Old Aug 25, 2008, 08:14 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
AP UAV methodology.
Someone asked somewhere else what would be neded to get a model to fly a preplanned course at a given altitude, stabilize and take an aerial survey set of pictures.
I decided that some sort of two axis gyro and a GPS system,plus some microcontroller smarts was what would be needed.
What is available to do the GPS? a module or chipset that you can read from a PIC or similar and determine position and altitude?
And how do you determine heading? Or is it a question of simply working it out from repeated position measurements..I know that standard GPS is only accurate to a few meters, but does it have enough resolution to detect a position CHANGE to less then that?
Old Aug 25, 2008, 09:18 AM
nagyizee is offline
Find More Posts by nagyizee
nagyizee's Avatar
Szčkelyföld, Transylvania (RO)
Joined Jun 2008
NMEA messages from GPS module already contain the heading and speed. The GPS module calculates these parameters from successive position measurements. The positioning accuracy is a couple of meters but the difference between two position measurement has only a little error (couple of cm) so the speed and heading is decently accurate. Heading is more accurate with higher speed.
For an integrated GPS/3xGyro/Accelero module I would recommend to look at:
http://www.xsens.com/en/products/mac...otion/mtig.php
nagyizee is offline Find More Posts by nagyizee
Old Aug 25, 2008, 12:39 PM
aaronbeekay is offline
Find More Posts by aaronbeekay
aaronbeekay's Avatar
Joined Mar 2008
Take a look at the fantastic work being done here:
http://diydrones.com/profiles/blog/s...ogPost%3A44814
That's the page for one of their products. I know they have several other versions, as well as a blimp, and the site is just chock-full of fascinating information and brilliant work.
aaronbeekay is offline Find More Posts by aaronbeekay
Old Aug 25, 2008, 02:24 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Now we are talking..I wasn't aware that work had progessed that far....
If that module can control a rudder, and throttle, then a gyro for the elevator and ailerons should keep all steady enough.
Old Aug 25, 2008, 05:32 PM
Joined Mar 2008
The guy who runs that project is editor in chief of Wired Magazine, and they've done some pretty incredible things. Check out the BlimpDuino for an example-- a fully autonomous helium blimp, with thrust vectoring on two axes and the ability to follow waypoints and find IR beacons.
The ArduPilot Pro, on the same site, integrates full attitude control and stability (4 channels, I believe) with two CPUs, but it's not as far along as the ArduPilot, which is nearly in production.
They recommend the FMA Co-Pilot for stability control, but I'm not familiar with it. YMMV.
Discussion ARF OV-10 for AP/UAV work rob10000 Aerial Photography 7 Jun 29, 2006 11:31 AM
Discussion ARF OV-10 for AP/UAV work rob10000 UAV - Unmanned Aerial Vehicles 0 Jun 28, 2006 06:19 PM
Discussion Cheap AP/UAV plane, a mental excercise. Medve UAV - Unmanned Aerial Vehicles 15 Apr 20, 2006 06:46 PM
New Product New 4 wing Tango AP UAV Sky Link Aerial Photography 26 Mar 12, 2006 06:00 PM
Yet Another AP UAV... JeffreyB Aerial Photography 4 Mar 14, 2005 01:07 AM
