Old Feb 08, 2003, 07:52 PM
Chris Roberts
Chris Roberts
Guest
n/a Posts
Re: Header Tank - what does it do?
Hi,
I'm a newbie too, so I may not be 100% right here, but I think the idea is
that the smaller header tank is always kept full by the pressurised fuel
system (until you're really low on fuel). This helps because when the
helicopter is upside-down or in any odd orientation, the clunk in the tank
will always be able to pick up fuel.
Hope this helps (and I hope I'm right!!)
- Chris
"Alan Spott" <alanspott@insightbb.com> wrote in message
news:W_h1a.38220$iG3.4944@sccrnsc02...
> Ok, I'm not afraid to ask a newbie question. Could someone briefly
explain
> the purpose of a header tank? Exactly what benefit does it bring?
> Thanks
Old Feb 08, 2003, 10:32 PM
Chuck W
Chuck W
Guest
n/a Posts
explain
> Thanks
This is RC car knowledge, so it may be a bit off, but here goes:
The header tank on a nitro car is there because your feul pressure system
has a natural delay time from when you gun the throttle to when it actually
increases fuel pressure (and flow) to your carburator. If you gun it quick
enough, that can kill the engine, or at least cause a lag and attempt to
die. In an RC heli, this would cause a loss of power to the head,
presumably when you wanted it the most. The header can give you a
momentary supply of fast fuel to the engine during that lag period while
your exhaust system catches up.
-Chuck W
Old Feb 09, 2003, 03:02 AM
Tim van Halteren
Tim van Halteren
Guest
n/a Posts
actually
quick
I don't see how the header tank would solve the problem you describe while
the pressure in the header tank is the same as the pressure in the main
tank.
Tim
Old Feb 09, 2003, 07:22 AM
Courseyauto
Courseyauto
Guest
n/a Posts
tank.
No it's not the same, the pressure in the header tank is constant and the
pressure in the main changes, this why you get a constant needle valve setting
while the engine runs on the header tank. without a header tank the needle
setting will change as the fuel level drops, unless you have a pump and
regulator, or a YS engine.
Old Feb 09, 2003, 09:32 AM
Tim van Halteren
Tim van Halteren
Guest
n/a Posts
> tank.
setting
needle
Some people still think this is how it works. I don't believe the header
tank keeps the pressure to your carb constant. It isn't possible.
If what you say is true and the pressure in the header tank remains constant
and the pressure in the main tank drops then there would be a growing
difference in pressure between them. This would cause fuel to move from the
higher pressure to the lower pressure thus it would go out of your header
tank and into the main tank. While we can all watch that this isn't the case
you statement can't be correct.
I don't argue the usefulness of header tanks but the one thing that it
doesn't do is to keep the pressure constant.
Tim
Old Feb 09, 2003, 11:22 AM
Martin Round
Martin Round
Guest
n/a Posts
explain
> Thanks
Three things:
1. Catches bubbles during aerobatics.
2. Increases fuel capacity.
3. Makes it easier to see when you are low on fuel.
The last one is especially significant on helis where the main tank is
mounted inside the canopy (e.g. X-Cell ST and SE)
There are drawbacks too:
1. Heavier.
2. More plumbing to go wrong.
Martin.
Old Feb 09, 2003, 11:52 AM
Biggie in PA
Biggie in PA
Guest
n/a Posts
Who said anything about a car?
Biggie in PA
sjg1958 at hotmail dot com
"Chuck W" <cwiley101@comcast.spamdeath.net> wrote in message
news:Q3-dnU6TS944StijXTWcqg@comcast.com...
> explain
> > Thanks
actually
quick
> -Chuck W
Biggie in PA
Biggie in PA
Guest
n/a Posts
The header tank should be void of air bubbles. This "buffer tank" keeps the
engine from sucking in air that may occur :
1) if the heli vibrates and the engine foams.
2) when performing 3D maneuvers
Biggie in PA
explain
> Thanks
Old Feb 09, 2003, 12:52 PM
Chuck W
Chuck W
Guest
n/a Posts
"Tim van Halteren" <t_dot_van_dot_halteren@inter.nl.net> wrote in message
news:3e461546$0$19800$19deed1b@news.inter.NL.net.. .
system
> actually
> quick
> tank.
