View Poll Results: Should future Whim kits be designed to accomodate the LPS system
Yes, continue designing with LPS when possible 44 20.75%
No, small brushless outrunners are the only way to go 168 79.25%
Voters: 212. You may not vote on this poll
Old Aug 31, 2008, 10:33 AM
ParkScaleModels
zbrubaker's Avatar
United States, PA, Loganville
Joined Feb 2002
Park Scale Models "Whim" Indoor/Backyard Flyers
I've really had a blast designing and flying these little planes. I hadn't really ever thought about designing small planes like this until Dave Blum showed us his amazing little planes here in the Diddle Scale Style thread - what a cool concept! I liked the idea of having a nice light weight plane I could quickly and easily fly out in front (or in back) of my house any time the weather was good.
My first attempt was with the Howard DGA "Pete". while it flew, it wasn't as good of flyer as I wanted it to be...so I decided to design another (I need to revisit the "Pete"). This time it was the Hawker Hind, a pre-WWII light bomber biplane. This time it flew perfectly! And the best part was I had it built, covered and ready to fly in one day! I showed it to my wife and her comment was "That's whimsical"....hence the name 'The Whim' series.
Those that know me know these three things:
1. I hate to have a lot of money tied up into a single plane.
2. I can't leave a design alone until I feel it's the best I can make it.
3. I like things to be easy to do...build, fly, whatever...
So I started thinking....why do I have to have so much money in electronics tied up with such an inexpensive plane? That really bugged me. So I started tinkering with some ideas of a pallet concept that has been used in some other planes to be able to move the electronics (receiver, servos, ESC and motor) from one airframe to the next.
But with a plane this small, messing with control linkages whenever you wanted to move the electronics whould be a major hassle. So I thought about which components could be moved the easiest between airframes and settled on the receiver and speed control. I figured that this would save at least $50-$60 bucks to be able to move these two components from one airframe to the next.
So I settled on a 'tray' that would hold the receiver and ESC and be held in place by a 1/8" dowel 'pin' and a couple of rare earth magnets. Simply unhook the servos from the receiver and the motor from the ESC and move the 'tray' to another airframe! So now each plane is designed around this concept.
I didn't originaly intend to kit any of these, but there has been more than enough interest, so I decided not only to kit, but to keep expanding this line of designs.
So here is the guide line I am using for all of these designs now:
1. Low cost
2. Scale outlines
3. Quick build, simplified construction, low parts count and interlocking/self aligning parts
4. A great flyer!
Kits include all laser cut parts from contest grade wood and 1/32" ply (as necessary), carbon fiber rod (as necessary), 1/8" dowel and rare earth magnets.
http://www.parkscalemodels.com/shop/
ZRS4's SE5a Build thread
http://www.rcgroups.com/forums/showthread.php?t=908213
Mike Tully and Chris Parent's SE5.a and Fokker D-VII video thread
http://www.rcgroups.com/forums/showthread.php?t=813501
zbrubaker is offline Find More Posts by zbrubaker
Old Aug 31, 2008, 10:46 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
I'm usually not good at keeping new designs a secret, but this one I did. This will be my next kit to release in the next couple of months - a North American P-51C Mustang. I started this design about 3 weeks ago as I could find the time between my 'real' job, family time and a vacation. I maidened it yesterday and I am SUPER pleased! I'll post specs for it later.
Next up will be:
FW-190
P-47
ME-109
F-6 Hellcat
Zero
Old Aug 31, 2008, 11:22 AM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
I cant wait to get my fleet going and when I get home I will post pics of my SE5 in civilian barnstorming colors. I am also picking up a few at NEAT.
CapMike is offline Find More Posts by CapMike
Old Sep 01, 2008, 07:54 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Here's the specs for the P-51C Mustang -
Span: 23-1/4"
Length: 18-5/8"
Wing Area: 96.5 sq.in.
Controls: Rudder/Elevator (will be experimenting with Aileron/Elevator)
Motor: 10g brushless outrunner w/7A ESC
Weight: 3.8oz w/2S 300mAh LiPo, 4.1oz w/2S 450 mAh LiPo
Wingloading: 5.67oz/sq.ft - 6.12oz/sq.ft.
There will be some changes to the design and there are some area where I know I can shave some weight off. Given the wing area, I don't know that I can get it down to the wingloading necessary for indoor flight (I'd have to lose about 1oz. ), but it is definitely a backyard flyer for sure.
My maiden flight was with a 6x3 prop and while it flew well enough, I knew it could fly better so I switched to a 5x4.3 prop - what a difference! It easily loops from level flight at 3/4 throttle. The stall is what you would expect, one wing drops but recovery is fast. With the power cut off, I did another stall test, it would porpoise a little, but would not drop a wing.
