Go Back   RC Groups > Aircraft - Electric - Airplanes > Beginner Training Area (Aircraft-Electric)
Old Feb 09, 2003, 06:47 AM   #1
6 cells vs 7 cells flying time
I have a Coyote and Astra Spitfire and am about to upgrade my battery pack. From posts I have read I am keen on the HR-4/5AUP cells. Motocalc gives me an indication of the relative flying time difference between 6 and 7 cells, but I would like to know if, because I am using a BEC, 7 cells will additional flying time (i.e. 6 cells are have a lower voltage to start with and are therefore going to cut out sooner?). I guess what I am asking is does anyone know if Motocalc allows for a BEC and its cut-off voltage?
I would prefer to go 7 cells, but it is a squeeze in the Coyote.
DarrenT is offline Find More Posts by DarrenT   Reply With Quote
Old Feb 09, 2003, 08:44 AM   #2
That sickening crunch..
Andy W's Avatar
How do you fly?
If you're at full power most of the flight, 7 cells will give you higher current, which translates into LESS flight time, as you're at the same capacity. It will be faster, thought.
If you're in the habit of carefully controlling throttle, you can get more flight time, however, as you now need less throttle (hence less current) for the same power output to maintain flight.
If you're hitting LVC cutout well before the cells are discharged because of the low cell count now, however, 7 cells will make a big difference.
..a
Andy W is offline Find More Posts by Andy W   Reply With Quote
7 cells vs 8 cells snakeX2 Batteries and Chargers 7 Dec 13, 2004 06:20 PM
7 Cells VS. 8 Cells in a Corona? Tram Electric Heli Talk 10 Dec 20, 2003 11:09 PM
7 cells vs 8 cells in sp 400 pylon saint152 High Performance 2 Oct 25, 2002 11:32 PM
TIPSY - 6 cell vs 7 cell batts Ron D Foamies (Kits) 3 Jan 02, 2002 11:49 AM
8 cells vs 10 cells in my X250 Joe Elston Electric Plane Talk 4 Sep 19, 2001 02:48 PM
Bored? Want to fight?
Join the RCGroups clan!
