Old Jan 13, 2013, 11:39 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
it is not the power, the control in post stall with the 14x7 is so much better
3drcparts is offline Find More Posts by 3drcparts
Old Jan 14, 2013, 12:15 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
I understand fully what you are saying.and most say it's better with the 14x7
All I meant is that it's pretty good with the 13x6.5 aswell,I had no problems with anything post stall.got a 13x6 on now and still very affective
chop stiX is offline Find More Posts by chop stiX
Old Jan 14, 2013, 12:34 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Originally Posted by chop stiX View Post
I flew 13x6.5 VOX before the shaft went flying and was ample power aswell
But was that with the thrust 40 motor? It's meaningless to compare performance with different props is the motors are different also.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 14, 2013, 12:51 AM
chop stiX's Avatar
Joined May 2011
No Steve different motor.
Old Jan 14, 2013, 08:52 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
13x6.5 and 14x7 both work awesome!
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Jan 14, 2013, 08:58 AM
chop stiX's Avatar
Joined May 2011
Agreed
Old Jan 14, 2013, 10:35 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
trust 40 here and sure it flew fine on the 13" vox, but I won't buy another 13, that is all I'm saying
Old Jan 14, 2013, 04:35 PM
digitalfish is offline
Find More Posts by digitalfish
Tolland CT
Joined Jan 2009
I'm sure this has been posted to death but I kept going back further and further and not finding it. I went to install batteries in my new AMR to find they seem too tall (turnigy 2200 40c)
what are people running that fits nice (other than PA batteries)
digitalfish is offline Find More Posts by digitalfish
Old Jan 14, 2013, 04:39 PM
Aberdeen
Joined Mar 2006
Most if not all 3s 2200 batteries should fit. I'm running 30c Gens Ace and 35c Hyperion and they have adequate clearance. The problem tends to come (with any battery) if you put velcro on the battery and tray as the battery wont slide in.
The solution is not to use velcro (use foam rubber instead) or to modify/remove the cross brace.
Old Jan 14, 2013, 04:58 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Mount the ESC as far back as you can and plug in from the back side of the tray. You can get kitchen drawer non slip honey comb mat at any department store for less than $5 and it should last you for years. Then just velcro strap the battery down. I'm using GensAce 3s2200 60C's and they fit fine. In the video I used 30c's. I have Turnigy, Gens, EpBuddy, Nanos, and they all fit just fine.
AMR Battery (1 min 11 sec)
kuczy is offline Find More Posts by kuczy
Old Jan 14, 2013, 05:05 PM
Aberdeen
Joined Mar 2006
Yep, many ways to skin the cat.. I made the brace removable but the foam rubber is probably easier.
Kuczy,
Question.... With the ESC way back like that is it still easy to balance (if you use wood prop and carbon spinner and stock motor)? I'm pretty sure that I might struggle to get the CG right if I put the ESC back in the fuselage like you have it.
Old Jan 14, 2013, 09:14 PM
Tolland CT
Joined Jan 2009
yes I see now I'm just spoiled by having lots of room to work with, I did manage to get my battery in through the back like that. Thanks for the help
Old Jan 14, 2013, 10:17 PM
BearBow is offline
Find More Posts by BearBow
Freedom isn't Free
BearBow's Avatar
United States, VA, Woodbridge
Joined Oct 2012
T40X is The prop for the t-40 in ADX and AMR....1/2" longer dia than 14x7. Unknown pitch but it looks like abt 5.5 or 6. Try one then you'll have a passel of 14x7's left over like I do.
BearBow is offline Find More Posts by BearBow
Old Jan 14, 2013, 10:24 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Kuczy,
No problems balancing it. I'm using a VOX 14x7 and CF spinner as well. My ESC sits under the battery tray zip tied to the 2 carbon tubes and I'm using an ICE50. It flies just fine and the battery just slips in and out.
Old Jan 14, 2013, 10:43 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
sorry I have never heard of a t40x. link?
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 09:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 09:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 08:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 12:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Kit/Scratch Built 9 Dec 08, 2001 08:03 PM
