Old Jun 29, 2012, 08:23 PM
hperez is offline
Find More Posts by hperez
hperez's Avatar
Joined Sep 2010
Originally Posted by homiefoamie View Post
Humberto, Did you know you were mentioned in this months Model Aviation Magazine?
No, I had been busy going fishing with my grandkids, will be back to my trailer next week and look at MA it got to be in my mail box.
Thank you for the info.
hperez is offline Find More Posts by hperez
Old Jun 29, 2012, 10:14 PM
Park_aviator is offline
Find More Posts by Park_aviator
3D, 1D at a time!
Park_aviator's Avatar
United States, TX, Plano
Joined Aug 2010
Originally Posted by robj View Post
I've got an open checkbook about it.
Might as well move to canada now..... Wait a sec... socialist health care..... decisions decisions.....
Park_aviator is offline Find More Posts by Park_aviator
Old Jun 30, 2012, 03:53 AM
rdsok is offline
Find More Posts by rdsok
rdsok's Avatar
United States, OK, Norman
Joined Mar 2010
Ok... some news for the electronic vaper's out there ( aka e-cig folk )
I'm afraid this will sound a lot like a spam for GotVapes... because this info for the most part is from what I got in their forum area on ECF... but it has some cool stuff so here it goes...
First up... the Viva Nova v2.5 3.5ml ( probably closer to 2.8-3ml ) Tank w/510 threading
I'm uncertain of who of you that may have tried out the VN v1 as I had... but it had major problems with flavor ( had none almost ) and the replaceble heads had a lot of QC issues ... to put it bluntly... IT SUCKED big time and that is no pun.
The VN v2.5 has addressed all of the issues I've read about ( and experienced ). The flavor is almost as good as a bridgeless atty ( so I'm told ), it doesn't leak like the Stone was known to do, and like it's predecessor ( the Stone and earlier VN )... it's easily disassembled and cleaned.
The heads are replaceable or rebuildable... they cost between $2.50 - 2.95 each.
This is everything I have wanted... As I mentioned, they are available at GotVapes and I've seen them on one other site ( but can't remember where ). Other vendors are listing v2.0 and I also hear pretty good reports on those as well. From what I've read... v2.5 is just a minor update to the v2.0
In a couple of weeks or so... they should also have a 2.0ml version which would be a better fit size-wise to the eGo size PV's ( using a collar to clean up the look a bit. ) and also will use the same replaceable heads as the VN uses.... Oh, one more thing, if you have a VN v1... these new heads work on it but I've had a bit of leaking with them... the flavor is almost as good as the all v2.5 system.
The next bit ... They have now released a Rebuildable Vision Ego Stardust 1.6ml.... This also uses heads that are compatible with the VN v2.5 and are available now. These are also easily disassembled for cleaning and should taste as well as the VN since it uses the same basic head. Here is a pic ...
The rest of this is for the "coming soon" stuff that GV has posted on ECF... I have no timeframe to pass on... so your guess is as good as mine. Still, these are cool looking products none the less. Also since they have yet to be released, I can't pass on any reports of how good or bad these may be...
Phoenix RAVEN Line 3.5ml & 5ml Hybrid Phoenix System
While this looks like a standard carto tank... It actually uses a bottom coil ( CE3?) carto instead of a fiber polyfil type carto...
The Hyper SRT ( similar to a Genesis type of tank )
Smok Tech Telescopic Mechanical ST MOD
Takes any of 16340 , 18350, 18500 or 18650 batteries....Insert the battery and the unit telescopes or collapses down (or adjusts up) to whatever battery you are using, no extension needed to screw in or unscrew. Completely mechanical button at base with locking feature so as not to accidentally fire or to allow you to set it vertically on your desk...
Now I'll return you to your regularly scheduled off-topic topic...
rdsok is offline Find More Posts by rdsok
Old Jun 30, 2012, 10:12 AM
PrkFlyrRic is offline
Find More Posts by PrkFlyrRic
It's a BIG park
PrkFlyrRic's Avatar
Killeen/Ft. Hood
Joined Apr 2007
I think the Viva Nova v2 is better than the RAVEN in flavor and vapor plus it has the threaded end caps.
I like the V2's longer wicks but I'm still checking durability. I have had issues with plugging or having restricted air flow with different mods/batteries.
I wish they would pull the old style short wick replacable coils but until the stock is used up, the new longer wick coil heads won't be available.
Ric
PrkFlyrRic is offline Find More Posts by PrkFlyrRic
Old Jun 30, 2012, 12:08 PM
rdsok is offline
rdsok's Avatar
Joined Mar 2010
Ric, thanks for posting about the wicks on the Viva Nova heads... It was late and I forgot to even mention that portion of having different wicks available on them.
