Maryland
Joined Nov 2006
There is nothing wrong with using subtrim on the rudder channel to get the servo arm at 90 with most gyro's. The 401 for example....when it initializes, it will simply recalculate this as the new center position.
Also, you don't need to have any pitch with the slider at center. The gyro will counter any torque.... Watch the Finless vids, he informs you to mechancially center the slider in rate mode (which will give zero pitch at center), then fly in HH mode. Good luck, Skarn |
Bad experience using sub trim, I used to but it creates more problems than it's worth, it simply doesn't matter on the tail. It's actually best to have it off centre a little at mid stick/no trim. |
| Thread Tools | |
| Wanted Trex 450 tail rotor pitch issue | rotorblade400 | Aircraft - Electric - Helis (FS/W) | 1 | Sep 05, 2008 09:23 AM |
| Discussion Trex 450 tail pitch plate/slider | BOING | Mini Helis | 3 | Mar 25, 2007 02:44 PM |
| Idea TREX tail rotor pitch control mod! | iceman33 | Micro Helis | 6 | Mar 24, 2006 07:35 AM |
| Unequal tail rotor pitch on Eco8, problem?? | All__talk | Electric Heli Talk | 1 | Apr 30, 2002 03:17 PM |
