Old Sep 20, 2008, 08:59 AM
papabatman is offline
Find More Posts by papabatman
Shut up and fly
papabatman's Avatar
United States, CO, Dacono
Joined Jun 2008
ok just got done with more testing, with no equipment, and all results are just guessing.
well through on the apc 10x10e prop it is a little different then the 11x7e. the nose lifts. was kinda bad at full throttle, but if i let off the power then it was to slow for what i wanted.i had to trimmed her out after that. i think the 10x10e is more power house prop, she climbs faster and does have a bit more speed. now i didn't like the way the bird flew with this prop. she sucked the juice down to quick didn't make anything hot or even warm just shorter flight time, also just wasn't a nice smooth flight ether. that is the best i could do you have to try them both to see what i mean. my vote is still the 11x7e apc this was all stock set up 2200 25c 3s
papabatman is offline Find More Posts by papabatman
Old Sep 20, 2008, 09:22 AM
aviator24 is offline
Find More Posts by aviator24
Flint, Michigan
Joined Aug 2008
Well...
Originally Posted by Rob_G
Here's a spy shot of the new PZ Stryker 'Big Daddy' combat wing, coming in november!
Rob
pps. this was parked in my usual flying spot today. It's a wing, but from what I have no idea...
It looks big, but still, your pretty much obligated to slap a motor and some servos on it and fly it!!!!!
Better use 2 motors and a couple big batteries
aviator24 is offline Find More Posts by aviator24
Old Sep 20, 2008, 09:45 AM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
If it stops raining I am going to a new club today to fly.
Will start with my 900 mah battery and take it easy.
put in a 3 cell and fly like normal
then when the right time occurs I will put in the 4 cell and surprise lots of people with my corsair.
no one will know what hit them, because mine is still stock pnp as I had before except now for the spar.. I am going to trick those guys lol
Got to get a streamer for it so I will know which is mine.
David22 is offline Find More Posts by David22
Reply With Quote  (Disabled)
Old Sep 20, 2008, 10:00 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Yer gone melt sumthin...
Why not pick up something like an Eagle Tree or at the very least, a wattmeter of some sort?
Jeff
www.CommonSenseRC.com
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Sep 20, 2008, 10:16 AM
David22 is offline
Joined Apr 2008
No 10X10's to be found for my corsair
within 50 miles or more from where I live
Will try to order a few
I have the "watts up" or something like that everyone should have
it is a must
but for my power set ups I have a general idea what it pulls from previos testings and now just use the old fashioned feel with my hand for temperature test
if it is hot it is not a good thing
your static tests will be scewed, because of the burst of a fresh battery, voltage(etc.), which battery you use etc. test a few props or maybe 10 of them to see how the test results are, write them down.
now go back and do it again. see if the figures are the same!
very light foamy (stock corsair), and say someone who has added 5 oz or so the the plane with the same set up, will have same static results but in the air it will be a different ball game.
even if your system works really well as you set it up and you change to a higher mah battery you are adding weight and have to be carefull of over heating due to weight
Old Sep 20, 2008, 10:41 AM
David22 is offline
Joined Apr 2008
safety question?
This is a 2200 battery from parkzone, I have never had one puff up on me before.
Is this unsafe or am I ok?
going to be used in my corsair today
Old Sep 20, 2008, 10:45 AM
Tram is offline
Tram's Avatar
Florence, Al
Joined Oct 2000
Looks a lil' puffy..
Old Sep 20, 2008, 10:48 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
are you saying that it puffed or that you are afraid it will puff
i had a 2200 pkz and i did kinda crash it in a p-51 once, and it did puff some i kept flying it never had a problem but that is me. but 15c i think you want more
yep same puff i think it is normal lol
Old Sep 20, 2008, 10:50 AM
neiloneil is offline
Find More Posts by neiloneil
LOVE MAIDEN'S : >
neiloneil's Avatar
norfolk va
Joined Aug 2007
yeah im not to sure about that one bro
neiloneil is offline Find More Posts by neiloneil
Old Sep 20, 2008, 10:53 AM
David22 is offline
Joined Apr 2008
got to use the batteries that I have , like a warm up battery
in this case it might get a little too warm lol
Old Sep 20, 2008, 11:03 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
after i puffed mine i just hammered it to death about 35 flight in a prakzone p-51 with the 6 series 2700kv motor 10x7 e-flight prop. the batter did die not from puffing but i pulled a wire out removing from my charger when i was in a hurry. remember i am not all that bright you should get rid of it for safety after awhile
Old Sep 20, 2008, 11:27 AM
turbonut is offline
Find More Posts by turbonut
Pro Hoarder
turbonut's Avatar
upland CA
Joined Dec 2004
Do not use a puffed batt...is the price of a battery worth the loss of your plane or your car you are transporting the batt in..if it puffed it is going bad and can self ignite at any time if you keep charging it or running it..send it back to Horizon.
Scott
Old Sep 20, 2008, 11:34 AM
Shut up and fly
papabatman's Avatar
Joined Jun 2008
http://www.rcgroups.com/forums/showthread.php?t=719116
Old Sep 20, 2008, 12:58 PM
David22 is offline
Joined Apr 2008
That one is not new by any means.
No warranty for me.
Will dispose propery.
you are right it is not worth it.
Old Sep 20, 2008, 04:13 PM
Taylorman is offline
Find More Posts by Taylorman
Taylorman's Avatar
Cleveland, Ohio
Joined Jul 2006
Puffed battery + Expensive plane = Magic Smoke and fiery crash that everyone talks about around the field for generations!
Taylorman is offline Find More Posts by Taylorman
Cool Hangar 9 F2G-2 Super Corsair in Action Richard L. Fuel Warbirds 10 Jul 08, 2014 12:32 AM
Yippee! ParkZone's New Warbird F4U Corsair ty_horn Electric Warbirds 1956 Sep 02, 2008 09:23 PM
For Sale F/s Nib Gws F4u Corsair theroo Aircraft - Electric - Airplanes (FS/W) 0 Dec 17, 2005 07:47 PM
Sold F/s Nib Gws F4u Corsair theroo Aircraft - Electric - Helis (FS/W) 1 Oct 19, 2005 05:28 PM
Corsair in action! pierluigi demontis Scale Kit/Scratch Built 10 Jan 21, 2002 09:58 AM
