Old Oct 12, 2011, 08:52 PM
FLYINGJUNKY
eschult's Avatar
USA, FL, Jacksonville
Joined Mar 2008
Originally Posted by dead View Post
ok, here you go.... Of course i have seen a lot fancier jobs than this, but this was cheap, quick and easy. It also seems to allow for a fair amount of planes hung per square foot of wall without taking up half of the room. The hangers are from the home deeepoe....
nice!!!!!!!!!!!
eschult is offline Find More Posts by eschult
Old Oct 12, 2011, 08:56 PM
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
Oh yeah, That is a simple job. Just get a fresh Xacto and cut the hinges for the rudder and remove, then do the same for the rudder. It can be a bit of a PITA if you have to put new hinges in the same slots as the old ones, you have to do your best to cut in the with the xacto and work the glue and old hinge free. If you can simply move you hinge points over a bit it is much easier. Definitely do not use the dremel for any of this!
Thanks, need to see if I can do as good of a job on the elevator. PA has these hinged using packing tape. Plane flies perfect and i know that one little off set could screw the bird up pretty good. Looks like heavy packing tape????
Thanks,Eric
Old Oct 12, 2011, 09:05 PM
Play Dead!
Dead's Avatar
United States, SC, Pawleys Island
Joined Jul 2003
Oh Yeah, forgot about the tape. That, I believe was there attempt to save weight on the hinges and the glue. Their idea being that instead of hinging and then taping you could just use tape. I will have to look closer at that, but sitting here on the couch I would say to cut and remove the tape. Then hinge using standard cloth type hinges, and then put some blenderm tape on the bottom half to seal the gap.
Dead is offline Find More Posts by Dead
Old Oct 12, 2011, 09:33 PM
shadow102's Avatar
United States, GA, Acworth
Joined Mar 2011
somebody posted this up in another thread thinking about building something similar
shadow102 is online now Find More Posts by shadow102
Old Oct 12, 2011, 09:51 PM
Play Dead!
Dead's Avatar
Joined Jul 2003
That one is easy to build, cheap, and effective. But if you need to hang some larger models (48" and up) it won't be strong enough without bracing up the horizontal arms that the planes rest on, which cuts into you "hanging space".
Old Oct 12, 2011, 09:58 PM
shadow102's Avatar
Joined Mar 2011
i would think you could use larger pipe...then again balsa planes are much lighter than the foamies
Old Oct 12, 2011, 10:26 PM
Play Dead!
Dead's Avatar
Joined Jul 2003
Yes you could experiment with some 1" pipe and see. Be sure to get Schedule 40 pipe and NOT PR200 or what they call "Thin Wall"
Old Oct 13, 2011, 05:25 AM
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
I have a bunch of cloth hinges. So you think I should just cut out some slots and replace the tape w. hinges. Sounds like a good idea.
Thanks,Eric
Old Oct 13, 2011, 08:20 AM
Play Dead!
Dead's Avatar
Joined Jul 2003
Start reading here at post 2989: http://www.rcgroups.com/forums/showt...e#post12354879
Herc tells us how to do the hinges per the factory tape style. But if you find that too difficult (does not sound easy to me unless you get help from someone with two more hands) then just use cloth hinges. If hinges then be sure to use at least three per side because the trailing edge of the horizontal stab does not have a lot of wood to glue to. Let us know how it comes out.
Old Oct 13, 2011, 03:32 PM
shadow102's Avatar
Joined Mar 2011
finally finished the repairs on my AMR. New hacker a30-14L, eflite 40A esc, new dubro spinner, new larger wheels, new motor box, and a repaired cowling (going to order a new one on my next PA order). Plane feels heavier than before though the motor is supposedly the same weight, i know the ESC is heavier but i didnt feel comfortable with the one that was in there. hopefully i will get to fly it this weekend and nothing will go wrong this time lol.
Old Oct 13, 2011, 06:59 PM
Joined Apr 2007
More weight = more momentum = more fun tumbling!!!!! Don't worry too much about the weight after repairs, just go have a a good time !!!!
MalaysianFlyer is offline Find More Posts by MalaysianFlyer
Old Oct 13, 2011, 08:10 PM
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
I went ahead and removed the horizontal stab. I impreesed myself as it came out pretty clean!!! LOL. started from the back and used a very thin blade and alot of scoring the epoxy. All set to put the new one on and guess what????? Open the box from PA and look at the elevator next to the stab. Anyone know if this can be fixed w/o re-hinging. Funny as I spent all that time removing the stab because i did not want to re-hinge. Do you think I should send it back for a new one???
Thanks, Eric
Old Oct 13, 2011, 10:05 PM
I'm torquing to you!
Mr Kamikaze's Avatar
Wattle Grove NSW Australia
Joined Nov 2006
If you are ok to wait for a new one, yes.
Mr Kamikaze is offline Find More Posts by Mr Kamikaze
Old Oct 13, 2011, 10:34 PM
Play Dead!
Dead's Avatar
Joined Jul 2003
Nice work though....
Old Oct 14, 2011, 05:30 AM
FLYINGJUNKY
eschult's Avatar
Joined Mar 2008
I already emailed them last night form a call tag. That elevator would ne bugging me everytime I flew the plane.
Thanks, Eric
GP Ultimate Biplane conversion SoarNeck Sport Planes 14 Dec 28, 2008 09:11 PM
Simple Series Ultimate Biplane exowatt Sport Planes 4 Jul 09, 2002 09:35 AM
Ultimate Biplane Templates for Foam Construction Here hoppy Sport Planes 8 Mar 17, 2002 08:34 PM
ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. hoppy Foamies (Kits) 65 Jan 10, 2002 12:51 PM
Ultimate Biplane Colourschemes Armin Mangelmann Scale Electric Planes 9 Dec 08, 2001 08:03 PM
