Old Feb 12, 2013, 02:51 PM
Blueshy is offline
Find More Posts by Blueshy
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
Originally Posted by Gary Mortimer View Post
I think the most interesting thing about that document, besides them apparently
giving up on hobbyists and saying to use AC91-57, is the definitions at the end.
Visual Line-of-Sight:
Unaided (corrective lenses and/or sunglasses exempted) visual contact between a PIC or a VO and a UAS sufficient to maintain safe operational control of the aircraft, know its location, and be able to scan the airspace in which it is operating to see and avoid other air traffic or objects aloft or on the ground.
Populated or Urban Areas:
Areas depicted in yellow on a Visual Flight Rules (VFR) sectional chart or as determined from other sources.
Observer: A trained person who assists a UAS pilot in the duties associated with collision avoidance and navigational awareness through electronic or visual means. (Collision avoidance includes, but is not limited to, avoidance of other traffic, clouds, obstructions, terrain and navigational awareness.) A visual observer (VO) is a trained person who assists the UAS pilot by visual means in the duties associated with collision avoidance. A VO includes the OPA pilot when the OPA is being operated as a UAS.
Daisy-Chaining: Aviation jargon for the use of multiple, successive observers to extend the flight of a UA beyond the direct visual line-of-sight of any other PIC or VO.
The last one in particular. The rest are just finally definitions the FAA has
come up with for some terms we have been arguing about.
-Blues
Blueshy is offline Find More Posts by Blueshy
Old Feb 12, 2013, 02:59 PM
prelator is offline
Find More Posts by prelator
FPV Browncoat
prelator's Avatar
United States, CO, Parker
Joined Mar 2011
Very interesting.
Key takeaways:
1. Amateur model aircraft are excluded from this policy, so we don't need to worry about it directly. Of importance is the fact that modeling is defined only as "operating unmanned systems for sport and recreation." The only factor is the purpose of use, not specific flight parameters such as remaining within visual line of sight. So the FAA has still not adopted the congressional definition of model aircraft which includes the visual line of sight component. This means that as long as you're flying for recreational purposes, you can still fly beyond VLOS without going outside the definition of model aircraft.
2. We have a new definition of VLOS:
Visual Line-of-Sight. Unaided (corrective lenses and/or sunglasses exempted) visual contact between a PIC or a VO and a UAS sufficient to maintain safe operational control of the aircraft, know its location, and be able to scan the airspace in which it is operating to see and avoid other air traffic or objects aloft or on the ground.
Looks like the AMA and FAA definitions of VLOS are now in sync. Elsewhere in the document though they limit VLOS operation to 1/2 mile when conducted by someone without a pilot's license.
3. While they list several "sense and avoid" methods that are not acceptable for see and avoid by themselves, I wonder how receptive they would be to a combination of multiple things, such as pan and tilt cameras plus a visual observer watching the airspace around the aircraft but not the aircraft itself, staying under 400 feet in unpopulated areas in class G airspace. Something worth thinking about.
prelator is offline Find More Posts by prelator
Daemon is offline
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Note there's still no obvious provision for commercial operation. Civil operations
seem to only cover R&D, crew training..etc.
And check out the PIC certification requirements if you ever choose to not operate
under the amateur exemption. Need a pilots license unless you
fly only daytime/under 1/2 mile/under 400ft.. period (I fly regular
RC sailplanes further than that), and even the non-pilot's license requirements
are pretty nutty.
There's a lot of wiggle room (possible exemptions as the technology matures) but
some of the core stuff is pretty silly.
ian
Daemon is offline Find More Posts by Daemon
Old Feb 12, 2013, 03:50 PM
CNY_Dave is offline
Find More Posts by CNY_Dave
DX5e fatal flaw- PM me!!!!
United States, NY, Cortland
Joined Sep 2010
Originally Posted by flyandi View Post
Ok - here is a scary part:
Drone Power to the Government?
I think only gov't vehicles can use due regard because only the gov't (DoD and DHS really here, NASA for it's Ikhana too) can assume the liability without some sort of insurance.
CNY_Dave is offline Find More Posts by CNY_Dave
Old Feb 12, 2013, 03:53 PM
CNY_Dave is offline
Joined Sep 2010
Originally Posted by Daemon View Post
I wasn't saying you'd rely on the transponder to sent its position. ATC radar knows its
position, transponder is only sending out altitude. ATC data is available on the internet.
Basically you'd take the same raw data that goes into the flight tracker website
and combine it with your UAV's telemetry data to warn you when they're
in the same area of the sky at close altitudes. Yes there's some gaps for certain
aircraft, and location but it's better than nothing, and gets better the higher you fly
where arguably people are the most concerned about it.
ian
Even worse than using ADS-B, I fear.
The feed the FAA puts out is delayed by 15 minutes, and only contains flights that have been issued Mode-A codes by HOST, so only IFR flights and VFR flights that are receiving services. No VFR flights, no flights without transponders, and other flights may be excluded at the owners request.
