Old Jun 06, 2011, 08:51 PM
EarthOrbiter is offline
Find More Posts by EarthOrbiter
Fly Chitty Chitty Bang Bang!
EarthOrbiter's Avatar
Central California USA
Joined Feb 2011
I only can imagine FPV NOTAMS coming in my mail in the possible future.
EarthOrbiter is offline Find More Posts by EarthOrbiter
Old Jun 07, 2011, 10:59 PM
Balsabird is offline
Find More Posts by Balsabird
Balsadustus Producerus
Escondido, CA USA
Joined Jan 2001
Nah, they'll be air-dropped from a BLOS instead of mailed
Balsabird is offline Find More Posts by Balsabird
Old Jul 08, 2011, 10:49 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Just kidding.
Blueshy is offline Find More Posts by Blueshy
Old Jul 08, 2011, 11:18 PM
prelator is offline
Find More Posts by prelator
FPV Browncoat
prelator's Avatar
United States, CO, Parker
Joined Mar 2011
Hmm, that document is from 2 years ago, so it may not be current. I don't think I've seen the whole document before, but parts of it look familiar. Did we already have this document or has it just recently been released?
prelator is offline Find More Posts by prelator
Old Jul 08, 2011, 11:30 PM
Blueshy is offline
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Oh good god, how did I miss that? The date is printed on every page... *facepalm*
When I read it for some reason it looked current...
Old Jul 15, 2011, 06:58 AM
misfire is offline
Find More Posts by misfire
Joined Aug 2007
What are the best links for checking on the current status of these guidelines at the AMA level and the proposed FAA regs? The FAA website is pretty good as far as the existing situation (FAA requirements for flying a "real UAV" as a private person are basically "fugeddabowdit"; advisory guidelines for FPV "modelers" are "playpen required". Just kidding.) but I can't find much about the rulemaking process and proposed regs?? I haven't looked at the AMA site lately, I guess I should.
It's always bothered me a bit how the FAA is letting the AMA take such a lead role in sanctioning modeler FPV ops. It's like, the AMA is spose to represent us. It seems like a conflict.
misfire is offline Find More Posts by misfire
Old Jul 15, 2011, 07:28 AM
Gary Evans is offline
Find More Posts by Gary Evans
FPV Desert Beta Test Center
Mesa, Arizona
Joined Nov 2006
This AMA Government Relations tab is your best bet for following all of the detail. When anything important happens I'll post it here.
http://www.modelaircraft.org/
I assume FAA would rather have AMA deal with day to day issues.
Gary Evans is offline Find More Posts by Gary Evans
Old Aug 19, 2011, 08:54 AM
scrtsqrl is offline
Find More Posts by scrtsqrl
Just trying to get a nut.
scrtsqrl's Avatar
United States, VA, McLean
Joined Oct 2006
Interesting article.
"In reality, neither a manned or unmanned aircraft can sense and avoid a collision from behind in the absence of a cue from ground-based radar or other offboard warning systems."
scrtsqrl is offline Find More Posts by scrtsqrl
Old Aug 19, 2011, 09:23 AM
Mesa, Arizona
Joined Nov 2006
Very true. You can't see what is out of view. In the sailplane flight due to the extremely small cross section of other gliders you spend a lot of time looking from side to side which increases your field of view to maybe 250 degrees. Even that is little protection when closing speed may be 200 mph. The most recent sailplane development (POWERFLARM) is a portable on-board warning system that each plane would carry. This is primarly intended for contests where a lot of gliders are in a relatively small area.
Old Aug 19, 2011, 09:25 AM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Overtake is going to be a huge deal with UAs, they are often flying in airspace with much faster traffic. My work has involved a bunch of sims predicting just this...
Now imagine that with a pred b and occurring at FL180.
U-G-L-I- UGLI!
The sense-and-avoid systems must do quite a bit better than looking forwards.
Also notable the C130 crew never saw it- too small, too slow, and a low-observable paint scheme. See-and-avoid will reliably fail for the manned craft going up against a small UA.
Dave
CNY_Dave is offline Find More Posts by CNY_Dave
Old Aug 19, 2011, 09:50 AM
patrickegan is offline
Find More Posts by patrickegan
SlowStick Test Pilot
patrickegan's Avatar
Yumastan RCAPA.NET
Joined Feb 2003
Not buying...
"The Shadow was in a holding pattern 4,500 ft. off the end of the runway, where it had been directed by air traffic control, when the C-130 “flew right through,” Owings says. “The manned aircraft did not do what it was procedurally supposed to, nor were they where they thought they were,” Sova says." (From Aviation Week)
If you can see a T33 out at 10 miles closing at 500 knots these guys should have seen the RQ 7
http://rgl.faa.gov/Regulatory_and_Guidance_Library/rgAdvisoryCircular.nsf/0/7373cdbc7158f4c286256a03006e1551/$FILE/AC90-48c.pdf
patrickegan is offline Find More Posts by patrickegan
Old Aug 19, 2011, 10:12 AM
CNY_Dave is offline
Joined Sep 2010
The largest dimension of the shadow is much much smaller than the smallest feature on a T33.
If you do the math on 20/20 visual acuity and the required subtended angle, the height and width of the fuse as seen from the rear, and the thickness of the wings, I think you will be somewhat surprised how close it needs to be.
For example, the length of the wing is quite meaningless until the thickness of the wing subtends an angle sufficient to be seen- until then, the wing is invisible.
It is quite possible the shadow was seen against terrain, as opposed to a sky silhouette.
Dave
Old Aug 19, 2011, 10:16 AM
Mesa, Arizona
Joined Nov 2006
Your eye can detect movement much better than a stationary object. Depending on direction and attitude another aircraft can appear stationary and if below the horizon it is even harder to detect unless you know right where to look. Detection can be much harder than you would think.
Old Aug 19, 2011, 02:04 PM
Yumastan RCAPA.NET
Joined Feb 2003
Early reports are saying they came up on the shadow...
Old Aug 19, 2011, 03:10 PM
Mesa, Arizona
Joined Nov 2006
How you doing Patrick? Still in Yumastan?
Discussion Petition the FAA to revise the restrictive laws placed on model aircraft! Decroxx Model Aircraft & Drone Advocacy 18 Apr 03, 2015 03:38 PM
Discussion New Forum Suggestion - Model Aircraft Regulations mjgravina New Forum Requests 0 Feb 04, 2015 06:10 PM
Alert New FAA TFR prohibits model aircraft/RPAS flight within 3nm of large sporting events Ronan87 Multirotor Talk 8 Nov 05, 2014 12:46 AM
Discussion Deadline to have your say in FAA guidlines for Model aircraft is today Sept 23 bravetiger73 Multirotor Talk 0 Sep 23, 2014 07:18 PM
Discussion The AMA / FAA model aircraft and sUAS regulation struggle continues in the USA RolandS888 UAV - Unmanned Aerial Vehicles 49 Mar 02, 2011 09:29 AM
