This thread is privately moderated by ATTF, who may elect to delete unwanted replies.
Old Mar 13, 2011, 12:52 PM
RCPtero is offline
Find More Posts by RCPtero
KJ4YNM
RCPtero's Avatar
Manassas, VA
Joined Sep 2006
Originally Posted by fmidgett View Post
Diggsy Bear,
I wanna be sure I'm hearing this right. So basically your saying your shaft is too small?
Feel the burn.
RCPtero is offline Find More Posts by RCPtero
Old Mar 13, 2011, 01:02 PM
bildo baggins is offline
Find More Posts by bildo baggins
Chillin till SEFF
bildo baggins's Avatar
Warner Robins, GA
Joined Aug 2003
Originally Posted by _OZ_ View Post
The chat room should be interesting tonight
It just might
bildo baggins is offline Find More Posts by bildo baggins
Old Mar 13, 2011, 01:14 PM
Diggs is offline
Find More Posts by Diggs
Not your average DiggsyBear
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
The spinner is from extremeflight. about half way down the page. Bought two of these.
3.00 (76mm)- nylon cone with aluminum backplate
http://www.extremeflightrc.com/html/Accessories.html
I am guessing the hole in the backplate is 8mm and the shaft on the motor is 6mm per the specs below.
The motor is a Scorpion 4025-12
Specifications
Stator Diameter ............................ 40.0 mm (1.575 in)
Stator Thickness ........................... 25.0 mm (0.984 in)
No. of Stator Arms ................................................ 12
No. of Magnet Poles ............................................... 14
Motor Wind ........................................... 12 Turn Delta
Motor Wire ..................... 22-Strand 0.25mm (30 AWG)
Motor Kv ............................................ 440 RPM / Volt
No-Load Current (Io) @ 21 v ...................... 1.80 Amps
Motor Resistance (Rm) ............................. 0.022 Ohms
Max Continuous Current ............................... 85 Amps
Max Continuous Power .............................. 2000 Watts
Weight ...................................... 347 Grams (12.24 oz)
Outside Diameter .......................... 48.7 mm (1.917 in)
Shaft Diameter ............................... 6.0 mm (0.236 in)
Body Length .................................. 46.2 mm (1.819 in)
Overall Shaft Length ..................... 101.0 mm (3.976 in)
Any helpful advice other than viagra for my motor? Sure is a pretty day out, would love to have this resolved and potentially maiden this bird.
Diggs
Diggs is offline Find More Posts by Diggs
Old Mar 13, 2011, 01:19 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Really doesn't make sense. As best I can tell the EF motors are 6mm shafts. No hole dia listed on spinners at all
Old Mar 13, 2011, 01:27 PM
Manta1 is offline
Find More Posts by Manta1
OOPS
Manta1's Avatar
USA, GA, Cochran
Joined Jun 2008
put the spinner in the box and go fly.
Manta1 is offline Find More Posts by Manta1
Old Mar 13, 2011, 01:30 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Heard dat
Spinners are like wheel pants and decals. Added weight and curse on maiden
Old Mar 13, 2011, 01:32 PM
IFLYOS is online now
Find More Posts by IFLYOS
14s 180mah should be enough...
IFLYOS's Avatar
United States, NC, Pfafftown
Joined Feb 2001
Diggs, do you have any of the APC prop inserts? Might try and see if you can find one that fits the spinner backplate and the motor shaft...
IFLYOS is online now Find More Posts by IFLYOS
IFLYOS's Avatar
Joined Feb 2001
And I am trying to get something finished myself so I can get a flight in...I feel your pain!
Old Mar 13, 2011, 01:40 PM
Vintauri is online now
Find More Posts by Vintauri
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
I'm waiting for my wife to come home so I can go maiden some planes.... watching the 2 year old right now.
Vintauri is online now Find More Posts by Vintauri
Old Mar 13, 2011, 01:43 PM
Diggs is offline
Diggs's Avatar
Raleigh, NC
Joined Dec 2006
FOUND IT! Ok, I don't remember these coming out of the bag, but obviously they did. I stuck them in the big cup holding all my parts for the slick. But yes there is a nice aluminum spacer that works perfectly! Thanks for the input folks.
Diggs
Old Mar 13, 2011, 01:54 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
I kinda figured there'd be adaptes
Old Mar 13, 2011, 01:55 PM
Chillin till SEFF
Warner Robins, GA
Joined Aug 2003
Adapters
Old Mar 13, 2011, 01:56 PM
_OZ_ is offline
Find More Posts by _OZ_
It's gone...
_OZ_'s Avatar
Germany, NRW, Heinsberg
Joined Aug 2004
Never mind, you found the answer while I was typing.
_OZ_ is offline Find More Posts by _OZ_
Old Mar 13, 2011, 02:16 PM
Willmsy is offline
Find More Posts by Willmsy
I am the BBQ Ninja
Willmsy's Avatar
United States, MN, Woodbury
Joined Jan 2003
So are you going out to fly now Diggs?
Willmsy is offline Find More Posts by Willmsy
Old Mar 13, 2011, 02:27 PM
IFLYOS's Avatar
Joined Feb 2001
http://www.valleymorningstar.com/art...erobatics.html
I worked with Kyle and Amanda at a couple of airshows...they were top notch.
I hope they both pull thru ok.
http://www.youtube.com/watch?v=PdWZdid2IoU
