Old Aug 21, 2008, 11:53 AM
airmcn_3 is offline
Find More Posts by airmcn_3
Moore, Oklahoma
Foam works foam cutting software issue
I am looking for somebody who may be able to help me with a Foam works CNC software issue. I have drawn my airfoils in ACAD and have made them a polyline, I transfer the dxf over to CadWorks and it shows the drawing just fine, I can get it to generate a sequential dat file and then I save it into foamworks. When I try to open the file in foamworks I receive a error code stating. ( Error encountered, Error Number 11, Division by zero Module 14, GCF.)
Has anybody ran into this issue? Can you help?
Thank you,
Chris
airmcn_3 is offline Find More Posts by airmcn_3
Old Aug 21, 2008, 08:59 PM
wzg_zxl is offline
Find More Posts by wzg_zxl
wzg_zxl's Avatar
Beijing
Joined Sep 2007
you would explode the polyline before saveas the dat file.
my step in cadwork
1."explode" the polyline, (edit menu)
2.set the start line (cnc tools menu)
3.recognize the line (cnc tools menu)
4.(i forget) (cnc tools menu)
5.save dat file (file menu)
you get dat file first,then run foamworks , you could do follow step
1.click "parameters" then input your parameters after inputing ,click "setpup complete"
2.click generate cut file ,input your parameters,after inputing click "generate",it will caculate the date you input,at last click "done".
3.click "start cut",you will see your wing drawing.
hope it could help you
wzg_zxl is offline Find More Posts by wzg_zxl
Old Aug 23, 2008, 01:12 PM
airmcn_3 is offline
Moore, Oklahoma
my step in cadwork
Man, Thank you! You know whats weird, I can get the file to cut just fine with a polyline.
I will try your way, thank you again for the response.
Chris
Old Aug 25, 2008, 08:23 PM
Kevin Matney is offline
Find More Posts by Kevin Matney
Kevin Matney's Avatar
United States, MI, Erie
Joined Mar 2000
Just try GMFC PRO
http://www.gmfcsoft.com/ . I use this all the time.
http://matneymodels.com/wingcut.html
Kevin Matney is offline Find More Posts by Kevin Matney
Old Aug 26, 2008, 10:42 AM
airmcn_3 is offline
Moore, Oklahoma
Originally Posted by Kevin Matney
Just try GMFC PRO
Very nice job. I am running into a little problem because I have a highly swept wing I am trying to cut. It has a 17deg TE and a 55deg LE on top of that its only 13" wide.
I will keep trying, thanks for the link.
Chris
Old Aug 29, 2008, 10:02 AM
airmcn_3 is offline
Moore, Oklahoma
Anybody happen to know why I keep receiving a "error number 9 script out of range"? This is a regular message I receive when I am trying to generate a dat file in Cadworks from a random drawing.
I am having no problems with airfoils just abstract shapes.
Chris
Discussion Foam cutting software comparison and tutorials bgriggs CAD/CAM 410 Oct 24, 2015 02:24 PM
Link Links to foam cutting software for CNC wing cutter sloper steve CAD/CAM 38 Mar 20, 2014 02:01 PM
DXF2DAT 3.0 Professional Released (cnc foam cutting software) djmrozinski Electric Plane Talk 2 Feb 17, 2008 04:24 AM
Discussion Foam cutting software and tutorials bgriggs Foamies (Kits) 0 Mar 01, 2006 07:44 AM
foam cutting software Dinah Power Systems 0 Mar 19, 2002 10:08 PM
