Old Sep 04, 2008, 10:41 AM
mrdj is offline
Find More Posts by mrdj
Dog is my co-pilot.
mrdj's Avatar
United States, GA, Brooks
Joined Mar 2005
Contest
Scratch-Build-Off-3 Firecrest
This will be an entry for Build-Off III.
I'm going to try for 1/10.
I'll have more details after the week-end.
DJM
mrdj is offline Find More Posts by mrdj
Old Sep 04, 2008, 10:49 AM
lake flyer is offline
Find More Posts by lake flyer
lake flyer's Avatar
Joined Nov 2005
Nice !!
lake flyer is offline Find More Posts by lake flyer
Old Sep 04, 2008, 11:03 AM
CapMike is offline
Find More Posts by CapMike
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
OOOOOOOO another gull wing. I like it
CapMike is offline Find More Posts by CapMike
Old Sep 04, 2008, 03:14 PM
jsfrench is offline
Find More Posts by jsfrench
jsfrench's Avatar
United States, WA, Olympia
Joined Nov 2002
Looks good, and unlike the Corsair, those short retracts don't have to swivel.
John
jsfrench is offline Find More Posts by jsfrench
Old Sep 05, 2008, 11:07 AM
mrdj is offline
Dog is my co-pilot.
mrdj's Avatar
Joined Mar 2005
John
The real trick is the gear doors. They slide down as the gear retracts. I can't ignore them completely, they're too big and would alter the look on approach.
If it was easy....
djm
Old Sep 05, 2008, 01:51 PM
sperry is offline
Find More Posts by sperry
St.Petersburg, FL
Joined Feb 2004
Never seen this airplane before. Looks like the unfortunate result of a Sea Fury and a Corsair being hangared together.....
Great choice, I'm looking forward to seeing it come together.
sp
sperry is offline Find More Posts by sperry
Old Sep 09, 2008, 01:34 PM
mrdj is offline
Dog is my co-pilot.
mrdj's Avatar
Joined Mar 2005
I have a plan. I'm starting to combine the sketches on scraps of paper with the 3-view. One concern though, is there a simple method for determining the CG on a swept/tapered wing. I seem to reacll something out there, but it escapes me at the moment.
Old Sep 09, 2008, 09:30 PM
jsfrench is offline
jsfrench's Avatar
Joined Nov 2002
CG Calculator
djm:
If you do a web search for "Center of Gravity calculator "you will get several hits. I've used this one a few times:
http://www.scaleaero.com/CG_Calculator.htm.
There a a lot of approximations here, but the calculations give a good starting point, 6.38 inches form the leading edge at the root.
Naturally you will want to try all this yourself.
John
Old Sep 09, 2008, 09:56 PM
mrdj is offline
Dog is my co-pilot.
mrdj's Avatar
Joined Mar 2005
Excellent! This is just what I was looking for. Thank you very much.
Old Sep 13, 2008, 05:27 PM
mrdj is offline
Dog is my co-pilot.
mrdj's Avatar
Joined Mar 2005
Image dump
Here's some more pictures.
I think of it as a Skyraider fuselage, Sea Fury engine, with Harvard wings on a Corsair spar.
Old Nov 29, 2008, 12:00 PM
mrdj is offline
Dog is my co-pilot.
mrdj's Avatar
Joined Mar 2005
I was going to build a chuck glider, but felt I could learn more with a basic model.
18" span, rubber power
Best of luck to all involved in BO III, and a thank you to scratchnhover for the great effort in putting this together.
DJM
Old Nov 29, 2008, 01:05 PM
scratchnhover is offline
Find More Posts by scratchnhover
Fly2Build.com
scratchnhover's Avatar
Redding,California
Joined Dec 2003
Terrific choice and hope the 5 blader makes it onto the model. Will be watching intently.
scratchnhover is offline Find More Posts by scratchnhover
Old Nov 29, 2008, 01:09 PM
W@CC0 is offline
Find More Posts by W@CC0
....When pigs can fly
W@CC0's Avatar
Duffel - Belgium
Joined Jan 2004
The small rubber powered model looks cute. You could make an RC indoor version of it
Best of luck!
Tom
W@CC0 is offline Find More Posts by W@CC0
Old Dec 02, 2008, 11:33 AM
mrdj is offline
Dog is my co-pilot.
mrdj's Avatar
Joined Mar 2005
Looking at the numbers, the diameter should be 15.2" I'll have to make some calls to find a suitable motor setup with enough torque. Any suggestions welcome.
I think seeing a big 5-blader at lower rpms would be a great effect, espcially on short final with everything hanging.
DJM
Old Dec 02, 2008, 01:18 PM
thomanie is offline
Find More Posts by thomanie
thomanie's Avatar
Trondheim, Norway
Joined Jun 2003
Nice, unusual subject, and a decent size mrdj
You could go with a Ramoser varioprop 5 blade hub (12C hub), and Ramoser scale 15.2" blades. Not exactly cheap, though. Sorry, haven't looked at suitable motors.
If you decide to scale it down somewhat, Manzanos 5 blade hub for the FSK blades would be a good choice. Sparky used the E-flight 480 910kv motor on the 6 blade version of his YO-3A, so one less blade and slightly higher kv should work equally well.
T
thomanie is offline Find More Posts by thomanie
