Old Sep 16, 2008, 01:04 PM
ricoalonso is offline
Find More Posts by ricoalonso
ricoalonso's Avatar
USA, KS, Derby
Joined Mar 2003
any info on actual performance will be greatly appreciated.
ricoalonso is offline Find More Posts by ricoalonso
Old Sep 16, 2008, 01:36 PM
bradpaul is offline
Find More Posts by bradpaul
USA, FL, Apopka
Joined Dec 2000
OK..... I'm trying to understand how this system works.
- The TX/RX communicate and select 5 free channels
- If it finds a "bad" channel it then picks another for the 5
- The TX/RX then monitor signal strength, error rate, to pick 2 of the 5 channels
- The system then uses those 2 channels
now is where I have questions.
- Does it stay on 1 channel and go to the second only if it needs to?, or does it constantly "hop" between the 2?
- When 1 of the 2 selected has noise does it then substitute 1 of the other original 5 selected?
The website is not very clear on this.
bradpaul is offline Find More Posts by bradpaul
Old Sep 16, 2008, 02:01 PM
slowswede is offline
Find More Posts by slowswede
slowswede's Avatar
Joined Jan 2007
Seems from the JETI site that it uses 2 out of 5 free channels and hops to one of the previosly selected free channels if needed (if one of the two channels it started on is deemed "bad"?). I wonder if it now has 2 channels to backup to or if it "prebooks" another one so that there still is 3 backups. Seems like to work a bit like an improved spektrum with hopping
The esotop article mentioned that it constantly hops between the 5 selected "good" channels (ca 1 ms/each), and if one channel is "bad" another one is selected for the next round of data. (bit like FASST, but not as many channels, and feedback).
This is interesting, looking forward to a good test/article of it.
slowswede is offline Find More Posts by slowswede
Old Sep 16, 2008, 03:35 PM
teamdavey is offline
Find More Posts by teamdavey
Sunnyvale, CA, USA
Joined Apr 2000
Just a guess, but don't hold your breath for FCC certs in Jeti's name. That module looks very much like it has a commercial RF subassembly on it which means they will ride on the vendor cert (like XPS). IF this is true, it would also explain the somewhat convoluted theory of op because they have to work within the constraints of the vendor's code and certs.
Can anyone identify the source?
How many ways can you spell Zigbee
teamdavey is offline Find More Posts by teamdavey
Old Sep 16, 2008, 03:45 PM
slowswede's Avatar
Joined Jan 2007
I see CE markings, if that means anything...
I guess we have to wait until the Prauge hobby fair in october to find out much more..
Old Sep 16, 2008, 04:20 PM
bradpaul is offline
USA, FL, Apopka
Joined Dec 2000
If it turns out that Jeti actually uses a Zigbee module and it performs as they describe, then Jim D better hire some Czech programmers.....
Old Sep 16, 2008, 04:29 PM
Sunnyvale, CA, USA
Joined Apr 2000
No comment.
Of course there are multiple vendors of Zigbee modules other than Maxstream (digi?). The specs on the Jeti site have certain clues in terms of the bandwidth, number of channels and theoretical maximum number of users. A quick trawl of the net pitched up a couple of candidates, but the FCC ident will tell for sure.
Old Sep 16, 2008, 04:32 PM
slowswede's Avatar
Joined Jan 2007
Hehe
I'd really like to go to 2.4G, and this sollution looks promising so far.. Have a HET mig 29 on the building board right now and dont want any problems with that one. Had enough glitch/EMC problems with my small EDF, it's only flyable on a jeti rex jbc reciever (35MHz) with filtering set to 100% (graupner synth reciever was a big no-no).
Old Sep 16, 2008, 04:53 PM
village_idiot is offline
Find More Posts by village_idiot
Inciting Riots
village_idiot's Avatar
Joined Dec 2006
Well hopefully the do use a pre-certified module, makes time to market that much quicker.
village_idiot is offline Find More Posts by village_idiot
Old Sep 16, 2008, 05:00 PM
Sunnyvale, CA, USA
Joined Apr 2000
This would be my guess: http://www.meshnetics.com/zigbee-modules/amp/
Old Sep 16, 2008, 06:19 PM
bradpaul is offline
USA, FL, Apopka
Joined Dec 2000
Looks like you are on to something.... and it does have according to the manufacturer a FCC id.
Brad
Old Sep 16, 2008, 06:39 PM
Sunnyvale, CA, USA
Joined Apr 2000
Right. It looks like jeti have their own protocal overlay on top. I haven't the time to dig into the specs for the actual device, but would be surprised if it actually "hops" since Zigbee is not intended to be frequency agile on the fly as far as I know. However, that particular implementation may support rapid channel change which they could take adantage of. I can't even guess where the 5 channel stuff comes from but someone with the time to dig through the specs may find the clue.
Old Sep 16, 2008, 09:10 PM
Inciting Riots
Joined Dec 2006
Whatever they use, I hope it lives up to the specs. And if it does then more power to them, looks like a nice system if it really works as claimed.
Old Sep 17, 2008, 12:53 AM
TheSteve is offline
Find More Posts by TheSteve
VE7FM
TheSteve's Avatar
Canada, BC, Langley
Joined Nov 2004
I hope it doesn't start communicating with/confusing XPS systems or vice versa...
TheSteve is offline Find More Posts by TheSteve
Old Sep 17, 2008, 01:04 AM
VasMan is offline
Find More Posts by VasMan
VasMan's Avatar
@Home
Joined Jan 2007
Good point. So even if it "hops", does this mean that if you have two Jeti modules up at the same time, neither is hopping?
VasMan is offline Find More Posts by VasMan
Discussion Polk Hobby 72Mhz or a 2.4ghz system skotman Radios 5 Apr 27, 2007 08:38 AM
Discussion XPS 2,4ghz system and FDR..? merengue Eagle Tree Systems 4 Apr 27, 2007 05:41 AM
Discussion 6EX-2.4GHz system Rox DIY Electronics 4 Apr 10, 2007 09:07 AM
Sold (pics added)ALULA 3 servo, complete setup with 2.4ghz system rcaddition Aircraft - Sailplanes (FS/W) 2 Apr 09, 2007 11:47 PM
Discussion Spektrum DX6 6-channel DSM 2.4Ghz System cpd1343 Dock Talk 38 Feb 23, 2007 05:53 PM
