Old Sep 05, 2008, 05:17 AM
tuootal is offline
Find More Posts by tuootal
tuootal's Avatar
Earth-Europe-Finland-Espoo-Friisilš
Joined Sep 2007
Question
changing poles-number in existing files?
Hi,
I made an stupid mistake on entering wrong number of poles for brushless sensor. It lead to rather suprising rpm-figures in recorded flights.
Question : how I should alter the datafiles to get the recorded flights to display correct RPM? Ie. I want fix the existing files.
Is it possible to load datafile to excel and do some scaling/other math and then save it back?
Tuomas
tuootal is offline Find More Posts by tuootal
Old Sep 05, 2008, 02:21 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hi Tuomas,
Yes, you can loadthe files in excel as "space delimited" - the instructions are in the user manual if needed.
You could probably devise a simple formula to alter all the RPM fields automatically. I beleive you would simply need to multiply the #'s by the ratio of new poles to old poles.
When saving the file, make sure you save it as type CSV, and the application should then be able to still load it.
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
What's The Proper Procedure For Changing Spur Gear In Cobri Gearbox? Randy Due Power Systems 5 Nov 08, 2005 10:19 PM
How are LiPoly Cells Number in a Battery? everydayflyer Batteries and Chargers 3 May 14, 2005 10:41 AM
Changing defaults when saving photo files in XP??? Don Sims Life, The Universe, and Politics 6 May 01, 2004 04:51 PM
kT Number in Real Flight G2 Brill 1 Simulators 2 Jan 18, 2004 12:31 PM
Question Camber changing on 60 In. Racer sloppymoeley Slope 5 Feb 24, 2003 08:58 AM
