Old Aug 23, 2008, 10:20 PM
IBCrazy is offline
Find More Posts by IBCrazy
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Build Log
Alex's twin motor hovercraft
Well, technically a hovercaft does fly right? It just flies at low altitude.
Since my first hovercraft was a success, I decided to make a bigger and better one. This one will use two motors rather than only one. One is dedicated to the lift, the other is the drive. I'm thinking I will make a finger skirt for this one rather than the typical bag style that I employed on my first model. We'll see how it goes.
Another first for me, this one is mostly wood construction (ie. not foam). The bottom is foam so it can naturally float without the skirt inflated.
The craft measures 32"X20" and will have a 2" hover height. I estimate it will weight about 50 oz or so. So the bottom area will be ~600 square inches supporting 50 oz weight. That means the lift motor must produce 1/160 psi to lift the craft.
IBCrazy is offline Find More Posts by IBCrazy
Old Aug 23, 2008, 10:36 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
frame construction
I build the frame out of Basswood. Balsa is a little too flimsy and takes on water easily. I would have used ply, but it is expensive and heavy. I used 3"X1/8" for the main rail. It will have foam glued to the bottom for flotation.
I glued a 1" strip along the bottom inner edge to begin the transfer chamber. The transfer chamber is 3" wide and will be fed by the lift fan. The transfer chamber will transfer the air around the craft and into the plenum chamber which lifts the craft.
Old Aug 23, 2008, 10:42 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Making the bottom
The bottom of the craft is foam. It naturally floats and is water proof, so it works well here. I traced out a form of the inside of the frame on the foam. This will be glued to the bottom of the frame and will be the top of the plenum chamber. I made it 1" wider than the bottom of the craft to make a bigger transfer chamber. I secured the foam to the wood with gorilla glue.
Old Aug 23, 2008, 10:55 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Finishing the transfer chamber
To finish the transfer chamber, I glued basswood at a 60 degree angle to the bottom of the craft. I then drilled many holes in it which will transfer air into the plenum chamber and the skirt. The angled chamber helps the craft overcome obstacles and such that are higher than the hover height. A squared edge will bring the craft to a jarring halt where the angle wants to rise over an obstacle.
The holes should act as individual air ports for each finger of the skirt. Before I get to the skirt, I'm going to set up the lift motor on the topside of the hull.
Old Aug 26, 2008, 09:16 AM
critterhunter is offline
Find More Posts by critterhunter
critterhunter's Avatar
Joined Oct 2006
Looking good, Alex. I may build a RC hovercraft in the future. RC cars never interested me since I drive a car in real life but I'm pretty sure I'll never fly a plane. On the other hand, a hovercraft would be cool and it also doesn't have expensive wear and tear that the RC cars do.
critterhunter is offline Find More Posts by critterhunter
Old Sep 29, 2008, 08:41 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Skirt construction
Ok, so after 5 weeks I'm finally getting back to this one. The skirt on this one is a finger skirt. I have never made a finger skirt before, so hopefully it will work.
The idea is that each individual "finger" acts as it's own, and will easily deflect if it hits an obstruction. I chose this type for two reasons:
1. The bag skirt had a tendency to take on water and was a pain to purge
2. I had never done it before
Each finer was glued on one side all the way around the craft with Goop. Once dry, I glued the other side to the frame.
Old Jun 19, 2009, 06:24 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Bag skirt
The finger skirt turned out to be too stiff. It would never have sealed so I went with a bag skirt. The entire skirt is sealed off except from inside the transfer chamber so it shouldn't pick up anything from the road or water. Again, the skirt is made from a cheap shower curtain and glued together with shoe goo.
I cut a 5" hole in the bottom of the craft for air to reach the plenum chamber. I then cut a cheap plastic bowl into a 2" cylinder and glued it into the hole. This will keep water out of the craft when I deflate the skirt.
The pressure vessel distributes the air to the rest of the craft. There are 6 ducts that transfer air into the transfer chamber and a hole every 2" along the transfer chamber to deliver air to the skirt. The vessel maintains pressure with a single small prop. Pressure in the chamber is approximately 1/5-1/8 psi.
I also glued an "H" out of 1/2" balsa wood strips. This way when I deflate the skirt at speed the craft drops on the wood and not the skirt. It's basically a set of brakes.
-Alex
Old Jun 19, 2009, 06:29 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Drive system
The drive system is a rudder with the motor mounted to it. This basically gives me thrust vectoring for the best possible turns. The motor swings a large 9" prop for maximum acceleration and torque.
The rudder is made from coroplast with a flute cut out for a pivot.
The lift fan is a small 6" prop. Smaller props are better than larger ones as they require less power to generate the needed pressure. Remember that pressure is what lifts the craft, so all you need to do is keep up with the air flow once pressure is established.
Old Jun 19, 2009, 06:35 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Completed craft
The hovercraft performance is nothing short of exceptional. I can hover on as little as 30 Watts and it will lift a full 20 lbs at full power of only 60 Watts! I might increase the prop pitch from a 6X4 to a 6X5.5 to get more air flow in rough areas.
Weight on this one is a bit over 3 lbs, which is fairly light for a 30X21" craft. The size is great for stability on choppy water. Top speed is 22 mph at which point the front end lifts in the air and it back flips I need a bit more weight if I want to go any faster.
Old Jul 04, 2009, 09:06 AM
parkpilot101 is offline
Find More Posts by parkpilot101
Grafton, Oh
Joined Jun 2008
it looks cool
parkpilot101 is offline Find More Posts by parkpilot101
Old Jul 04, 2009, 02:24 PM
BrunswickOH is offline
Find More Posts by BrunswickOH
Brunswick, Ohio
BrunswickOH's Avatar
Joined Aug 2003
Any chance of some video of this in action?
BrunswickOH is offline Find More Posts by BrunswickOH
Old Jul 04, 2009, 04:14 PM
IBCrazy is offline
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
I'll take some of it on water and land. I run it at the dock in downtown Paducah. It always draws attention when I charge it into the river at full power. It is a bit slower on water due to the drag of the skirt, but still works well.
Old Jul 04, 2009, 08:10 PM
Brunswick, Ohio
Joined Aug 2003
Very cool
Twin motor ?s, both brushed and brushless. Zeroaltitude Power Systems 4 Mar 13, 2005 07:59 PM
Canon & Optio-s Mounted On Twin Motor Ss BAR-STOOL Aerial Photography 16 Mar 08, 2004 03:40 PM
Yippee! T6XA Super: Twin motor, throttle-rudder mix (here's how it's done) Zeuser Radios 2 Jan 22, 2003 05:29 PM
Question for LS's prop motor gb 8x270mah experts jas_Qfix Parkflyers 13 Jul 24, 2001 12:17 AM
Twin motor wiring - which is best? Slope Nut Power Systems 7 Apr 25, 2001 10:18 AM
