Old May 28, 2012, 10:07 PM
vangvace is offline
Find More Posts by vangvace
vangvace's Avatar
Greece, Kriti, Khania
Joined Feb 2012
http://www.dcma.mil/communicator/win..._pp36-pp37.pdf
vangvace is offline Find More Posts by vangvace
Old May 29, 2012, 05:54 AM
pathloss is offline
Find More Posts by pathloss
Joined Dec 2011
Can you explain your position? Perhaps I am missing something.
pathloss is offline Find More Posts by pathloss
Old May 29, 2012, 06:06 AM
pathloss is offline
Joined Dec 2011
Originally Posted by scrtsqrl View Post
With respects, what you are missing is that whilst flying IFR, you are under the control of an air traffic controller who is responsible for your airspace. That's how you can fly single piloted in IMC. Indeed FPV gives you a better idea of what your plane is doing. However, it is not as effective at maintaining situational awareness around it. This is why you need a spotter...to clear you of other aircraft. Even head on, you are more likely to see FS plane at 5 miles than you are to see a FS plane at 1 through your plane's video.
If you can see a plane at five miles, it must be a B747. No one said flying of any kind is without risk, so the question becomes what is reasonable for a toy airplane. Sounds like you have done some GA flying perhaps. Ever have a plane come close to you in the air? I have, even with radar service from either ARTCC or ASR. The best of efforts available do not eliminate risk. Now I ask you to compare this with a foam toy bobbing along at 200 to 300 FT that weighs a few pounds. Still think you need two "official" AMA dues paying pilots to guide this menace to society? Really....?
Old May 29, 2012, 06:41 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
When defending FPV safety the argument seems to always be how could a little foam plane drifting around at a couple of hundred feet be of any risk. When I hear this story I am reminded of a fairytale with pretty harmless butterflies floating aimlessly along. Itís such a beautiful story but it must make a lot of pilots feel alienated since it doesn't really describe their plane or how they fly. Perhaps it could pass the sniff test for the masses if there were not message boards like this one with tons of posts and videos about long range high altitude flights with relatively high speed planes weighing closer to 10 lbs or multi-rotors with enough blades and power to slice beef for Carl Junior just waiting for the gift of a hand or face.
Guys this one isn't going to get past first base anymore with the authorities but if you think otherwise knock yourself out or maybe instead push for only allowing little foam planes with windup rubber band power.
Gary Evans is offline Find More Posts by Gary Evans
Old May 29, 2012, 07:37 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Who, and which position?
CNY_Dave is offline Find More Posts by CNY_Dave
Old May 29, 2012, 07:44 AM
CNY_Dave is offline
Joined Sep 2010
Originally Posted by vangvace View Post
I suspect that's a doppler radar, which presents some problems for airborne use.
Now, if you are suggesting personal GBSAA systems for FPV fliers (or one for the club) that's another thing...
Old May 29, 2012, 08:49 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
You have just made my point.
And, yes, I know the risks associated with flight. It's my living.
It is easy to do risk management if you're safely on the ground.
I assure you a piece of metal as small as blue wonder motor will take down turbine engines. It wouldn't be cool to run into one of these whilst I'm flying a low level route at high speed.
To be clear, I never said you need 2 AMA members to fly FPV...All you need is a spotter...buddy box optional.
Mind your tone. Forgo the drama. We will get no where this way.
Thanks.
scrtsqrl is offline Find More Posts by scrtsqrl
Old May 29, 2012, 09:59 AM
nakelp86 is offline
Find More Posts by nakelp86
Nakelp
nakelp86's Avatar
United States, NJ, Union
Joined Sep 2004
Spotter is very helpful regardless where and how you fly FPV but not the buddy box.
This is why I dont like to fly alone, anytime I hear big guy flying I just dive to 100-150 feet.
If I fly alone I make sure there is no air traffic at least in couple miles area.
I recal one instance last year where I was flying at the shore and there was this guy flying full size not higher than 50 feet at the edge of the water and beach. Was he cracking safety rules? I think well kicked beach ball could have take him down.
nakelp86 is offline Find More Posts by nakelp86
Old May 29, 2012, 01:20 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
I think it would be very helpful if this community adopted safety standards akin to the AMA's and really pushed FPV pilots hard to follow those standards.
