This thread is privately moderated by robertdhayes, who may elect to delete unwanted replies.
Old Aug 24, 2008, 10:30 PM
robertdhayes is offline
Find More Posts by robertdhayes
Trader Rating: 6
Mesa, AZ
Joined Aug 2008
Trader Rating: 6
Sold
E-flite Power 32 Brushless Outrunner Motor, 770Kv
$60obo shipped. I flew this motor on an Ultra Stick 25 for approximately 7-8 flights. In perfect condition. Basically new. Thank you >>>>>
Product Features
Equivalent to a 30- to 36-size glow engine for sport and scale airplanes weighing 3.5–6 lb (1.6–2.7 kg)
Ideal for 25- to 36-size 3D airplanes up to 4.5 lb (2 kg)
Ideal for models requiring up to 700 watts of power
High-torque, direct-drive alternative to inrunner brushless motors
Includes mount, prop adapter and mounting hardware
Quite, lightweight operation
External radial rotor design—5mm shaft can easily be reversed for alternative motor installations
High-quality construction with ball bearings and hardened steel shaft
Slotted 12-pole outrunner design
Overview
The Power 32 is designed to deliver clean and quiet power for 30- to 36-size sport and scale airplanes weighing 3.5- to 6-pounds (1.6- to 2.7-kilograms) 25- to 36-size 3D airplanes up to 4.5-pounds (2-kilograms), or models requiring up to 700 watts of power. Its especially a good match for the Gee Bee Tiger Moth, TopFlite DC-3, Phoenix Sonic 25 and 3D airplanes such as the E3D.
Technical Notes
Maximum operating temperature: 220 deg Fahrenheit.
Adequate cooling is required for all motor operation at maximum current levels.
Maximum burst current duration is 15 seconds. Adequate time between maximum burst intervals is required.
Specifications
Type: Brushless Outrunner
Size: Replacement for a 30- to 32 size glow engine
Bearings or Bushings: Ball Bearings
Wire Gauge: 14
Recommended Prop Range: 11x7 to 14x10
Voltage: 12 - 16.8
RPM/Volt (Kv): 770
Resistance (Ri): .02 ohms
Idle Current (Io): 2.40A @ 10V
Continuous Current: 42A
Maximum Burst Current: 60A (15 sec)
Cells: 10-14 Ni-MH/Ni-Cd or 3-4S Li-Po
Speed Control: 60A Brushless
Weight: 200g (7.0 oz)
Overall Diameter: 42mm (1.70 in)
Shaft Diameter: 5mm (.20 in)
Overall Length: 50mm (1.90 in)
Needed to Complete
60A Brushless ESC
3S - 4S Li-Po or 10 - 14 Cell Ni-MH/Ni-Cd
11x7 to 14x10
robertdhayes is offline Find More Posts by robertdhayes
Old Aug 24, 2008, 11:52 PM
stents3 is offline
Find More Posts by stents3
Trader Rating: 45
"Annie"
stents3's Avatar
United States, NY, Centereach
Joined Mar 2006
Trader Rating: 45
Power 32
PM sent
stents3 is offline Find More Posts by stents3
Old Aug 25, 2008, 08:47 PM
mickydee is offline
Find More Posts by mickydee
Trader Rating: 165
Hemet, California, United States
Joined Aug 2001
Trader Rating: 165
Hi,
Sill available?
Mickydee
mickydee is offline Find More Posts by mickydee
Old Aug 25, 2008, 08:57 PM
Trader Rating: 6
Mesa, AZ
Joined Aug 2008
Trader Rating: 6
In negotiations. But so far yes thank you.
Sold E-Flite Power 60 Brushless Outrunner Motor, 400Kv FREE SHIPPING Mikey 68 Aircraft - Electric - Power Systems (FS/W) 5 Jul 21, 2008 10:08 PM
Sold E-flite™ Power 46 brushless outrunner motor rapster Aircraft - Electric - Power Systems (FS/W) 1 Feb 24, 2008 04:09 PM
Sold E-Flite Power 10 Brushless Outrunner Motor NIB moxjett Aircraft - Electric - Power Systems (FS/W) 0 Jan 09, 2008 09:07 PM
Sold NIB E-flite Power 32 Brushless Outrunner mjeffdavis Aircraft - Electric - Power Systems (FS/W) 4 Aug 28, 2006 08:12 PM
New Product e-flite power 32 brushless outrunner sokmeister Power Systems 3 Feb 03, 2006 04:29 PM
