Old Aug 07, 2000, 02:47 PM
Crash King is offline
Find More Posts by Crash King
Lucas, Texas
Joined Aug 2000
Suggest an ARF 2 Meter electric
Growing tired of my Wattage Whisper, can anyone recommend a good 2-meter electric. Dymond RC has a great deal on an ARF 2 meter at 169.99 with servos and BEC. Any other suggestions??
Crash King is offline Find More Posts by Crash King
Old Aug 08, 2000, 03:14 AM
oded mazor is offline
Find More Posts by oded mazor
oded mazor's Avatar
Tel Aviv-Yafo Sde Dov, Israel
Joined Apr 1999
if i were you i would have looked at two options :
1. cermark easy 72.
2. kyosho soarus/stratus.
i heared very good reviews on both models (a few posts down someone is praising the easy 72). the advantage with the kyosho kits is that you can upgrade from the standard wing version to the aileron version by purchasing the wing only (fuselage stays the same).
there is an online review in the e-zone of the easy 72, take a look !
if you're looking for something more advanced and expensive (like german models) than try searching hobby lobby, new creations...
i am not familiar with the "whisper" so i can't compare it with the others.
good luck, oded.
oded mazor is offline Find More Posts by oded mazor
Old Aug 09, 2000, 10:44 AM
Lucas, Texas
Joined Aug 2000
Well folded the wing on my Whisper 2M today so I will be needing this a little faster than expected. Any other suggestions.
Derek
Old May 02, 2001, 11:00 AM
Boot is offline
Find More Posts by Boot
Joined Feb 2001
I realize that you've already must have purchased another sailplane, but I wanted to post a praise of the Kyosho Soarus (with modifications).
The main change that I would make is to the power train and propeller. The Graupner 2.8:1 gear reduction speed 500 (or similar) with an 11x7.5 prop works wonders. The supplied propeller is rediculously underpowered and a disservice to the kit and the manufacturer. If you are willing to spend another $100 on a moter and good prop, then the sailplane becomes more than flyable -- totally enjoyable.
Boot is offline Find More Posts by Boot
Old May 02, 2001, 11:40 AM
oded mazor's Avatar
Joined Apr 1999
even better power set-up for the soarus is the graupner inline 2.8 gearbox + magnetic mayhem motor on 7-8 cells packs & 12x10 folder. excellent climbs at 20-25 amp'.
this arrangement provide more power than the speed 500 (initially tried that) and uses less amps, so flight time is longer .
oded.
Old May 02, 2001, 03:36 PM
dommi is offline
Find More Posts by dommi
Oxfordshire, UK.
Joined Nov 1999
Hi, Consider the FVK Silent Dream 2.2 metre
in Tee Tail or Vee Tail, I fly the Tee Tail
version, but both are superb flying machines,
the kits excellent, almost ready to go.
Mike. PS look at http://www.nesail.com./silentdream.html
[This message has been edited by dommi (edited 05-02-2001).]
dommi is offline Find More Posts by dommi
Old May 06, 2001, 10:03 PM
phoenix flyer is offline
Find More Posts by phoenix flyer
westminster ,,ca usa
Joined May 2001
I too folded my wings on my whisper but on the 2nd flight,so i did alot of looking before i bought a cermark phoenix w/ailerons i love this plane..you can see it at cermark.com fully arf w/servos $160..they have a reg.phoenix w/rudder -elevator for $129....these also fly great....good luck
phoenix flyer is offline Find More Posts by phoenix flyer
Old May 06, 2001, 10:22 PM
EAMRC is offline
Find More Posts by EAMRC
Gravity Is My Friend !!!
EAMRC's Avatar
Lewisville, Texas, United States
Joined Mar 2000
Check out our Mytos Combo:
http://eam.net/plug&fun.htm
Fully proportional 30amp ESC w/BEC and Brake not just an on/off like the others also the plane is already trimmed out as pictured, it also uses a steel wing joiner rod into an aluminum sleeve instead of aluminum bar into a balsa/ply slot. Flies better too
EAMRC is offline Find More Posts by EAMRC
EBAY--Fiberglass Fuse for 2 meter Electric objectGuru Aircraft - Electric - Airplanes (FS/W) 0 Nov 12, 2002 03:12 PM
EBAY Millenium 2 Meter electric sailplane NEW wistmodel Aircraft - Electric - Airplanes (FS/W) 0 Oct 18, 2002 03:41 PM
FS: 2 meter electric sailplane, Tx, Rx, ESC & 2 servos for $150 Flying Cat Aircraft - Electric - Airplanes (FS/W) 2 Sep 14, 2002 08:42 AM
WTB 2 meter Electric sailplane (Back again) Q-HUNTER Aircraft - Electric - Airplanes (FS/W) 4 Sep 11, 2002 08:48 AM
2 meter electric Lil Bird Richard Electric Sailplanes 1 Jun 12, 2001 07:29 PM