And it should really come down hard on people who do not follow those standards... rhetorically if nothing else.
It seems to me the FAA and AMA are willing to listen to organized modelers who can present rational compliance with guidelines.
So my question is, what should those guidelines be that this group would agree to?
For me there are a couple very simple ones:
1) Do not fly over 400' AGL because doings so risks encountering Full Scale aircraft in operation.
2) Do not fly over populated areas.
Given that frankly even these simple things seem to be "up for debate" leaves me little hope we will get model-level waivers.
I personally would add a VLOS rule which pretty much removes flying greater than about 1-2 mile. And a required spotter. This to ensure no dangerous situation arises outside the very limited view of the model's video feed.
I think something like that would have a chance to be included in a model waiver.
As it is, I'm very skeptical.
Darren Hintze is offline Find More Posts by Darren Hintze
Old May 29, 2012, 01:27 PM
Mesa, Arizona
Joined Nov 2006
Look at the first post in this thread but note that pushing FPV pilots is like herding cats.
Old May 29, 2012, 01:30 PM
NorCalMatCat is offline
Find More Posts by NorCalMatCat
FPV Electronics For Life!
NorCalMatCat's Avatar
United States, CA, Arcata
Joined Oct 2011
That's what the AMA rules are NOW for FPV, 400 feet AGL is not very high, and I like doing longer range, though I doubt anyone is going to see a model beyond a few hundred meters unless it is super large.
I do not believe 400' AGL or VLOS is really adding much to the safety factor at all. I understand 400' if you are close to an airport with a lot of approach / take off planes at low altitude, but somewhere like I am where there might only ever be 10 planes that fly over in a single day, and it's mostly rural area.
NorCalMatCat is offline Find More Posts by NorCalMatCat
Old May 29, 2012, 01:55 PM
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Actually, AMA rules do *not* restrict model aircraft to 400ft AGL, except within 3 miles of an airport.
A typical 3+ meter sailplane comes off the winch at over 500 ft, and then soars much higher.
That happens at AMA fields and events all over the country all the time.
A high visibility coloring scheme on a plane like the Skywalker makes it visible at ranges
well over a mile.
ian
Daemon is offline Find More Posts by Daemon
Old May 29, 2012, 02:00 PM
branflakes is offline
Find More Posts by branflakes
branflakes's Avatar
Joined Jan 2011
I also debate the populated areas issue. Park flying breaks this rule, so it should be adjusted to say flying the perimeter of populated areas is acceptable. If I add a camera to a slow stick its still a park flyer, cam doesn't make it more dangerous.
branflakes is offline Find More Posts by branflakes
Old May 29, 2012, 02:01 PM
thekubiaks is offline
Find More Posts by thekubiaks
Joined Aug 2010
I'm kind of surprised that the FPV equipment manufacturers aren't trying to organize some kind of "resistance" to the new regulations we know are coming. This will cripple their business.
thekubiaks is offline Find More Posts by thekubiaks
Old May 29, 2012, 02:45 PM
Joined Oct 2011
I fly FPV on the south perimeter of my town, granted I don't go over the town, but I do scoot along the edge of it.
Discussion Petition the FAA to revise the restrictive laws placed on model aircraft! Decroxx Model Aircraft & Drone Advocacy 18 Apr 03, 2015 03:38 PM
Discussion New Forum Suggestion - Model Aircraft Regulations mjgravina New Forum Requests 0 Feb 04, 2015 06:10 PM
Alert New FAA TFR prohibits model aircraft/RPAS flight within 3nm of large sporting events Ronan87 Multirotor Talk 8 Nov 05, 2014 12:46 AM
Discussion Deadline to have your say in FAA guidlines for Model aircraft is today Sept 23 bravetiger73 Multirotor Talk 0 Sep 23, 2014 07:18 PM
Discussion The AMA / FAA model aircraft and sUAS regulation struggle continues in the USA RolandS888 UAV - Unmanned Aerial Vehicles 49 Mar 02, 2011 09:29 AM
