http://www.chiefaircraft.com/rcmsec/...timateAMR.html |
King NorthCarolina
Joined Sep 2004
s. |
Resurrected an old friend today. Almost was ready to be done with her and order a new one. I did the motor box replacement last spring and a few doinks & fixes here and there. The last one this past summer seemed worse than it really was. Just had to reinforce the new motor box a little but mostly was building a new bat. tray. She's ready to go for re-maiden tomorrow!
Thanks for the picture subsonic, that’s a quality repair job. I was wondering how much darker the film would be on the overlap. I do use an old non steam iron for some covering repairs but I should get a real covering iron one day.
Good luck on the re-maiden Dan5.0. I hope it feels as good as new……or at least close to new.. |
i used my mums clothes iron for years when i was a kid. Put an end to that when after covering with dark blue Solarfilm, my dad's shirt got a blue streak on it, right across the collar. I was in deep Shiz over that one. A clothes iron runs a close second if you don't have a real covering iron. They are just quite heavy to use but still do an acceptable job. s. |
i'm about to build this airplane but i haven't gotten my package yet. i'm wondering if you all have any problems with the tail wheel? from the pictures, it looks like a wire just stuck to balsa. i wanted to know how the durability of this setup is.
i have a spare 3DHS tail wheel for my Slick 42" that i wanted to try on the Ultimate if it fits. that setup has a metal plate that screws on the fuselage. it has a hole where tail wheel wire pivots. this metal plate is what takes the stresses from the tail wheel instead of a wire straight to wood. |
Joined Mar 2010
If you are going to stick with the original tail wheel, just make sure that you use 5-min or better 30-min epoxy for gluing it to the rudder. It really makes a difference and all tail wheels that are glued with epoxy on my PA planes hold and are very strong. The ones I CAed are not very good. Jakub |
Joined Jun 2006
Just cut a narrow slot under the rudder along the position where the tailwheel wire runs and then embed it with epoxy. This is the method I use. You may like to refer to the step by step photos on page 1 at this link for the Extreme Mods for Your Katana MD http://malaysia-rc.com/index.php?topic=10147.10 Hope this helps RR |
| Thread Tools | |
| GP Ultimate Biplane conversion | SoarNeck | Sport Planes | 14 | Dec 28, 2008 09:11 PM |
| Simple Series Ultimate Biplane | exowatt | Sport Planes | 4 | Jul 09, 2002 09:35 AM |
| Ultimate Biplane Templates for Foam Construction Here | hoppy | Sport Planes | 8 | Mar 17, 2002 08:34 PM |
| ULTIMATE BIPLANE - Another Meat Tray (Depron) Project. | hoppy | Foamies (Kits) | 65 | Jan 10, 2002 12:51 PM |
| Ultimate Biplane Colourschemes | Armin Mangelmann | Scale Electric Planes | 9 | Dec 08, 2001 08:03 PM |
