Old Jan 08, 2010, 05:02 PM
Dennis H. is offline
Find More Posts by Dennis H.
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
I haven't seen the word {recommendation} in AC 91-57 But the word Compliance.
Dictionary.com
1. the act of conforming, acquiescing, or yielding.
2. a tendency to yield readily to others, esp. in a weak and subservient way.
3. conformity; accordance: in compliance with orders.
4. cooperation or obedience: Compliance with the law is expected of all.
So how are you going to give the right of way to full scale planes coming in from the sides or rear, If your flying beyond VLOS?
To fly beyond VLOS, you'll have to fly above the 400ft mark, To have control of the plane and video equipment.
But who here in the US has talk with anyone from the FAA about AC 91-57?
Is it a law or just recommendation?
And if its not a law, why did the FAA even write anything about RC flying?
The AMA already cover RC flying.
Dennis H. is offline Find More Posts by Dennis H.
Old Jan 08, 2010, 05:19 PM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
The current FAA policy for UAS operations is that no person may
operate a UAS in the National Airspace System without specific
authority. For UAS operating as public aircraft the authority is the
COA, for UAS operating as civil aircraft the authority is special
airworthiness certificates, and for model aircraft the authority is AC
91-57.
AC91-57 is an FAA advisory not a rule or regulation. AMA rules were written to comply with that advisory (kind of). AMA is the tail in this not the dog. AC91-57 was written way before the current state of affairs existed but worry not new regulations are on the way.
Gary Evans is offline Find More Posts by Gary Evans
Old Jan 08, 2010, 05:29 PM
Mel Duval is offline
Find More Posts by Mel Duval
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
Gary is right on the button. A read through these documents might be in order....
http://www.modelaircraft.org/news/ama-faa.aspx
Mel Duval is offline Find More Posts by Mel Duval
Old Jan 11, 2010, 02:41 PM
billpa is offline
Find More Posts by billpa
billpa's Avatar
Joined Nov 2003
Hello!
I've been marginally following this thread and the proposed FAA regulations, in a half-asleep fashion. Applause to the few folks who are really paying attention to this!
After re-reading the FAA committee proposed rules (link below), I have a few questions/comments:
a) There are a few posts here that suggest model aircraft (FPV or otherwise) would not be legal to fly outside of AMA fields. But, the proposed rules do not seem state such a limitation? As I read the proposal, the AMA (and/or other model airplane community organizations) would be relied upon to set the guidelines for operation. In section 2, the proposed rules do state that the community organizations would be relied upon to establish guidelines for dedicated flying sites (2.2.8), but I see nothing in section 2 suggesting that model flying outside dedicated flying sites (as long as the requirements of section 3 are not violated) would be illegal. The guidelines of a community based organization certainly do not have the force of law, and regardless I doubt that the AMA would adopt guidelines that prohibit modeling activity on private property. Comments?
b) Section 3 does indeed impose some stringent limitations for model flying. I believe that only section 3 will have the force of law with respect to model airplane operation? The hard 400' limit in section 3.3.5 seems to me to be the one to be most concerned about? It's good to see that the AMA, and probably the other hobby folks on the committee, are opposed to it.
c) Regarding the VLOS rule in section 3.2.5, as written this seems somewhat ambiguous. The "Pilot in Command" (PIC) is rigorously defined in the document as the person holding the radio. But, section 3.2.5 refers to the "pilot" rather than the PIC, whereas the rest of the document refers to the PIC. Perhaps those in our hobby, during the comment period (see below) should push to clarify this rule to allow a shared responsibility between the PIC and the spotter to maintain VLOS, just as the document requires "the PIC and/or qualified visual observer" to be within VLOS contact, in the non-hobby sections of the rule?
I also have a general comment/question: I assume that, once the FAA makes an initial decision on the various points of contention in the proposal, a proposed final rule will be published, with a comment period. If so, and the proposed rules are counter to common sense and to enjoyment of our hobby, individually contacting your US representative would be a good idea. Politicians respond to issues that involve significant numbers of voters. Maybe it would be best if the proposed rule is published in an even numbered year, when US representatives are most sensitive to voter concerns.
Here's the document that I'm referring to above:
http://www.faa.gov/about/office_org/...S_ARC_Recs.pdf
Regards,
Bill, for Eagle Tree
billpa is offline Find More Posts by billpa
Site Sponsor
Old Jan 11, 2010, 03:35 PM
Mesa, Arizona
Joined Nov 2006
Welcome to the thread Bill!
Originally Posted by billpa View Post
Hello!
What has been recommended is that AMA would be given the authority to write rules for amateur model airplanes but it doesn't limit flying to AMA fields. That and the AMA's current FPV rules are obviously subject to change.
Pilot and PIC are interchangeable terms to me. AMA's rule #550 defines the requirements if it follows their rules.
http://tinyurl.com/cu6zx7
Regards,
Old Jan 12, 2010, 12:10 AM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
I just don't see the ambiguity in 3.2.5 that you do Bill.
