Old May 01, 2001, 11:51 PM
franz is offline
Find More Posts by franz
Downey, California
Joined May 2001
Programming JR 8103 for E powered gliders
Need help programming my JR 8103 radio for my Multiplex Kranich which is electric powered and has been modified to use flaps. One thing I would like to know is if most people put motor control onto a switch or do they use the throttle stick? Another thing is if you use the throttle stick for motor control what is the best way to program camber changing as well as butterfly by use of the three position switch? Also are there any books that help explain programming this radio for E-powered sailplanes or for sailplanes in general? Hopefully someone can help me with these things. Franz
franz is offline Find More Posts by franz
Old May 05, 2001, 12:31 AM
GTurner is offline
Find More Posts by GTurner
Joined Feb 2001
Franz,
I'm not an expert, the 8103 is my first computer radio. I bought it primarily to use with an electric glider but now rather wish I'd saved up for a more capable radio. I don't think you can have the throttle on the throttle stick and get camber, crow, etc. I ended up using the acro mode, not glider, because I wanted the throttle stick and my glider has only ailerons, no flaps. I put spoilerons on the "landing mode" switch, just
on or off. You may prefer to use the glider mode for crow and adjustable spoilers and put the motor on a switch.
Where in Downey? I used to have relatives on Donovan, just north of Imperial off Lakewood.
Gary
GTurner is offline Find More Posts by GTurner
Old May 05, 2001, 01:28 AM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
I've done a lot of head scratching trying to figure out the best way to program the 8103...surely someone must know how to program this radio effectively??? Things that have me puzzled...how to make spoilerons go up a lot without binding the linkage when aileron is input? How to get an on/off motor switch on the left side?
ScotY is offline Find More Posts by ScotY
Old May 06, 2001, 10:48 PM
Daveairway is online now
Find More Posts by Daveairway
Santa Rosa, Northern CA, USA
Joined Oct 1999
Hi Guys,
More stuff here.
http://www.ezonemag.com/disc/Forum1/HTML/006737.html
ScotY,
That is tough. You need lots of Ail travel, linkage wise. Binding with a mix can be a real problem.
Dave
Daveairway is online now Find More Posts by Daveairway
Suggestions for e-powered 100"-118" built-up floater houdini Electric Sailplanes 4 Jan 13, 2003 02:04 PM
Trade: HPI Micro RS4 and JR XR2 for E-flight stuff--TRADED SiRacer Aircraft - Electric - Airplanes (FS/W) 12 May 30, 2002 02:01 PM
Question Eclipse 7 for electric powered gliders yflint Electric Sailplanes 12 May 03, 2002 09:35 AM
