Old Sep 06, 2008, 10:52 AM
mikeyflight3 is offline
Find More Posts by mikeyflight3
Duxbury, MA
Joined Sep 2007
Build Log
1st glider build - Sig Riser 100 electric conversion
Have been flying fuel and electric planes for about a year, 3-4 builds. Would like to try an electric glider - chose Sig Riser 100 - LHS had one. Plan on the following gear:
BP Hobbies 2826-6 Motor 730 kv - similar to eflite power 25
CC Phoenix 45
Flight Power 3s 2500 20C
Aeronaut 14x7 folding prop
Futaba 3004's for rudder and elevator
HS 55 for spoilers - one each wing
Planned mods:
New ply firewall on shortened nose for motor mount 3 deg downthrust
2-56 rods for control linkage rudder and elevator
Re-enforce fuse around wing TE
Sig AeroKote Lite covering - have extra
Any thoughts, suggestions, comments would be welcome.
mikeyflight3 is offline Find More Posts by mikeyflight3
Old Sep 06, 2008, 11:34 AM
robh is offline
Find More Posts by robh
Good, fast or cheap, pick two
robh's Avatar
Napa, California
Joined Jul 2006
Hi Mikey... go for it, sounds like it could be fun! Please keep us posted as the build progresses - pics are always good too.
Cheers,
Rob
robh is offline Find More Posts by robh
Old Sep 06, 2008, 12:19 PM
Duxbury, MA
Joined Sep 2007
Beginning fuse - cut off and angled nose for new firewall
Old Sep 06, 2008, 12:24 PM
Seahag721 is offline
Find More Posts by Seahag721
Seahag721's Avatar
Joined Sep 2007
Hey Mikey keep us posted on the details of your build. I've been debating on one of two planes the dynaflite butterfly or the sig 100. I'm leaning toward the Sig 100. At any rate here is http://www.rcgroups.com/forums/showthread.php?t=319505 another thread of a sig 100 conversion if you haven't seen it already. :-)
Seahag721 is offline Find More Posts by Seahag721
Old Sep 06, 2008, 12:30 PM
Bob Cook is offline
Find More Posts by Bob Cook
The Lone Blue Plaid Flyer
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hay Mike,
I just finished doing this mod a few weeks ago. I added 2 ea 6 inch wing tips to it. I call it the Riser 112. Everything your doing looks good, as far as the planned equipment goes. Here is a shot of my plane. There is a build thread on it here too. Your gonna love it. It flies great.
Bob in Seattle
Bob Cook is offline Find More Posts by Bob Cook
Old Sep 06, 2008, 03:03 PM
rabidrue1 is offline
Find More Posts by rabidrue1
Blueplaidcanard flyer
sdy. ny
Joined May 2007
Mine uses an E flight 15 motor,with a 12x7 apc. With the motor you have expect 85+ deg climbs.You might want to put 3 deg right and about 5 deg down on that for the thrust lines.The power system you have sounds awsome,but do make sure the wing is flat as per plan so no surprises come at you.On the fuse put a doubler of 1/8 light ply from the cut outs left from the kit on the inside of the fuse behind the former at the back of the wing,even if you use the bolt on wing the aft dowel holes are a weak point.While you are stiffening things up,add some corner gussets to the stab,don't worry the motor and battery will offset the weight.To cool the works use a plastic spoon scoop on the battery hatch and remove the covering from the last lightening hole in the fuse bottom.scottie
rabidrue1 is offline Find More Posts by rabidrue1
Old Sep 06, 2008, 03:44 PM
Duxbury, MA
Joined Sep 2007
Thanks for the advice.
Some more done - fuse glued, used 1/8 sq and thin ca to re-enforce side to bottom joints - not much weight but more strength and stiffening.
New firewall epoxied in.
Old Sep 07, 2008, 07:17 AM
sdy. ny
Joined May 2007
Try what I did,use the left over fuse side and bottom pieces and make a cowl for the motor.I used 1/4sq balsa in the corners so I could round it to a 1 3/4" spinner,the cowl on mine is held on with a 1" wide strip of the fuse covering so I can peel it off if needed.
Old Sep 07, 2008, 09:10 AM
Seahag721's Avatar
Joined Sep 2007
Hey Mikey, I noticed your motor mount seems flush with the firewall, are you using spacers to get your right & down thrust angles or did you cut the fuse to the proper angles. Any advice on which way is better? Your pics are great, so please keep'em coming
Old Sep 07, 2008, 10:21 AM
Duxbury, MA
Joined Sep 2007
Installed the firewall with 4 deg downthrust, no right but will use washers if necessary.
Old Sep 11, 2008, 09:40 PM
Duxbury, MA
Joined Sep 2007
Some more work:
made hatch for battery compartment and hatch/cowl combo for esc compartment. Rough shaping until spinner and prop arrive tomorrow.
Old Sep 11, 2008, 09:48 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Looks very nice. Keep on gluing !!!
Bob in Seattle
Old Sep 12, 2008, 04:43 AM
sdy. ny
Joined May 2007
Nice work on the hatch/cowl,should look real fine when it's shaved down to the spinner contour.
Old Sep 13, 2008, 12:12 PM
rud-elev is offline
Find More Posts by rud-elev
Joined Apr 2006
I gather your motor choice doesn't have a reversible prop shaft to allow direct bolting to the inside of a firewall?
R/E
rud-elev is offline Find More Posts by rud-elev
Old Sep 13, 2008, 05:29 PM
Bob Cook is offline
Bob Cook's Avatar
Seattle
Joined Jan 2003
Hi R/E,
I thought that too, but maybe he did that for CG ???
Bob in Seattle
Build Log Sig Riser 100" Build RC-JG Thermal 109 Feb 13, 2016 10:26 AM
Sig Riser 100 chris dodge Electric Sailplanes 11 Feb 04, 2015 04:56 AM
Build Log Sig Riser 100 build jwhitacre Sailplane Talk 18 Jul 27, 2008 05:40 PM
Sig Riser 100 electric conversion John Gallagher Electric Sailplanes 9 Apr 07, 2004 11:17 PM
Sig Riser 100 NIB soar-iowa Aircraft - Electric - Airplanes (FS/W) 0 Feb 12, 2002 09:09 AM
