This thread is privately moderated by FLOEY, who may elect to delete unwanted replies.
Old Aug 27, 2008, 12:29 PM
FLOEY is offline
Find More Posts by FLOEY
Norway
Joined Dec 2007
Mini-HowTo
Replace ball bearings with Carbon tube Bushing
One of my cheap Tower Pro Brushless motors had nasty sound when
propeller shaft was rotated. Broken / worn out ball bearings most likely.
So I removed the ball bearings or at least the most of them. The forward
one still got some of the bearings housing pressed into the aluminium stator core.
I decided to try to repair the motor by adding a carbon bushing instead
of new ball bearings who would cost more than the motor was worth.
I used a piece of 5mm dia carbon tube drilled/grinded up to approx
3mm inside (must be drill / grinded by hand to get a tight fit around
propeller shaft)
After that the steel shaft was rotating freely in the bushing it was
glued in the aluminium stator core (remember to degrease before
gluing).
The test runs so far has shown that the alu. core is getting a bit hot
but there is no bad sounds or any detectable wear so far.
See sketch below
FLOEY is offline Find More Posts by FLOEY
For Sale Tamiya Hummer with ball bearings WJH Cars - Cars and Parts (FS/W) 1 May 26, 2006 05:35 PM
For Sale Chevy starter with dual ball bearings and winch drum for a sport winch. rogerflies Aircraft - Sailplanes (FS/W) 1 Apr 16, 2006 02:49 PM
i need help with ball bearings please. sharpiehead Micro Helis 10 Mar 30, 2005 08:32 PM
i need help with ball bearings please. sharpiehead Micro Helis 8 Mar 30, 2005 06:23 PM
Corona Carbon Fiber Boom with Ball Bearings with EXTRAS n111kx Aircraft - Electric - Helis (FS/W) 2 Nov 25, 2004 04:49 PM
