Old Nov 19, 2012, 10:52 AM
rayonnair is offline
Find More Posts by rayonnair
rayonnair's Avatar
Singapore, Singapore
Joined Jun 2012
Originally Posted by chop stiX View Post
pleasure man.just to note.I don't have a thrust motor on mine.just to avoid confusion.the thrust motors CAN take LOTS of punishment.It's also less stress on the airframe if you pulse
Ah OK. It's all good. I think the advice is probably good for all motors... if anything if you're using less power you can spend more time in the sky and less time on the ground .
Originally Posted by JetPlaneFlyer View Post
I ended up with the CG at 48-49mm for hands-off inverted.. That's a full 10mm in front of the position advised in the manual. That may take the edge of the overly sensitive pitch response too.
Mine AMR laid up at the moment at one of the l/g legs started to de-laminate at the bend so I'm waiting for spares (UK stockist is out of stock again)
I've moved the CG up to 50mm from the outside LE of the top wing. Hopefully that calms things down. Will let you know this weekend if all goes well.
Originally Posted by HeeBeeGeeBee View Post
rayonnair...so glad to hear all is going well with the AMR! Nice video as it has me stoked to get mine in the air. Oh well...maybe after the holiday.
What a great group of guys on this thread.
Just fly it! *Dangles temptation in front of HeeBeeGeeBee*
In all seriousness sorry to hear you don't have the time. It's tropical where I live and usually doesn't rain in the mornings in the dry season - I haven't missed a weekend since april. The monsoon is coming, though, and the winds are changing around the flying field, so I'll probably be in a bind soon!
rayonnair is offline Find More Posts by rayonnair
Old Nov 20, 2012, 10:40 AM
rayonnair's Avatar
Joined Jun 2012
Finally managed to get rid of that 20g, for an AUW of 1164g. That'll have to do. I can't make it lighter without replacing the spinner or the servos.
I also re-taped the portion of the aileron hinge that became unstuck. Somewhat annoyed that it would come undone after a handful of flights! Even more annoyed now because the repair looks hideous .
I seriously cannot wait for this weekend!
Old Nov 20, 2012, 09:50 PM
subsonic is online now
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Did you try just ironing the hinge tape back down? It is heat activated.
subsonic is online now Find More Posts by subsonic
Old Nov 20, 2012, 10:03 PM
rayonnair's Avatar
Joined Jun 2012
Yup. I had hoped that that's all I needed to do, but it didn't seem to stick .
Old Nov 21, 2012, 10:13 AM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
One alternative is to apply clear transparent tape on it. I had to do it on mine after +3 years of flying it LOL
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Nov 23, 2012, 02:53 AM
rayonnair's Avatar
Joined Jun 2012
Aerofundan, I did put transparent tape on. But I can see the edges... and it doesn't match up against the original tape... so it annoys me. HAHA. It's OK, it's fixed.
Just ran 6 more packs through it.
I'm having tremendous difficulty finding the right CG on this one. Battery up against front edge of battery tray, and it's pitch sensitive and climbs inverted but flat spins beautifully. Move it 5mm forward, and it is so much more controllable on pitch and it sinks inverted but it doesn't flat spin inverted anymore, and the upright flat spin is jerky.
RAAAAAAAAAR!
It's over 20 packs now and it's still not trimmed right. I'll get it one of these days... I'll get it. Tomorrow is another day with another set of packs to run.
Old Nov 23, 2012, 11:30 AM
aerofundan's Avatar
Panama
Joined Jul 2005
RAAAAAAAAAR!
Are you sure its not your elevator servo? it could be that its not centering right, so its tricking you!
Site Sponsor
Old Nov 23, 2012, 01:26 PM
stgdz is offline
Find More Posts by stgdz
One blade in the water is wet
stgdz's Avatar
United States, MN, Buffalo
Joined Jul 2011
Anyone fly this inside of a baseball diamond? Little league diamond that is.
Trying to figure out if I should replace my little slick with this or an addiction. I tend to fly more high energy
stgdz is offline Find More Posts by stgdz
Old Nov 23, 2012, 05:10 PM
FlyWW1 is offline
Find More Posts by FlyWW1
FlyWW1's Avatar
United States, VA, Winchester
Joined Nov 2010
If you want high energy the Addiction is not the answer. The AMR is high energy but I'm not sure how much fun it would be to just fly in a baseball diamond. Unless your talking about a the whole field and not just the infield.
FlyWW1 is offline Find More Posts by FlyWW1
Old Nov 23, 2012, 05:11 PM
HaventFlownSince2014 is offline
Find More Posts by HaventFlownSince2014
DFC~ We Do Flyin' Right
HaventFlownSince2014's Avatar
USA, GA, Atlanta
Joined Nov 2008
I have flown mine in small ballfields, but it is not ideal. AMR carries energy well and it is tight. I get much more joy from flying the KMD, and Ad-X in smaller fields.
Like WWI said above, Addictions are not exactly "high energy"
HaventFlownSince2014 is offline Find More Posts by HaventFlownSince2014
Latest blog entry: New Drone Movie :D
Old Nov 23, 2012, 09:12 PM
rayonnair's Avatar
Joined Jun 2012
Thanks for the tip. I couldn't verify today because it was really windy so I flew as nose heavy as I could. I'll get it figured out tomorrow or next weekend I guess . The servo does have a bit of slop in it from the spline side so that could be an issue, I may have to swap out all the servos in the end.
Old Nov 23, 2012, 11:58 PM
stgdz is offline
stgdz's Avatar
Joined Jul 2011
decided against it, as much as I want a bipe I need the ability to change packs fast and a high energy plane.
back to the little slick I go.
Old Nov 24, 2012, 12:08 AM
USA, GA, Atlanta
Joined Nov 2008
stg~ FYI battery swaps take only a moment, it just takes some getting used to. As far as wanting a high energy plane; IMO I will take the AMR over a slick any day... My suggestions to consider another plane was based ENTIRELY on your venue (if you are trying to fly it in a small space).
If you want a high energy plane, dont hesitate on the AMR; this thing winds up like a top during spins and carries its energy so well. For years, it has been my favorite to KE spin.
Old Nov 24, 2012, 04:09 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
yep, nothing comes close to AMR in KE spins. It's almost unbelievable the first time you see one virtually catching its own tail in a frenzy.
demonGti is offline Find More Posts by demonGti
Old Nov 24, 2012, 05:54 AM
chop stiX is offline
Find More Posts by chop stiX
how'd I do that....oh
chop stiX's Avatar
South Africa, GP, Pretoria
Joined May 2011
DAMN straight!The AMR is an amazing plane,and tbh I would take it over a Slick aswell. i the size class.Hey check this if you wanna talk bout an AMR being flown in tight space
I saw a vid of a guy that flies it in a school gym.really tight.can't find the vid though
chop stiX is offline Find More Posts by chop stiX
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 10:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 10:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 09:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 01:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Kit/Scratch Built 9 Dec 08, 2001 09:03 PM
