Old Oct 28, 2011, 08:27 AM
HeeBeeGeeBee is offline
Find More Posts by HeeBeeGeeBee
Lysdexic I'm
HeeBeeGeeBee's Avatar
Spring, TX
Joined Oct 2010
Thanks for all the tips guys. I'll check 'em all out.
HeeBeeGeeBee is offline Find More Posts by HeeBeeGeeBee
Old Oct 28, 2011, 09:27 AM
MalaysianFlyer is offline
Find More Posts by MalaysianFlyer
Joined Apr 2007
Originally Posted by demonGti View Post
Exactly, some guys fit potent engines to small cars only to break sideshafts, beef them up and the diff breaks, beef that up and engine mounts break, beef them up..... you get the idea. Its an on going problem over powering any vehicle (or model in this case) that was never intended to cope with excessive power. A fun project if you're that way inclined, but can become very tiresome... not my idea of fun.
That may be true, but I would love to see some video of the AMR on 4S !!!!!
MalaysianFlyer is offline Find More Posts by MalaysianFlyer
Old Oct 28, 2011, 05:26 PM
subsonic is offline
Find More Posts by subsonic
If it's to be, it's up to me.
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
My mate flies his on a 4s 1800 pack. It runs a smaller prop so it doesn't have the 3d authority that mine does, but it is faster.
subsonic is offline Find More Posts by subsonic
Old Oct 29, 2011, 07:41 PM
cepheus is offline
Find More Posts by cepheus
cepheus's Avatar
Canada, BC, Vancouver
Joined Feb 2009
I was using a 13 x 4 but tried a 14 x 7 to-day and the plane was crazy in KE spins etc especially with full power!!!! On the 4th flight the prop adapter, prop and spinner disappeared over some fir trees, rest of the plane is fine.Have to wait for parts to come from Australia as it's quicker than the US if you live in Canada.
cepheus is offline Find More Posts by cepheus
Old Oct 29, 2011, 07:58 PM
YellowJacketsRC is online now
Find More Posts by YellowJacketsRC
They Call him Dead!
YellowJacketsRC's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
14 x 7 on 4s? Are you kidding???
YellowJacketsRC is online now Find More Posts by YellowJacketsRC
Old Oct 29, 2011, 09:06 PM
cepheus is offline
cepheus's Avatar
Joined Feb 2009
No, it seems to work fine now I've glassed the mount around where the motor bolts on and also to the #1 former/bulkhead. Flying with a Nanotech 1.3 4cell so it's quite light. Goes crazy when you give it full down elev and full throttle.
Old Oct 29, 2011, 10:01 PM
They Call him Dead!
Joined Jul 2003
Yeah but what motor are you using? I am sure you are going to burn it up....
Old Oct 29, 2011, 11:08 PM
cepheus is offline
cepheus's Avatar
Joined Feb 2009
Thrust 40.
Old Oct 30, 2011, 02:35 AM
demonGti is offline
Find More Posts by demonGti
Precision Aerobatics Team
demonGti's Avatar
South Africa, GP, Randburg
Joined Dec 2006
What!?! I'd like to see your numbers on this.
Do you have a WATT meter to show us volts/amps/watts?
demonGti is offline Find More Posts by demonGti
Old Oct 30, 2011, 03:52 AM
JetPlaneFlyer is offline
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
A Thrust 40 swinging a 14 x 7 prop should be pulling about to 80 Amps and 1.1Kw. I find it hard to see how that can be so without smoking the motor?
You would also be discharging your 1300mAh batteries at 62C, that would give one minute flying time at WOT
Only thing i can see that might explain how you haven't smoked the motor already (assuming you are not winding us up) is that due to the super high discharge rate on those small cells voltage must be sagging massively. Suggest you put a Wattmeter on it before you run again.
Steve
JetPlaneFlyer is offline Find More Posts by JetPlaneFlyer
Old Oct 30, 2011, 05:05 AM
subsonic is offline
subsonic's Avatar
Sydney, Australia
Joined Jan 2007
Originally Posted by cepheus View Post
Thrust 40.
Yes! I love to see people stress testing this system. I always thought the T40 had some in reserve.
Need the numbers!
Old Oct 30, 2011, 02:24 PM
cepheus is offline
cepheus's Avatar
Joined Feb 2009
I don't have a meter but the guys at the local flying field do. I'll try and do this next time I'm there. Won't be till early Dec as I'm heading to Ca. Also there's a weather component up here in the coming months.Looks like a tough winter possibly. The motor won't overheat most of the year in Vancouver!!! Will post the figures when done.
Old Oct 30, 2011, 06:39 PM
shadow102 is offline
Find More Posts by shadow102
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
nailed my first KE spins with the AMR today...they look so cool in a bipe
shadow102 is offline Find More Posts by shadow102
Old Oct 31, 2011, 08:31 AM
NeverEnough is offline
Find More Posts by NeverEnough
NeverEnough's Avatar
USA, AZ, Phoenix
Joined Nov 2009
Figured out something goofy with the AMR when getting it to KE Spin. Instead of up rudder (Like I would on other planes), I gave it down rudder and it spun super tight and fast. It stayed locked in too. It was awesome. Anybody else done this?
NeverEnough is offline Find More Posts by NeverEnough
Old Nov 01, 2011, 08:58 AM
cayars is offline
Find More Posts by cayars
cayars's Avatar
Bridgeton, NJ
Joined Mar 2009
That's pretty sad.
cayars is offline Find More Posts by cayars
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 09:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 09:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 08:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 12:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Kit/Scratch Built 9 Dec 08, 2001 08:03 PM
