM
Using Orbit charger for foam cutting tom_yellowblue Power Systems 6 May 02, 2002 02:49 PM
Anyone using Grish props for Slowflyers ? Feodosia Flyer Parkflyers 3 Jun 23, 2001 09:48 PM
A great day for modeling t-turley Parkflyers 3 Apr 29, 2001 08:48 PM