The FAA won't release the live, up-to-date, scan-by-scan feed to anyone.
In the future ADS-B in could be used, where all traffic data is sent up to aircraft capable of receiving it.
Old Feb 12, 2013, 04:16 PM
seearestacey is offline
Find More Posts by seearestacey
Keep Calm, and Carry On...
seearestacey's Avatar
United States, UT
Joined Feb 2012
Could we propose to the FAA that FPV'ers could get an FPV license? You would get a HAM radio license and an FPV license. The license would be similar to a pilots license, wherein you would have to follow certain rules. No flying next to landmarks or near airports, staying within "Class G" airspace, ect, ect....
seearestacey is offline Find More Posts by seearestacey
Old Feb 12, 2013, 04:24 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Without a complete live picture of at least your area, then what we're talking about
really just isn't possible. People keep acting like eyes are infallible in the "see and avoid"
equation, but they are really pretty dreadful for this sort of task. I think realistically
VFR pilots rely a lot more on the "big sky" principle than they'll ever admit.
ian
Old Feb 12, 2013, 05:26 PM
flyandi is offline
Find More Posts by flyandi
United States, CA, Aliso Viejo
Joined Aug 2009
unrealistic and unnecessary .. Ultralight are exempt and the only thing you need is a Driver License to fly one .. it's called Amateur Aviation for a reason!
flyandi is offline Find More Posts by flyandi
Old Feb 12, 2013, 05:27 PM
flyandi is offline
Joined Aug 2009
ian
You can buy a ADB-S receiver on eBay for $99 and see all live traffic within 150nm...
Old Feb 12, 2013, 05:32 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Only if "all live traffic" is also so equipped.
Old Feb 12, 2013, 05:39 PM
Daemon is offline
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
True ultralights don't even require a driver's license to operate. You may be thinking of new Sport Pilot class.
ian
Old Feb 13, 2013, 01:45 AM
atckirk is offline
Find More Posts by atckirk
atckirk's Avatar
United States, CA, Mission Viejo
Joined May 2001
I'm an Air Traffic Controller in Socal and am trying to get on a UAS project in a few months:
1 UAS TCRG Research Task UAS-12-01a (Determine Minimum SAA Information for Collision Avoidance)
1.1 Requirement
This event consists of a Human-in-the-Loop (HITL) simulation to research minimum sense and avoid (SAA) information for collision avoidance. The event is a pilot-centric HITL, with data collected on pilot activities. The SMEs will participate in the controller role for the HITL. Data will not be collected on the controller activities.
Hopefully I can get on this project and find out some good info!
atckirk is offline Find More Posts by atckirk
Old Feb 13, 2013, 09:15 AM
prelator is offline
FPV Browncoat
prelator's Avatar
Joined Mar 2011
Huh. You would think they would have studied that BEFORE declaring that cameras a per se inadequate to sense and avoid now wouldn't you?
Old Feb 14, 2013, 12:35 AM
leszekmp is offline
Find More Posts by leszekmp
Joined Nov 2012
are pretty nutty.
ian
I'd say there's no provision for commercial operations, period. This is strictly for government agencies applying for COAs, or those crazy enough to try for experimental certification. As I read this, even if you fly within 1/2-mile, and under 400 ft. AGL, you still need a certificate showing you've passed the private pilot's written exam.... and you need to provide airworthiness/maintenance information, regular written reports about usage ...and prove that you've done at least three takeoffs and landings within the past 90 days to prove your pilot competence. Even if you're only flying a 1 kg foam plane, or an AR Drone.
This is not a serious document. In fact, it could be interpreted as the FAA thumbing their noses at at least two sections of the 2012 FAA Reform and Reauthorization Act:
Section 333: Where the FAA was supposed to issue guidelines by August 2012 under which certain small UAS could operate before the full 2015 commercial implementation.
Section 334: Where the FAA was supposed to make it easier for public agencies to use small UAS.
leszekmp is offline Find More Posts by leszekmp
Old Feb 14, 2013, 02:18 AM
flyandi is offline
Joined Aug 2009
Yeah - but the document clearly states that Hobbyist are exempt and fall under AC91-57 .. what else do we want?
Discussion Petition the FAA to revise the restrictive laws placed on model aircraft! Decroxx Model Aircraft & Drone Advocacy 18 Apr 03, 2015 04:38 PM
Discussion New Forum Suggestion - Model Aircraft Regulations mjgravina New Forum Requests 0 Feb 04, 2015 07:10 PM
Alert New FAA TFR prohibits model aircraft/RPAS flight within 3nm of large sporting events Ronan87 Multirotor Talk 8 Nov 05, 2014 01:46 AM
Discussion Deadline to have your say in FAA guidlines for Model aircraft is today Sept 23 bravetiger73 Multirotor Talk 0 Sep 23, 2014 08:18 PM
Discussion The AMA / FAA model aircraft and sUAS regulation struggle continues in the USA RolandS888 UAV - Unmanned Aerial Vehicles 49 Mar 02, 2011 10:29 AM
