Old Jan 10, 2013, 12:52 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
No thanks JPF. the ally is like a crumple zone if you have a mishap.
demonGti is offline Find More Posts by demonGti
Old Jan 10, 2013, 01:34 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
If you want a weak link to reduce chance of bent shafts then use a wood prop.
Each to his own but i prefer my collets to stay on the shaft. In fact I'd rather have to replace a shaft now and again than keep loosing props, not that I've found shaft bending to be an issue when using the Hacker collet.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Jan 10, 2013, 01:49 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
Oh just to mention,it wasn't my collet that came loose.I pulled the whole shaft out my motor,so def not the PA collet that failed at all,I find no problem with the PA collets
chop stiX is offline Find More Posts by chop stiX
Old Jan 10, 2013, 02:17 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
I fly vox props on all my planes. ,,, and my PA collets DO stay on the shafts.
Indeed, each to his own.
Old Jan 10, 2013, 02:19 AM
demonGti is offline
demonGti's Avatar
Joined Dec 2006
Lets not confuse the issue any further and make it clear that the motor in your AMR is not a Thrust 40
Old Jan 10, 2013, 04:20 AM
chop stiX's Avatar
Joined May 2011
Thanx for mentioning
forgot to mention
Old Jan 10, 2013, 06:30 AM
Aberdeen
Joined Mar 2006
To be fair on the AMR personally I also never had any problem with generic ally type collet adapters, though from the posts here plenty have had issues. It's on higher power planes that I've found the ally ones just arent up to the job at all. Out of preference I'd go for the Hacker ones anyway as they are just better quality bits of kit IMHO.
Old Jan 10, 2013, 07:44 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
I hate collets. I hate front mounted motors. I have never had any kind of problem with X mount. I have lost collets on my T 40. I have bent a zillion shafts. PITA!!!!!
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Jan 10, 2013, 08:34 AM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am a huge fan of bolt-on...
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Jan 10, 2013, 12:34 PM
Aberdeen
Joined Mar 2006
Yeah, me too... but if it has to be a collet use the Hacker one
Old Jan 12, 2013, 10:54 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
I prefer bolt ons too, in addition to being more secure, they wick heat away better too.
That said, I've never lost a collet since learning how to install them properly. Remember. It's the balance of wet and dry friction that secures the connection.
- The motor shaft must be clean (ensure you remove the oil that's present on all new motor shafts)
- The collet 5mm ID must be clean too. There is always oil in these too from the machining operation or packaging.
- The tapered cone must be lightly lubed or it can't push the collet ID onto the motor shaft with enough pressure
- The nut and threads must be lightly lubed also or the prop and outer cone will slip before there is enough tension.
I've seen some collets that have developed ridges on the tapers from over tightening. They never work once they start to look like that and need to be re lapped / replaced.
subsonic is offline Find More Posts by subsonic
Old Jan 13, 2013, 09:49 AM
USA, GA, Atlanta
Joined Nov 2008
Thats just a PIA
with many others, you can simply slide on and bolt down, and forget about it.
Old Jan 13, 2013, 04:00 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
new collet works perfect today and I have to say I love the xoar 14x7 on this plane way more than the vox 13x7 that flew off, this is a fun plane, really really easy to fly and look good doing so.
3drcparts is offline Find More Posts by 3drcparts
Old Jan 13, 2013, 04:40 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
14x7 VOX or Xoar is the only way to go. Speed and thrust is perfect.
kuczy is offline Find More Posts by kuczy
Old Jan 13, 2013, 11:14 PM
chop stiX's Avatar
Joined May 2011
I flew 13x6.5 VOX before the shaft went flying and was ample power aswell
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 09:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 09:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 08:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 12:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Kit/Scratch Built 9 Dec 08, 2001 08:03 PM