> Tim
My fault. What I'm talking about is a booster tank, or boost bottle. It's
not part of the actual tank. Different animal.
-Chuck W
Old Feb 09, 2003, 06:42 PM
Phil Noel
Phil Noel
Guest
n/a Posts
Hi Tim,
You are absolutely correct. The header tank DOES ABSOLUTELY NOTHING to "keep
the pressure constant". As this has been a "wives tail" believed by many
years ago, it finally seems to have been put to bed. I have explained the
physics of this many times here and in other forums, and have conducted
experiments, at many symposiums/seminars over the years, that clearly
illustrate the fact that it does diddly squat to keep the pressure constant,
I will not go into detail again.
I thought that the world has finally accepted the fact that it does nothing
for constant pressure. As decoursey's post illustrates, it seems there are
still a few that believe it does.
As the others have pointed out, it is a "air-bubble" trap in the fuel line,
it gives a bit more fuel capacity, and it can be poitioned in a location to
indicate fuel capacity (as a small reserve tank) in systems where the
maintank is not in plain vue.
Those are its' only benifits.
Phil
news:3e4670b3$0$19805$19deed1b@news.inter.NL.net.. .
while
> > tank.
the
> setting
> needle
constant
the
case
> Tim
Old Feb 09, 2003, 08:52 PM
x-guy
x-guy
Guest
n/a Posts
Yes you are 100% correct
"Chris Roberts" <chris@bms-systems-ltd.co.uk> glsD
:b24bgn$53i$1@news6.svr.pol.co.uk...
> Hi,
> - Chris
> explain
> > Thanks
Old Feb 10, 2003, 07:02 AM
David Lodge
David Lodge
Guest
n/a Posts
A header tank is just like a length of v large bore tubing. It does
two things:
- acts as a bubble trap so you get pure fuel going to the engine
- gives you a couple more minutes run time at the end.
It doesn't affect the fuel pressure to the engine, untill the main
tank is empty, then the header tank becomes the main tank.
David.
"Alan Spott" <alanspott@insightbb.com> wrote in message news:<W_h1a.38220$iG3.4944@sccrnsc02>...
> Ok, I'm not afraid to ask a newbie question. Could someone briefly explain
> Thanks
Old Feb 10, 2003, 09:02 AM
Philip Martin
Philip Martin
Guest
n/a Posts
"David Lodge" <david@cherrybank.co.uk> wrote in message
news:6e6cfcb.0302100450.49304007@posting.google.co m...
> two things:
Hmmm, let me chuck yon spanner in the works then!
Conventionally the fuel tank seems to be mounted below the level of the
engine / carb. Thus when in normal flight the only pressure on the carb is
that of the exhaust take off pushing the fuel through to the carb (unless of
course we are talking Perry pump or YS engine). However when the heli goes
into inverted flight you have the above pressure plus the weight of the fuel
in the tank = more fuel flow to the carb.
Now if a header tank is fitted with its outlet on centre line with the carb,
the pressure on the carb will be slightly increased (because of the head of
fuel), no matter which way up the heli is.
?;o)
Phil Martin.
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.449 / Virus Database: 251 - Release Date: 27/01/2003
Old Feb 10, 2003, 11:52 AM
Courseyauto
Courseyauto
Guest
n/a Posts
two things:
Wouldn't it be more correct to call it a fuel trap, as the idea is to keep it
full of fuel.
I also get a more consistant run with my header tank set up than i did
without it,for what ever reason. DOUG
Old Feb 10, 2003, 12:42 PM
Dan G.
Dan G.
Guest
n/a Posts
"Courseyauto" <courseyauto@aol.com> wrote in message
news:20030210123934.07728.00000485@mb-mg.aol.com...
> two things:
keep it
> full of fuel.
Maybe since no more tiny air bubbles get to your engine near low tank?
Help! Walkera 5#6 Gyro Pot - what does it do? helitoad Coaxial Helicopters 2 May 05, 2007 05:30 AM
Question Corona Tail-Fin... what does it do? AnthonyRC Electric Heli Talk 7 Oct 31, 2005 05:06 PM
What does nose heavy do? tekochip Power Systems 8 Dec 06, 2001 07:58 PM
Correction: What does the flybar do? Ben Diss Electric Heli Talk 8 Jun 04, 2001 12:48 AM
