Old Nov 15, 2012, 07:29 PM
nick_75au is offline
Find More Posts by nick_75au
NeverAgainVolunteerYourse lf
nick_75au's Avatar
Australia, QLD, Regents Park
Joined Mar 2007
Hi Bruce, the tube has a brass bush at each end and the centre is filled with marine grease, the top of the tube is slightly higher than the waterline as well which helps, Its built the same as a prop shaft
cheers
Nick
nick_75au is offline Find More Posts by nick_75au
Old Nov 16, 2012, 01:19 AM
HeavyCruser9 is offline
Find More Posts by HeavyCruser9
HeavyCruser9's Avatar
Adelaide,Australia
Joined Dec 2009
Thanks mate!!
I am thinking about having working stabs in my 1/72 Type23 HMS Iron Duke.....when I find the bench space to build her!
Cheers Bruce
PS George Sitek is the go to man for custom stuff!! How did ya prop come off ?? I Loctite mine on after losing one off CGN9 on early trials!!
HeavyCruser9 is offline Find More Posts by HeavyCruser9
Old Nov 16, 2012, 02:53 AM
nick_75au's Avatar
Joined Mar 2007
I think I hit a hazard of the lake being in a lower socio-economic area
shopping trolley or bike or safe, all of these have been dragged out of the lake in the past It could have also been construction debris from the building of the boat ramp, it was neat that area
Prop was lock tighted on and had a really long thread as well, should have learned from Peters experience and put a grubscrew or pin
Cheers
Nick
Old Nov 17, 2012, 12:34 AM
Adelaide,Australia
Joined Dec 2009
That's a big chunk of metal to lose mate! If it was ferrous(iron based/alloyed) you could have searched with a metal detector.... Oh well someone may find it one day (probably by stepping on it!)
Cheers,
Bruce
Old Mar 06, 2013, 05:05 AM
nick_75au's Avatar
Joined Mar 2007
SPS-49 reflector
Long time no update and no real progress, I've been working for the last few days on this
Next warship will have a phased array
Cheers
Nick
Old Mar 06, 2013, 05:08 AM
Deckie is offline
Find More Posts by Deckie
Deckie's Avatar
Australia, WA, Garden Island
Joined Nov 2010
Cheers
Nick
THAT is real Art
Deckie is offline Find More Posts by Deckie
Old Mar 06, 2013, 05:14 AM
nick_75au's Avatar
Joined Mar 2007
Old Mar 27, 2013, 03:23 AM
Deckie is offline
Deckie's Avatar
Joined Nov 2010
Had a debate with someone at work today re: brushed vs brushless.
Nick, I know you advocate brushless motors to some extent with scale models, however you've used a Brushed scooter motor for your FFG? what were your reasons behind that, purely to fulfill my curiosity
Old Mar 27, 2013, 06:37 AM
nick_75au's Avatar
Joined Mar 2007
Firstly, I already had the motor and doing the calculations on it it turned out to be a near perfect fit for the prop, I do under-volt it by running on 4 Cell Li-po. It has a very low 100 Kv and sufficient torque.
A suitable brush-less would either need to be as low KV, and expensive or a much smaller one geared down,similar 400 Kv motor with a 4:1 reduction has enough power, like this,
http://www.hobbyking.com/hobbyking/s...arehouse_.html
Cheers
Nick
Old Mar 27, 2013, 07:08 AM
Deckie is offline
Deckie's Avatar
Joined Nov 2010
Cheers
Nick
Alright, two more questions then based on the above:
(1) Would the scooter motor and propeller combo above fair well with just 12 volts?
(2)
This motor on 12 volts could achieve a very similar outcome?
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
Old Mar 27, 2013, 07:14 AM
nick_75au's Avatar
Joined Mar 2007
(1) Yes though a bit slower
(2) Yes
Of course this would depend on having a similar size prop.
cheers
Nick
Old Jan 15, 2014, 01:45 AM
nick_75au's Avatar
Joined Mar 2007
What resin to cast prop blade
I built a Silicone mould for my prop blades, I no longer have access to the foundry and I NEED a prop,
Oh and I'm a tightarse so want to do it myself, What should I use to cast the blades.
Cheers
Nick
Old Jan 15, 2014, 08:23 AM
liljimmy is offline
Find More Posts by liljimmy
20M northeast of Hell Mi
liljimmy's Avatar
United States, MI, Howell
Joined Jul 2012
Could you use the molds to cast lost wax. Check your local college they may have an art class that will do small bronze casting
liljimmy is offline Find More Posts by liljimmy
Old Apr 04, 2014, 04:07 AM
nick_75au's Avatar
Joined Mar 2007
I've just brought some Smooth cast 385 to have a try with, the plan is a brass hub and secure the resin blades to it with small bolts, in planning for a future CCP
http://www.smooth-on.com/gallery.php?galleryid=183
Old Jun 04, 2014, 05:47 AM
nick_75au's Avatar
Joined Mar 2007
Im in between work ATM so decided to make a bit of progress with the boat, And installing cabinets and benchtop into our laundry
Discussion 1/48 missile corvette ready for maiden voyage leaky bill Scale Boats 3 Aug 29, 2008 03:48 PM
1/48 scale A-10 aerogel Scratchbuilt Indoor and Micro Models 15 Nov 04, 2002 06:11 PM
