Old Nov 02, 2012, 07:40 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
I agree with Dave .. this is how I read it between the lines, too.
flyandi is offline Find More Posts by flyandi
Old Nov 02, 2012, 09:18 PM
branflakes is offline
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
Each time a discussion veered into aerial observation I mention google earth and then we get into the difference of vid/still pics...there is no way what we do is illegal and google earth won't be, prediction.
branflakes is offline Find More Posts by branflakes
Old Nov 03, 2012, 11:43 AM
jasmine2501 is offline
Find More Posts by jasmine2501
Rocket Programmer
jasmine2501's Avatar
United States, AZ, Mesa
Joined Jul 2007
Originally Posted by gundamnitpete View Post
I think his main point, is the AMA is branching out of "model airplane guidelines".
Something used for covert photography is by it's very nature outside the "model airplane" definition, as it's purpose for flying isn't solely recreation.
So, why is the AMA commenting on privacy issues that only effect aircraft whose definition does not meet "model aircraft"?
I think that was his point, not that we should all be flying into our neighboors backyards, lol.
They are just drawing a line in the sand. And covering their butts...
The AMA rules have a hidden purpose that has always been there, and that's to define what qualifies as model aviation. If you aren't following the AMA Safety Code, you aren't doing model aviation, you're doing something else, and they want no part of it. It makes sense that they don't want to be associated with "real" FPV because it does entail some uncontrollable liability, and the AMA likes clearly defined liability.
I did try to tell them what I thought, but their web site is broken. Will have to find an email address to hit up.
jasmine2501 is offline Find More Posts by jasmine2501
Old Nov 03, 2012, 12:10 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
It isn't very well hidden as the rules have been posted forever. Most all organizations have rules and they need not be followed unless you want to stay in the organization but you can continue doing whatever you wish on your own.
In the near future FPV will be regulated and the only question is which rules and who will administrate. It could either be FAA or AMA but either way flight beyond VLOS will not be allowed. The choice between FAA and AMA is an easy one if you are familiar with FAR's. We barely slipped by the full sUAV regulations because AMA let us in with Rule 550. You may consider that a good thing or a bad thing but for sure you would not have liked the alternative.
Gary Evans is offline Find More Posts by Gary Evans
Old Nov 03, 2012, 12:22 PM
Rocket Programmer
Joined Jul 2007
The AMA Safety Code defining what is model aviation and what is not, is a hidden purpose. The rules are normally read as safety rules, but they also constitute a definition of what AMA will touch and what they won't. That's less than obvious I think.
Old Nov 03, 2012, 01:09 PM
Mesa, Arizona
Joined Nov 2006
The last plan discussed between FAA and AMA was that AMA would submit their proposed rules for FAA approval and after approval AMA would administrate. That is subject to change but under that plan the AMA rules would have to very specifically define what is an amateur model and what is not. What is not would fall under the full sUAV regs. Calling them safety rules, rules or commandments doesn't change anything.
Old Nov 03, 2012, 04:24 PM
branflakes's Avatar
Joined Jan 2011
Its patently amazing to me a 55lb large scale flyer will be considered a model, or a 200 mph jet, but a30 gm parkzone vapor with a cam will not.
This is insane btw.
Blos with a vapor is two blocks. I know its not your fault Gary but i just want to shake someone about the shoulders and scream wth at them.
Old Nov 03, 2012, 04:37 PM
Mesa, Arizona
Joined Nov 2006
This is insane btw.
I hear you but your singing to the choir. If we only flew vapors maybe it would have gone differantly. Look at the good side with the vapor you don't need long range RC gear to fly beyond VLOS.
Old Nov 03, 2012, 04:52 PM
branflakes's Avatar
Joined Jan 2011
yeppers
Old Nov 03, 2012, 05:02 PM
David22 is offline
Find More Posts by David22
North vancouver, B.C. Canada
Joined Apr 2008
Gary do ever feel like you make mistake flying with UHF system that is not legal in USA
How does this work with your feelings on how safety codes and such should be?
What is your opinion on guys who do fpv that is illegal such as fly with video tx that has not stamp or sticker?
You seem like smart guy but i read on rc groups you use UHF system that is not legal in USA
Also you fly with video tx for fpv that has no proper stickers
You also fly far away further I suggest than USA allows for fpv
What is your opinion on this info about you
Why you break laws with illegal fpv stuff but try to post in safety threads?
Don't take this as threat but rather information to others
Hopefully no one has a problem me asking you questions about what you do with fpv and actual legalities you do with fpv
You smart guy and can respond with intelligent response
No need for for reporting me for saying you hypocrite as you smart and have great answer for me
I wait for your answer and not provoke why you fly illegal fpv equipment in your planes but say they are not
You see I am expert and try to,tell you that people make mistake and in effect do make infractions without knowing it
You know it I think
Please explain to me how you as example fly fpv with illegal stuff in USA and still post,like topic in this thread
I am curious
David22 is offline Find More Posts by David22
Old Nov 03, 2012, 05:15 PM
flyandi is offline
Joined Aug 2009
I may correct you there. All the UHF systems are legal in the US - but it depends how you use them in the US. UHF requires a Amateur Radio License and with a certain level, you may even add boosters, etc. All legit. I don't know how you guys handle that in Canada.
All Transmitters and Receivers sold in the US have FCC stickers and are most of the time already restricted - so I don't know where you get your information from, but sources would help.
There is no Law that regulates FPV - not right now and not in the near future. There are no restrictions on distance what so ever.
So overall, you calling somebody out with no facts and 100% misinformation. What are you trying to do?
Old Nov 03, 2012, 05:22 PM
branflakes's Avatar
Joined Jan 2011
Also, our vtx do not have stickers, which is why we need a license i call wrong on both of ya. I'm sure I'm wrong somewhere too
Uhf is legal but not past one watt output. Markings are required on the radio/handheld for the rc control if using a non part 15 compliant and either osd xmission or plane-marked callsign -the camera can see at least every 1o mins- cover the vtx side.
Old Nov 03, 2012, 05:30 PM
David22 is offline
Joined Apr 2008
Actually in Canada we can use 4 watts legal UHF
If we have proper licence
But UHF system and video tx as example need stickers or you have to be advanced or special guys or very smart to,use and make home made stuff
I ask Gary Evans about this and why he use illegal stuff as this is his thread
I am interested in his response as he should have answer
Old Nov 03, 2012, 05:35 PM View Post
David22
A moderator felt this post violated the following rule: Personal Attack. Show it to me anyway.
gundamnitpete is offline
Find More Posts by gundamnitpete
Team White Llama!
gundamnitpete's Avatar
United States, TX, Houston
It's not illegal. There's your answer.
gundamnitpete is offline Find More Posts by gundamnitpete
Discussion Petition the FAA to revise the restrictive laws placed on model aircraft! Decroxx Model Aircraft & Drone Advocacy 18 Apr 03, 2015 04:38 PM
Discussion New Forum Suggestion - Model Aircraft Regulations mjgravina New Forum Requests 0 Feb 04, 2015 07:10 PM
Alert New FAA TFR prohibits model aircraft/RPAS flight within 3nm of large sporting events Ronan87 Multirotor Talk 8 Nov 05, 2014 01:46 AM
Discussion Deadline to have your say in FAA guidlines for Model aircraft is today Sept 23 bravetiger73 Multirotor Talk 0 Sep 23, 2014 08:18 PM
Discussion The AMA / FAA model aircraft and sUAS regulation struggle continues in the USA RolandS888 UAV - Unmanned Aerial Vehicles 49 Mar 02, 2011 10:29 AM
