Old Mar 03, 2009, 11:10 PM
Lee is offline
Lee
Find More Posts by Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
????Question????
I'm trying to draw plans for the Peregrine but am having trouble with arcs. Feather tips are not perfect circles and I haven't been able to figure out how to draw elipses to get it to look right except for freehand and I'm horrible at freehand.
Also ..... Is there a cut function so I can cut a drawing into parts rather than drawing each part individually? for example the Snowball. I had to draw the tips and body separately. Is there a way I could have just cut the circle?
Lee
Lee is offline Find More Posts by Lee
Old Mar 04, 2009, 04:07 AM
davereap is offline
Find More Posts by davereap
davereap's Avatar
Ashford. Kent. England
Joined Feb 2005
try the bomb all plugin(post104) followed by zorro (post35)to cut... ive not tried it but it might work...note zorro will only cut when in the iso(3d) view not parallel, so it can be a bit tricky to line up the cut accurately... info in earlier post
Arcs and curves... find the bezier curves plugin this will let you do curves that are not exact arcs.. post32 zip
do the mirror as well, then you only draw half the model and mirror it to get the whole thing
saving pics from sketchup...I am using vista so in the side bar ive a screen snapper tool that lets me save any section of the screeen as a bmp file.
This is then put in photoshop and saved for web.. then uploaded to RCG in the normal way
davereap is offline Find More Posts by davereap
Old Mar 08, 2009, 07:43 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
I thought you might be interested in the process of getting a RC kite plan from a picture.
heres the thread for nightkites
http://www.rcgroups.com/forums/showthread.php?t=987191
Using a pic, I put it in photoshop, added a grid, selected the kites area and cropped, then used the transform-perspective option to square up the background tiles to the grid ...pic1 (saved as a bmp)
Now using sketchup I imported the pic as an image. It goes in on the x/y plane and you just drag it to a viewable size.
Using the tapemeasure tool ,I then measured the edge of one tile and assuming they were 12", Ityped the value in and then resized the model to that size.
Next I wanted to check the tiles actually measured square.. so I used the dimensions tool to add sizes across and down the tiles ....pic2..
As can be seen from the dimensions the sizes are out slightly..
Now I select the picture and use the scale tool, pulling the bottom centre down untill the sizes across and down the square are the same ....pic3..
The image in sketchup is now ready to be drawn over
Old Mar 08, 2009, 07:44 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Next in sketchup... just use the drawing tools and draw over one half only of the design.
Miiror the half drawn
Remove unwanted picture and add kite dimensions.
lastly check the specs for the kite and adjust the size to suit using the tape measure tool on the span....
Not a bad job, when resized it was only a fraction of inches out
Old Mar 08, 2009, 09:50 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
I appreciate the effort you are putting into this thread Dave.
Would you please make a list of all the plug ins you recommend?
Lee
Old Mar 08, 2009, 12:33 PM
kram242 is offline
Find More Posts by kram242
-+- PhlatBoyz -+-
kram242's Avatar
New Jersey
Joined Sep 2003
Build a Better Mouse Trap with SketchUp :)
You guys have to see some of the cool mouse trap designs that these guys are coming up with
The contest entry ended today but we are going live for the builds and setup of the traps you may want to tune in at 2:00 pm est Today!
http://www.phlatforum.com/viewtopic....&t=559&start=0
Also here is good link to some plugins for sketchup I thought you might want to check out. There is one there with a visual index of many cool plugins.
http://www.phlatforum.com/viewforum.php?f=11&start=0
Mark
kram242 is offline Find More Posts by kram242
Old Mar 08, 2009, 01:21 PM
mxspode is offline
Find More Posts by mxspode
If it flies, I will crash it
mxspode's Avatar
USA, CO, Westminster
Pretty cool contest Mark. You got some pretty intricate designs too. I have been wondering about designing some Rube Goldberg devices myself to pass the time. This was a pretty good idea.
You do of coarse realize the some what obvious irony of trapping a mouse in a box made of foam.
Rob...
mxspode is offline Find More Posts by mxspode
Old Mar 08, 2009, 07:35 PM
Doncrashum is offline
Find More Posts by Doncrashum
Nyuk nyuk nyuk
Doncrashum's Avatar
Hi. I need help. I imported a freeflight plan into Google Sketchup. I resized it. Then when I went to print preview I got this. I clicked a few things like I knew what I was doing. Apparently not! The first time I did it it worked. Help!!!!!!
Doncrashum is offline Find More Posts by Doncrashum
Old Mar 09, 2009, 07:06 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Autocentrepoint ..**
.. jf unfold tool ...****
Bezier curves...*****
Joint Push Pull . ***
Tools on Surface ..**
shapes ...**
Slicer ...***
.. zorro.. *****
Mirror ..*****
.Construction line tool.. *****
Bomb All.. *****
star rated, only my opinion as to what I use the most.. some are in zip files earlier in the thread also check Krams post and link... there are loads of usefull scripts, it just depends on what you are doing with sketchup...
Old Mar 09, 2009, 07:10 AM
davereap is offline
davereap's Avatar
Joined Feb 2005
Doncrashum
printing..go to here
http://www.rcgroups.com/forums/showt...g#post11088238
Old Mar 09, 2009, 08:05 AM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
More current pictures. I like to color.
This is after about 2 weeks of playing with Sketchup 7
Old Mar 09, 2009, 08:34 AM
tdearth is offline
Find More Posts by tdearth
USA, IN, Nineveh
Joined Apr 2002
Hi Lee,
You are doing really good after only a couple weeks working with sketchup.
One question, are these two versions of the Capricorn?
The 3D drawing show the wing as both anhedral and dihedral,
while the front vies shows only dihedral.
Never mind, I just realized that one is the Capricorn and the other is the snowball.
Tim
tdearth is offline Find More Posts by tdearth
Old Mar 09, 2009, 12:17 PM
Lee is offline
Lee
Lee
PERFECT LANDING !!!
Lee's Avatar
USA, UT, Orem
Joined Jul 2004
Originally Posted by tdearth
Hi Lee,
Tim
Tim
I've built it with a flat center with the same angle on the tips as the Snowball before and it flies like the Snowball except even more stable.
Lee
Old Mar 09, 2009, 12:43 PM
tdearth is offline
USA, IN, Nineveh
Joined Apr 2002
Thanks Lee,
Do you need an additional sponson on the back if you fly either of these off of water?
Tim
Old Mar 09, 2009, 12:45 PM
tdearth is offline
USA, IN, Nineveh
Joined Apr 2002
Sorry, I realize that I got way off the thread with these questions.
I should find the appropriate threads.
Tim
Any advantage using AE cells for receiver batteries? dvint Electric Plane Talk 8 Jan 12, 2003 10:34 AM
Using Lithium Batteries for Receiver Pack stevek Radios 7 Jun 24, 2002 08:52 PM
Using Orbit charger for foam cutting tom_yellowblue Power Systems 6 May 02, 2002 02:49 PM
Anyone using Grish props for Slowflyers ? Feodosia Flyer Parkflyers 3 Jun 23, 2001 09:48 PM
A great day for modeling t-turley Parkflyers 3 Apr 29, 2001 08:48 PM
