Old Feb 06, 2003, 04:01 AM
dvint is offline
Find More Posts by dvint
Indpls.,In.
Joined Oct 2000
Is there such a thing as ground effect ?
I did a forum search and could not find an answer.
Thanks in advance.
dvint is offline Find More Posts by dvint
Old Feb 06, 2003, 05:17 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Yes. For info about the extremes of this effect see
http://www.se-technology.com/wig/
http://home.mira.net/~radacorp/ground_effect.html
Did you have any particular reason for asking ?
Steve
steve lewin is offline Find More Posts by steve lewin
Old Feb 06, 2003, 09:32 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
Pelicans are in the habit of saving energy by using ground (water?) effect. When flying over relatively smooth water a pelican will flap 7 to 10 times to gain an altitude of about 10 or 12 feet over the water. Then the bird goes into a shallow dive, pulling out inches above the water. It glides along for about 50 yards skimming the surface. The wing tips are arced downward slightly so that they sometimes penetrate the water briefly without the body touching the surface. As the speed gained in the dive bleeds off and a stall is about to happen the bird starts flapping again to repeat the cycle. When the bird glides this close to the surface its induced drag is approximately halved and its total drag is reduced by about 25%. That constitutes a significant energy saving for the bird.
Ollie is offline Find More Posts by Ollie
Help! Is there such a thing as an EDF Concorde? turbovector Electric Ducted Fan Jet Talk 15 May 03, 2004 04:29 AM
Is there such thing as too cold? cincy Aerial Photography 2 Dec 11, 2003 12:15 PM
Is there such a thing as "Dreaded WEDGIE Flap?" Helicool Foamies (Kits) 4 Aug 28, 2003 11:55 PM
Is there such a thing as a too large esc? Rackey Beginner Training Area (Aircraft-Electric) 7 Mar 06, 2003 07:48 AM
Is there such a thing as motor being too powerful/prop being too big? simingx Power Systems 9 Jan 28, 2003 07:36 PM
