Old Oct 22, 2012, 10:25 AM
kchen95 is online now
Find More Posts by kchen95
Taiwan, 北市
Joined Dec 2008
OK I haven't taken other photos yet, but here's the amount of down trim I need to get it to fly level. Is this normal?
Kevin
kchen95 is online now Find More Posts by kchen95
Old Oct 22, 2012, 10:26 AM
YellowJacketsRC is offline
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Kevin
That looks about right....
YellowJacketsRC is offline Find More Posts by YellowJacketsRC
Old Oct 22, 2012, 10:42 AM
Taiwan, 北市
Joined Dec 2008
Originally Posted by JetPlaneFlyer View Post
Kevin,
I went on (and on) about the CG a few pages back. It seems to be subject of some dis pure as some swear by the factory 57- 60mm CG.
Personally I found the CG had to be in the 47-48mm range for neutral trim. Even at that you might find that it climbs a little when inverted with low throttle, but at about 75% power it should fly level. You will need to be closer to 45mm to get a trim that needs a hint of down when inverted.
Are you using especially light batteries by any chance? Mine balances at 47mm with the rear of the battery about 20mm from the back edge of the tray and the front of the battery maybe 20mm from the firewall.
I'm using the stock battery and some Turnigy batteries, which are about 20g heavier than the stock battery. In both cases, I push the battery as far front as it will go, and the CG seems to be around 47-48mm.
But it's interesting you say that when inverted, it will still climb a little in low throttle - think low throttle was actually what I was doing. I had thought that the climb would get worse if I throttle up - kinda like in upright when most planes have a tendency to claim with higher throttle? If it's the opposite with inverted, maybe I'll try flying inverted with higher throttle and see how it goes.
The other thing I'm confused by is, if this plane needs a lot of down trim to fly level when upright, doesn't the down trim also cause the plane to climb when inverted?
Tks again for all the advice!
Kevin
Old Oct 22, 2012, 11:06 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Biplanes do have some unique peculiarities I think if you do your inverted test at higher throttle you will find it flies level, I know mine does.
Your down elevator trim seems to be the standard amount that's required on the AMR. You would think it would make the plane climb when inverted but it doesn't seem to, at least not if you have reasonable power on and the CG is in the 47-48mm range.
The down elevator does lead to strong pitch coupling in knife edge. I've got about 18% up elevator with rudder to mix out the KE tuck (the manual has an error on this point as it says to mix in down elevator)
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Oct 22, 2012, 12:21 PM
kuczy is offline
Find More Posts by kuczy
The Earth got in the way!
kuczy's Avatar
United States, OH, Canal Winchester
Joined Feb 2007
Mine uses about the same amount of down trim. Most bipes need some down.
kuczy is offline Find More Posts by kuczy
Old Oct 22, 2012, 01:24 PM
Vapor Trails is online now
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
looks all good to me
Vapor Trails is online now Find More Posts by Vapor Trails
Latest blog entry: Please kill isis
Old Oct 22, 2012, 01:56 PM
aerofundan is offline
Find More Posts by aerofundan
aerofundan's Avatar
Panama
Joined Jul 2005
It’s that time of the year again and PA Batteries Week is ON.
We are offering a special (once a year only!) discount
between the 22nd to 29th of October.
All Batteries will be offered at 30% discount throughout the week
There is no better time to stack up your PA Packs – a pack of two 3S 2200mAh (item Code AC-2146) – instead of $79.95 only $55.95!!! Don’t miss out!
These top quality battery packs will last and last and last..
www.PrecisionAerobatics.com
aerofundan is offline Find More Posts by aerofundan
Site Sponsor
Old Oct 22, 2012, 05:55 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Crashed mine today. Not much damage. Really to just a wing tip. It's pretty much destroyed at the tip. I can't believe a new lover wing is $75. Guess I'll do my best to fit it the best I can....
Old Oct 22, 2012, 06:12 PM
Mr Kamikaze is offline
Find More Posts by Mr Kamikaze
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
The wings are the most complex part as far as build and materials go.
Hope you get it sorted ok. It's worth giving it a shot but good to know if you can't then spares are available. Which is better than some manufacturers.
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Oct 22, 2012, 10:08 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
No, I know. At least I don't need to buy a whole new ARF and I can buy parts if needed.
My point though is if you look at PA's parts list though the sum of the parts is more than the ARF. Why is 1 top wing $74.95 and 1 bottom wing is $74.95 but both bought together are $125.95....?
I'm trying to fix it and I'll see how strong it is in the morning.
Old Oct 22, 2012, 11:24 PM
They Call him Dead!
Joined Jul 2003
One of the oldest marketing tricks on the book
Old Oct 23, 2012, 09:45 AM
USA, GA, Atlanta
Joined Nov 2008
If it makes you feel any better, I turned a wing half on my cub into toothpicks...
One wing half for Hangar-9 1/4 scale J-3 Cub = $210
A single roll of fabric covering to match what is applied to the rest of the plane = $65 per roll
Hours projected to remove monokote, prep surface, apply fabric, fabricate and apply stitching and panel details = approx hours
Old Oct 23, 2012, 10:05 AM
Vince_TT is offline
Find More Posts by Vince_TT
United States, PA, Philadelphia
Joined Dec 2011
Kevin
Hi Kevin, Taipei in my hometown but I have not visited there for a couple of years. Where did you get PA stuff in Taiwan? Where can you fly this beauty? Are there many 3D pilots there? Sorry to ask so many questions but I probably will have a business trip to Taipei in near future.
Back to the topic, I do not have AMR (really want one), but I do have two Pitts special and one Ultimate, like others said already, trimming a bipe sometimes is tricky. I found that I could play around the upper ailerons to erase unwanted pitching up or down but not affect the flying characteristics much.
Good luck!
Vince
Vince_TT is offline Find More Posts by Vince_TT
Old Oct 23, 2012, 11:44 PM
Taiwan, 北市
Joined Dec 2008
Good luck!
Vince
VInce, do I read your profile correctly that in addition to being from Taipei, you're now living in Philly? I'm actually a Philly guy (Valley Forge) who's now living in Taipei! Whenever you come out to Taipei, please do give me a shout and we can go flying. The best flying field in Taipei is at an area called Xin Chuang, where there is a paved runaway that was just paved two weeks ago. And yes there are a lot of 3D pilots here.
I actually ordered my PA Ultimate directly from Australia - with a hefty EMS shipping cost of around US$80. I believe there are a couple vendors in Singapore and Malaysia that sell PA planes, but with their mark-ups in price, I thought I was better off just ordering directly from Australia - it was a b-day gift from my wife, so I could afford to splurge a bit
Yeah I'm definitely finding the setup to this Ultimate somewhat tricky in trying to get it to fly exactly right. It's a bit of a surprise because back in Valley Forge, I built and flew the E-Flite Ultimate, which I thought was supposed to be the poor man's version of PA Ultimate, but that thing set up easily like a normal plane, with slight nose-heavy configuration and slight nosedive when inverted. Having said that, I'm guessing the tradoff is that the E-Flite Ultimate probably will not perform as well as the PA Ultimate when/if I graduate to more aggressive 3D flying.
It's a pleasure to meet a fellow Philly/Taipei pilot! Again, let me know when you plan to come out to Taipei.
Kevin
Old Oct 23, 2012, 11:53 PM
kuczy is offline
kuczy's Avatar
Joined Feb 2007
Repaired and ready to fly again. I'll just airbrush the stripes back on tomorrow.
Before
After
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 09:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 09:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 08:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 12:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Kit/Scratch Built 9 Dec 08, 2001 08:03 PM
