Can any one Identify this Model
I recently obtained from an older club member, a 32 inch (830mm) "old timer"
The member was moving away and downsizing, and was about to throw out the model. He didn’t know the name of the model but had used it for many years as an instructional aid. The model is clearly a kit as some wing ribs were numbered and it had a plaque inside saying it was constructed in Hong Kong in 1971. ( Name and address were given) It was an IC model with a very small triangular rudder, probably one channel RC. I was taken by it and asked if I could have the aircraft. After sanding off layers and layers of paint I rebuilt the empennage, added elevators and increased by 100% the rudder, while still retaining the basic shape. The wood was very hard and heavy and after removing the paint and my building work on the tail I had lightened the aircraft by nearly 3 oz which was important as I was going to use a brushless motor and did not want to have to add lead to balance it. All up flying weight is 10 oz I added a little GWS brushless 002 motor and with a 600 mAh 2 cell battery I get about 12 to 15 minutes flight just puttering around or on full throttle she flies like a witch. I am very pleased with this little model as it is just the best flyer but I would like to know what it is? Can any one help? John
This looks a lot like the 1961 Graupner "Topsy"
See here : http://www.koralpe.biz/topsy.htm and here :
If like me you are puzzled at the prop saver on the Cox engine, check this : http://www.rcgroups.com/forums/showthread.php?t=888673 http://www.powercroco.de/elocox.html |
| Thread Tools | |
| Discussion dose any one have this model? | mike22115 | Electric Plane Talk | 4 | Mar 02, 2008 08:55 PM |
| Discussion can any one identify this heli | Supersix | Electric Heli Talk | 7 | Apr 01, 2007 02:47 AM |
| Discussion Can any one use this?? | x45acp | Motorcycles | 2 | May 31, 2006 06:53 PM |
| Question Can Any one ID this boat | wingnut163 | Sailboats | 9 | Jan 11, 2006 01:25 PM |