There wasn't a general concensus on which type of wick was better as it appeared to be which juice was being wicked or the convienence of not having to tilt as much with longer wicks as you would with the shorter ones. On the juices I'm vaping, the shorter wicks really enhanced the flavor but also make me vape with my PV almost horizontal towards the end of the tank full... GV's said they are going to stock the longer wicks so users can choose which way they want, if you want a short wick just trim it down.
I hate hearing about the Raven having less flavor and I already had reservations about how easily it cleans compared to the VN which is almost stupid simple to maintain.
At the same time, I've got 4 DTC type tanks that I could put back into rotation if these are not too much of a drawback. The juices I vape most are dark tobacco's and they clog a polyfil carto in less than a tankful. Cleaning them by backflushing is a PITA and I end up loosing a 1-1.5ml of juice when they clog. I also prefer the looks of the DTC tank over the Vivi tank, but obviously that is just a personal preference issue only.
The 1.6ml Stardust v2's that I've tried were ok with only a slight muted flavor... so the move to the new heads and being able to clean easier... will certainly make these a favorite with many folks. The 1.6ml capacity will be a nice amount for the juices I still like a lot but seldom get in a mood to vape. Of course, the 2.0ml VN tank will work well for this size capacity also and it won't require a 510-eGo adapter if you use just a 510 device.
Old Jun 30, 2012, 12:14 PM
3D, 1D at a time!
Joined Aug 2010
I don't understand all of this.... lol
Old Jun 30, 2012, 12:24 PM
rdsok is offline
rdsok's Avatar
Joined Mar 2010
... and if you don't smoke cigarettes ( which is a Gooder thing )... don't worry about it. If you do however, we are just mentioning some of the advancements in e-cigs that will help in replacing the analog cigs
Old Jun 30, 2012, 12:33 PM
blakevan is offline
Find More Posts by blakevan
Ta-dah!
blakevan's Avatar
United States, TX, Richardson
Joined May 2007
Ok I official HATE PA airplanes. I have tried to put this Bandit together for weeks and every step requires all kinds of work. Anyone who says PA, EF and 3DHS are equals is full of !
blakevan is offline Find More Posts by blakevan
Old Jun 30, 2012, 12:35 PM
It's a BIG park
PrkFlyrRic's Avatar
Killeen/Ft. Hood
Joined Apr 2007
What he said x2
I went from 2.5-3 packs a day to 0 in about 14 days thanks to E-cigs. I smoking started at 18 when I joined the Army and smoked for 28 years.
I use the lite colored juices, mostly a mix I've got my local Vape shop mixing, Vanilla Bean, lite-Cinnamon over a RY4 base, 50/50-PG/VG or 70/30 @ 16mgs.
The issue of having to tilt or lay my mod down to wet the wick is why I like the longer wicks.
Old Jun 30, 2012, 12:37 PM
It's a BIG park
PrkFlyrRic's Avatar
Killeen/Ft. Hood
Joined Apr 2007
Wait until you have to do any kind of repairs, it's even worse.
Old Jun 30, 2012, 02:03 PM
Lonelasso is offline
Find More Posts by Lonelasso
Lonelasso's Avatar
United States, TX, Austin
Joined Dec 2006
Dohhhhh !!
32 D'oh's in 15 Seconds (0 min 15 sec)
Lonelasso is offline Find More Posts by Lonelasso
ambientech is offline
Find More Posts by ambientech
ambientech's Avatar
Central Texas
Joined Jun 2008
The only PA plane I have had was the amr and it took a ton of work also. It flew nice and light but will crumble in a crash any EF or 3dhs plane would survive unscathed so be careful
ambientech is offline Find More Posts by ambientech
Old Jun 30, 2012, 02:04 PM
3D, 1D at a time!
Joined Aug 2010
I love how the AMR looks though
That sucks!
I'm all for replacing the old ones
Old Jun 30, 2012, 02:14 PM
-= GYRO =- is offline
Find More Posts by -= GYRO =-
United States, NV, Las Vegas
Joined Nov 2010
+1. I'm also not a PA fan, and won't buy their planes either. I had the AMR also and sold it. fragile like glass!
-= GYRO =- is offline Find More Posts by -= GYRO =-
Reply With Quote  (Disabled)
Old Jun 30, 2012, 02:24 PM
blakevan is offline
Ta-dah!
blakevan's Avatar
Joined May 2007
Can't wait for the crash. Happy to sell the motor and get that one out of the system.
Ideas for annual fun fly games? JTinCT Electric Plane Talk 9 Jan 29, 2011 11:49 AM
Discussion First Annual "Lawn Dart" fly-in mattJ Thermal 1 Apr 15, 2007 10:39 PM
Fly-In first annual skymac"Vette City Big Birds", giant scale fly-in taildragger21 Fuel Power Events 11 Jul 24, 2006 06:35 PM
First Housefly to Fly Contest johntbyrne Electric Heli Talk 65 Jan 17, 2002 12:36 AM
Dream High, Fly Low Todd Long Sport Planes 2 Apr 23, 2001 04:55 AM
