Old Dec 05, 2012, 11:25 PM
3drcparts is offline
Find More Posts by 3drcparts
inverted-i-fly
3drcparts's Avatar
United States, CA, Petaluma
Joined Mar 2011
got the motor out, missing c-clip in front, I doubt KE spins will rival my 51 slick, but we will see
3drcparts is offline Find More Posts by 3drcparts
Old Dec 05, 2012, 11:30 PM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
The c-clip is not meant to be on with this configuration.
51 Slickerooo has a tight KE spin,but I promise you,nothing compared to that of the AMR
chop stiX is offline Find More Posts by chop stiX
Old Dec 05, 2012, 11:39 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
then what would keep the can of the motor from moving backwards
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
is there suppose to be a shaft collar with set screw, no that would never fit
Old Dec 05, 2012, 11:45 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
The AMR does the most violent KE spin at our field hands down.
kuczy is offline Find More Posts by kuczy
Old Dec 05, 2012, 11:54 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
I guess it doesn't matter too much with the motor behind the firewall, all the thrust from the motor/prop is going to be pulling the can forwards so there is no way it is coming off anyways? Unless you nose in and maybe that will help save the motor/motorbox.
Old Dec 05, 2012, 11:57 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
As long as your motor is spinning in the right direction and your prop is on forward, there is no way the motor will move backwards. The spinning prop will keep everything pulling forward... More likely your prop adapter might pull off the front end in a high g spin- but no worries as to it coming off the back, it wont happen.
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Dec 06, 2012, 12:03 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
agreed, it just threw me, as I'm not used to motors mounted behind the firewall
Old Dec 06, 2012, 12:16 AM
chop stiX's Avatar
Joined May 2011
as I was about to answer that q the Big man BS answered
which color did you get inverted?
Old Dec 06, 2012, 12:21 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
red, it is a sweat plane, just about got it all about gone over and set up on my radio. Paid $200, had only 4 flights so I was told and I believe it from the condition, has trust 40, vox 13x6.5 prop, , phoenix 35 with castle 10a bec, 2 hitec hs65mg on tail and 2 hb on ailerons.
Old Dec 06, 2012, 12:27 AM
chop stiX's Avatar
Joined May 2011
awsome.that's a steal man.best $200 you will ever spend
just check the AMP draw.on the VOX 13x6.5 I was just under 40A at WOT
have a plush 40 in mine and it takes some punishment on that prop,so maybe just check the esc.
Old Dec 06, 2012, 12:28 AM
USA, GA, Atlanta
Joined Nov 2008
whata deal
Do put that on a watt-meter though to be sure you are not going to burn up that Phoenix ESC; as it is 35amp vs the suggested 45amp (especially if you step up to a 14x7 prop).
Old Dec 06, 2012, 12:37 AM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Yes will do that in the morning, it does seem small to me
Old Dec 06, 2012, 12:38 AM
rayonnair is online now
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Inverted, I think you're going to love this one
rayonnair is online now Find More Posts by rayonnair
Old Dec 06, 2012, 01:57 PM
inverted-i-fly
3drcparts's Avatar
Joined Mar 2011
Watt test came in at 34A at 375 watts on vox 13x6.5 does that sound about right?, I think I'm going to replace the esc with a 40a hobbywing that I have
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 09:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 09:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 08:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 12:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Kit/Scratch Built 9 Dec 08, 2001 08:03 PM
