Old Feb 06, 2003, 10:13 AM
SPLINTER is offline
Find More Posts by SPLINTER
smyrna de.
Joined Feb 2003
crystals is there difference depending on r/x
are cyrstals the same in single and double r/xs can the same crystal be used in ethier ?
SPLINTER is offline Find More Posts by SPLINTER
Old Feb 06, 2003, 12:42 PM
Don Sims is offline
Find More Posts by Don Sims
Don Sims's Avatar
Outside of Dyer, Tn. USA
Joined May 2000
Welcome to R/C Groups!! No you can't use a single conversion in a double. Plus different MFG have different sized crystals.
Don
I was told a single would work in a dual but it didn't work for me when i attempted it.
Don Sims is offline Find More Posts by Don Sims
Old Feb 06, 2003, 02:05 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
What he said. Dual and single don't mix, and don't mix manufacturers either..
..a
Old Feb 06, 2003, 03:20 PM
HiPlanesDrifter is offline
Find More Posts by HiPlanesDrifter
Lakewood, CO
Joined Feb 2003
So you're saying I'm stuck with Airtronics rx'es? Not that that's bad, but there are cheaper.
BTW, I'm puzzled as to single and dual conversion. What exactly does that mean?
HiPlanesDrifter is offline Find More Posts by HiPlanesDrifter
Old Feb 06, 2003, 03:26 PM
Don Sims is offline
Don Sims's Avatar
Joined May 2000
I do use Hitec crystals in my Airtronics receivers. From my very limited understanding...Dual conversion receivers have a better quality reception and "filter" transmitter siginals better. Single conversion take hits from other transmitters more, some events permit dual only and won't allow single. I use botha and do in fact have more problems with the single.
Don
Old Feb 06, 2003, 04:40 PM
Lakewood, CO
Joined Feb 2003
Would it be OK to use Hitec receivers, or even one of the "store brands"? It just bugs me that a rx itself runs almost $70, not counting the battery, servos, etc. For a lightweight setup it can run over $100 just inside the plane. Maybe I'm just not looking in the right place. I was adding up what I would need to get a Terry RTF, and came up to a little over $280. The combo from HobbyLobby was only $309. But I don't want that crummy radio they sell with it. [rant over]
Anyway, thanks for the info. I wonder if dual conversion sends it through a couple of filters, or something.
Old Feb 06, 2003, 05:26 PM
SPLINTER is offline
smyrna de.
Joined Feb 2003
Hi all I purchased an electro 6 hitec r/x LHS did not have but they gave me crystal. are there markings to indicate conversion. Regarding single vs dual In ancient days Voice radio [am] had devices known as IC,s. If my knowledge is correct they had three of these and they were used to refine the signal. those radios were know as triple conversion radios So I assume that in r/c single is only one refined signal. In dual R/X,s the signal is refined twice resulting in a clearer,cleaner more acurate signal
Old Feb 06, 2003, 06:21 PM
Lakewood, CO
Joined Feb 2003
Good question. Sometimes it says whether it's a single or a dual rx, and sometimes it doesn't. If I don't plan to do alot of flying at the club field for now, does it matter that much? Or does interference come from other sources?
I think that 'triple conversion' IC explanation is probably close enough. Sounds good to me.
Old Feb 06, 2003, 09:16 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
You can't mix brands of crystals and receivers. There's nothing wrong with using a different brand receiver than your transmitter. Make sure it's the correct 'shift' to receive the signal from your transmitter - positive and negative are the choices - Futaba/Hitec is one, JR/Airtronics the other. I use a Futaba transmitter, but use Hitec (mostly), as well as FMA, GWS, and MPI receivers.
..a
Old Feb 07, 2003, 03:06 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Single and dual conversion get discussed quite often over in the Radios forum. A search will find you plenty of information.
There's no connection between that and what makes of receiver you can use with a transmitter. A transmitter will work with both SC and DC receivers, provided they're on the correct "shift".
Steve
steve lewin is offline Find More Posts by steve lewin
Wtb R/x Crystals cobdon Aircraft - Fuel - Airplanes (FS/W) 0 Nov 11, 2003 03:52 PM
Why is there a horizontal fin on some helis?? Lucas in Alaska Electric Heli Talk 6 Jan 22, 2002 01:24 AM
Crazy Max on 8 X 300 mah NiMH? ETKing Foamies (Kits) 9 Jan 05, 2002 03:31 PM
Is there a difference between the CP1700 and 1700AE cells? razzor7 Electric Plane Talk 23 Jun 28, 2001 06:38 PM
What's the rpm on your x-250? temacc Electric Plane Talk 5 Jun 11, 2001 10:24 AM