It really wants to climb with full power, so I may adjust the thrust line on the motor mount or the change incidence of the wing a little. I had a lot of fun doing 'strafing runs' in my back yard - full throttle and a slight dive to about 10' off the ground then pull up while turning to the left slightly...looked just like a Mustang should!
I did some spins, stall turns and hammerheads - typical rudder only aerobatics. Ailerons would offer the ability for rolls, split-s and cuban 8 manuvers.
Given the weight/wing loading, I have decided to design for the little burshless outrunners only. I just don't think I can get the weight down enough to where a GWS LPS motor would fly it like it should. Besides...these little outrunners barely cost more than the LPS drives and deliver almost twice the power!
Old Sep 03, 2008, 12:54 PM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
P-51c
I kow for one that I can not wait to get my hands on this new plane and fly it hard and fast. When is it going to be available? More I want more of these little planes. Besides they look good and dont take up too much room. I can even keep them in the living room and my woman doesn't complain.
Old Sep 03, 2008, 01:40 PM
too busy looking forwards
theKM's Avatar
central PA.
Joined Sep 2004
that's awesome. more small balsa parkies, there's not enough of 'em around!
theKM is offline Find More Posts by theKM
Old Sep 03, 2008, 01:53 PM
Methuen, MA
Joined Sep 2002
Hi Zeke,
Chris and I will bring Snoopy and Hermann to NEAT for you to have in the booth Saturday/Sunday.
The P-51 looks great. Just a thought about aileron-elevator on a undercambered wing plane - the ailerons have zero effectiveness as the stall approaches. If you get the nose too high, then all you can do is push it back down and wait until you have sufficient speed to regain directional control. No such problem with rudder-elevator control planes, but they do lousy victory rolls.
Mike Tully is offline Find More Posts by Mike Tully
Old Sep 03, 2008, 02:06 PM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Great Mike...hopefully we can get in a couple of early morning dogfights! It would be cool to see three of these flying around together! A couple of SE5's laying in wait to pounce on Hermann.
Old Sep 03, 2008, 02:18 PM
Veni Vidi Volavi
Sterling, VA
Joined Jan 2002
Zeke
Ron and I will be bringing the SE-5a and the Fokker up to NEAT so there are a few extra planes for the Dawn Patrol. Lets see if we can schedule a dawn (or close to dawn) flight on Saturday AM weather permitting of course.
Brian Allen
Veni Vidi Volavi
I came I saw I flew
Brian Allen is offline Find More Posts by Brian Allen
Old Sep 03, 2008, 02:24 PM
echoplanar's Avatar
Lafayette, CA
Joined Aug 2002
Zeke-nice to see you will be expanding the line. Can't wait to see your Hellcat! I just ordered the SE5a and Fokker.
-Jon
echoplanar is offline Find More Posts by echoplanar
Old Sep 03, 2008, 06:42 PM
Airplane crasher
CapMike's Avatar
USA, CT, Shelton
I may be there for Saturday morning as well with my Yellow barnstorming SE5
Old Sep 04, 2008, 07:22 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
I had thought about that which is why I was considering going with a full length strip aileron. That way you would at a minimum have air from the prop going over part of the aileron. Not ideal, but it's something to experiment with.
Old Sep 04, 2008, 07:23 AM
ParkScaleModels
zbrubaker's Avatar
Joined Feb 2002
Excellent! This should be fun!
Old Sep 05, 2008, 10:11 AM
helimatt's Avatar
NJ
Joined Feb 2002
These are very neat.
What size battery packs are recommended?
helimatt is offline Find More Posts by helimatt
Old Sep 05, 2008, 10:16 AM
MN WATTS Master
Vintauri's Avatar
United States, MN, Mankato
Joined Jul 2003
I use a 2s 300mah polyquest in mine.
Vintauri is offline Find More Posts by Vintauri
Latest blog entry: WATTS over Owatonna
Cessna 206 StationAir by Park Scale Models zbrubaker Parkflyers 481 Sep 06, 2011 09:28 AM
Build Log Park Scale Models Cessna 182 Vintauri Parkflyers 88 Jul 22, 2010 12:53 PM
Sold FS - Park Scale Models-Monocoupe 90A zbrubaker Aircraft - Electric - Airplanes (FS/W) 2 Dec 14, 2006 12:37 PM
Park Scale Models Monocoupe Clearance Sale zbrubaker Parkflyers 5 Nov 27, 2005 12:44 PM
