Belgium
Joined Jul 2003
The first solution is extremely simple:
A module TU2 is delivered with a short cable, same connectors as MC24, same cable as the connection from MC24 main board to FM module You connect one cable from main board to Jeti TU and the second cable from TU to FM . A picture of the cable: http://www.rc-easy.com/shop/product_...s-TU2--15.html If you take out the FM module, and look at the back side there are 5 female connectors - antenna ( this is the connector near the corner) -ground -+ from the battery + 6V (needed for the FM module) PPM signal There is some info on http://users.belgacom.net/TX2TX/tx2t...h/tx2txgb5.htm I hope this can help |
Joined May 2010
We made couple interesting videos. Jeti is proving to be excellent system.
Zb/Esprit Model Jeti Profi Box with Mezon 130 ESC, Neu 700-3D Motor and Henseleit TDR Helicopter at 148.5mph (240km/h) http://player.vimeo.com/video/46233596
Joined May 2010
Jeti Telemetry Variometer w/DC-16 Radio
Another interesting video, Jeti DS-16 transmitter with Variometer.
Zb/Esprit Model
Belgium
Joined Jul 2003
look at
http://www.rcgroups.com/forums/showt...1114168&page=5 For each antenna, put the last 32mm outside the carbon fuselage : this is the most important. If needed, use a Jeti receiver with long antennas, allowing the two antennas to exit the fuselage after the wing (one antenna on each side) A nice protection: http://www.stratair.com/Shop/Produkt...aspx?ArtId=656 Robert |
Joined May 2010
Zb/Esprit Model |
| Thread Tools | |
| Discussion Polk Hobby 72Mhz or a 2.4ghz system | skotman | Radios | 5 | Apr 27, 2007 08:38 AM |
| Discussion XPS 2,4ghz system and FDR..? | merengue | Eagle Tree Systems | 4 | Apr 27, 2007 05:41 AM |
| Discussion 6EX-2.4GHz system | Rox | DIY Electronics | 4 | Apr 10, 2007 09:07 AM |
| Sold (pics added)ALULA 3 servo, complete setup with 2.4ghz system | rcaddition | Aircraft - Sailplanes (FS/W) | 2 | Apr 09, 2007 11:47 PM |
| Discussion Spektrum DX6 6-channel DSM 2.4Ghz System | cpd1343 | Dock Talk | 38 | Feb 23, 2007 05:53 PM |
