This thread is privately moderated by ATTF, who may elect to delete unwanted replies.
Old Mar 13, 2011, 06:08 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Originally Posted by bildo baggins View Post
I used to cut my own from surgical tubing. O-rings work as well
+1 on this suggestion, cheap and easy and 3ft of surgical tubing will make a bunch of Orings.
Diggs
Diggs is offline Find More Posts by Diggs
Old Mar 13, 2011, 06:09 PM
anti-gravity is offline
Find More Posts by anti-gravity
In the 20' glider range
anti-gravity's Avatar
Boise, Idaho
Joined Jul 2009
Where can I get some S-tubing at? D & B Supply?
anti-gravity is offline Find More Posts by anti-gravity
Old Mar 13, 2011, 06:14 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
Hardware store, plumbing section...
Diggs
Old Mar 13, 2011, 06:21 PM
ASB32 is offline
Find More Posts by ASB32
hmph!
ASB32's Avatar
United States, UT, Logan
Joined Dec 2008
Diggs, I don't know if this helps but I have shimmed prop adapters with electrical tape before. Basically, I wrapped the prop shaft (yes it was too small) tightly and carefully with the tape until it was shimmed out enough to center the back plate of the spinner. I wrapped it so the edge of the tape was perfectly aligned with the base of the shaft. I then held the backplate on and used it as a guide trim off the excess tape, not covered by the backplate. Then I just mounted everything up normally. I guess it's not ideal but it worked great and everything seemed balanced enough. Let the small shaft jokes continue...
I have the same Scorp and it just went into a Vyper today. It came out of an 8' Telemaster. I really like it and am thinking about buying another for my Slick.
BTW- For those of you out there that pray... Keep the Japanese in mind. As if it wasn't bad enough, things are sounding pretty dicey today.
ASB32 is offline Find More Posts by ASB32
Old Mar 13, 2011, 06:42 PM
karl k is offline
Find More Posts by karl k
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Fishing shops (for holding lead pencil weights)
Also look for "Theraband" tubing. It's used for resistance training. Comes in all sorts of thicknesses.
If you know anyone with a small glider like a Fling, get a foot of their high-start.
karl k is offline Find More Posts by karl k
Vintauri is online now
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
Your local drug dealer should be able to keep you well stocked.
Vintauri is online now Find More Posts by Vintauri
Boise, Idaho
Joined Jul 2009
Old Mar 13, 2011, 06:45 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Is anyone else having issues with RC Groups loading properly running Chrome on a Mac?
Old Mar 13, 2011, 06:47 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
Really?!?!?!
Old Mar 13, 2011, 06:49 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Thickness is key
bildo baggins is offline Find More Posts by bildo baggins
ASB32 is offline
hmph!
ASB32's Avatar
Joined Dec 2008
My Chrome started acting up on RCG today, but on Win 7/64bit.
Old Mar 13, 2011, 06:52 PM
RadioActive is offline
Find More Posts by RadioActive
Master of the Touch and Tumble
RadioActive's Avatar
On the green side of the Grass
Joined Jan 2005
Lowe's sells it by the foot. You want 3/8" Cut them about 1/8" to start, if you still have slippage increase the width.
RadioActive is offline Find More Posts by RadioActive
Old Mar 13, 2011, 07:01 PM
karl k is offline
Yes, "that" Karl...
karl k's Avatar
Canada, BC, Burnaby
Joined Mar 2007
The wider it is, the slippier it has to be.
HA. Beat Bildo to it!
Old Mar 13, 2011, 07:05 PM
FLG_Ashley is offline
Find More Posts by FLG_Ashley
FLG_Ashley's Avatar
United States, TN, Memphis
Joined Feb 2011
Wow I think Ashley has had quite the influence on Fred. He's sure throwing the zingers out there.
I have QUITE the influence, my good man.
TASTE THE RAINBOW
Originally Posted by IFLYOS View Post
Go to Wal-Mart, and in the cosmetics section, they have packs of multi-colored hair bands. They come with three different sizes to a pack, and I think its 100 of each size. Girls use them when they braid their hair. The material is a flat rubber band, but it feels like it might be made of silicon.
Ummm... why do you know so much about the cosmetic department in Wal-Mart AND the goings on of braided hairs..
Thanks! I might see if I can snag a few from my chick friends
The fact that you say "chick friends" means you don't have any.
xoxo
Can't wait for chat tonight. We can talk o-rings
Thickness is key
Frantically holds in laughter, but it's slipping.
FLG_Ashley is offline Find More Posts by FLG_Ashley
Old Mar 13, 2011, 07:08 PM
MN WATTS Master
Vintauri's Avatar
Joined Jul 2003
Nope working right now for me.
