Aug 31, 2008, 03:05 PM
Joined Oct 2007
Here are the specs, straight from Tower:
FEATURES: Construction: Molded foam, white in color Wings: One-piece foam construction Landing Gear: Prebent wire nose and main gear Wheels: Three foam 1.02" (26mm) diameter
INCLUDES: Molded foam fuselage, one piece foam wing, foam tail surfaces, foam engine nacelles with preinstalled ducted fan housing, ducted fan rotors, prebent landing gear wires, nylon wing mount bolts, linkage hardware, instruction manual and decals
REQUIRES: Three channel radio system with micro servos (FUTJ54**) Two brushless ESCs at least 10 Amps (GPMM1810) Two brushless motors 11.1V Lipo battery pack (GPMP0609) AA Batteries: Eight for transmitter (SANP3501) Pliers and phillips screwdriver
SPECS: Wingspan: 32.7" (830mm) Wing Area: 149 sq in (9.62 sq dm) Length: 31.9" (810mm) Weight: approx. 14.5 oz (410g) Control Throws- Rudder, right and left: 0.35 - 0.39" (9 - 10mm) Elevator: Not listed CG (center of gravity): 4.1 - 4.3" (105-110mm) forward of the trailing edge of the wing measured at the fuselage with battery pack installed Distance of Control: 1640 ft (500m) Flight Time: Approx. 4 minutes