To me that rule flat out disallows non-visual operation of a model aircraft anywhere in the wild.
We've seen that very same language used before in the AMA code itself (rule 9) and
until the FPV exemption was specifically added (and referenced in the updated rule 9),
that language prevented FPV operations entirely.
The absence of a similar rule in section 2 is now what makes FPV possible in
AMA (or other recognized community organization) controlled airspace, as long
as there is an FPV exemption.
ian
Daemon is online now Find More Posts by Daemon
Old Feb 05, 2010, 12:16 PM
misfire is offline
Find More Posts by misfire
Joined Aug 2007
Is anything happening w/this?
I've looked briefly at the "Set of Recommendations for Regulatory Development". Could someone kindly point me to a schedule of proceedings, or any other information as to the status of regulations or of the "Development" process?
I'd be all about getting involved in this and helping out the good guys, if that would be a possibility. I am a retired lawyer, 20 yrs. in private practice, worked on regulatory/legislative stuff (not F.A.A), licensed private pilot since 1979, last 10 yrs. operating private outdoor recreation area. I always prefer to fight for the cause of Liberty wherever possible.
If there's a point person or somebody I should talk to, please drop me a PM and point me in the right direction. Thanks!
Stu
misfire is offline Find More Posts by misfire
Old Feb 05, 2010, 12:38 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
I don't know, But my guess would be contact the AMA?
Old Feb 05, 2010, 01:44 PM
Mesa, Arizona
Joined Nov 2006
The process is now in the hands of FAA who are developing proposed rules that when complete would be published for comment.
I don't know exactly who to contact for more information as to procedings but you could start with one of the people listed as contacts on this information release.
http://tinyurl.com/yct3q4u
Old Mar 04, 2010, 12:56 PM
Mesa, Arizona
Joined Nov 2006
AMA is anticipating that the new FAA proposed sUAV regulations will be published for comment in the second quarter of 2010 with rules being implemented in 2011.
http://tinyurl.com/yeaxn67
This is the latest from AMA's President Dave Mathewson on the subject. Clearly they are trying to back away from any association with sUAV's. He also explains that the final AMA rules for submission to FAA are not finalized.
http://tinyurl.com/y8hj7er
Old Mar 04, 2010, 01:44 PM
Dennis H.'s Avatar
Denton Tx.
Joined Sep 2003
Well I don't think the FAA would get involved but look now, At all the video now Posted all over the net,Way above the set 400ft level that the FAA has set as the max Alt. that a model can fly.AMA post that no model to be flown beyond visual range. They fly with no regard to the safety of full scale aircraft etc.. Its been posted here on RCG and other RC forum,People have said, I don't care, At how high or how far.
So IF the FAA past some type of law that hurts RC flyer, You can blame the I don't care people.
Old Mar 08, 2010, 02:43 AM
man2000me is offline
Find More Posts by man2000me
Mums the word.
man2000me's Avatar
St.Augustine, FL
Joined Sep 2009
I'm not starting anything... But what is the difference of a non-fpv glider thermaling above 400ft and a FPV glider thermaling above 400ft?
man2000me is offline Find More Posts by man2000me
Old Mar 12, 2010, 03:21 PM
g00bd0g is offline
Find More Posts by g00bd0g
g00bd0g's Avatar
USA, CA, Watsonville
Joined Jul 2001
Arguably the ability to better perceive other aircraft (or other dangers) in the vicinity. Arguably
g00bd0g is offline Find More Posts by g00bd0g
Old Jul 06, 2010, 05:50 PM
outngo is offline
Find More Posts by outngo
E-Gliders
outngo's Avatar
South Carolina
Joined May 2009
91-57.
ama is always the tail in everything they do.. remember that.
outngo is offline Find More Posts by outngo
Old Jul 14, 2010, 09:09 AM
charlie2020 is offline
Find More Posts by charlie2020
Taipei Sung Shan, Taiwan
Joined Feb 2004
I am wondering if the Autopilot would be more helpful than the bodybox or spoter. When the RC or AV radio signal is lost the bodybox will not help from crash the model. When flying further away like half miles very few people can really see the airplane model.
Feed back are welcome!
charlie2020 is offline Find More Posts by charlie2020
Discussion Petition the FAA to revise the restrictive laws placed on model aircraft! Decroxx Model Aircraft & Drone Advocacy 18 Apr 03, 2015 03:38 PM
Discussion New Forum Suggestion - Model Aircraft Regulations mjgravina New Forum Requests 0 Feb 04, 2015 06:10 PM
Alert New FAA TFR prohibits model aircraft/RPAS flight within 3nm of large sporting events Ronan87 Multirotor Talk 8 Nov 05, 2014 12:46 AM
Discussion Deadline to have your say in FAA guidlines for Model aircraft is today Sept 23 bravetiger73 Multirotor Talk 0 Sep 23, 2014 07:18 PM
Discussion The AMA / FAA model aircraft and sUAS regulation struggle continues in the USA RolandS888 UAV - Unmanned Aerial Vehicles 49 Mar 02, 2011 09:29 AM
