Hmmmmm..... interesting. I didn't think about the throttle-channel bit, but that will certainly complicate the production of the positive-shift version because there is nowhere near the apparent standardization of the thorttle channel as on negative shift equipment.
GWS uses channel 1 as does JR. Airtronics uses channel 3. My Multiplex uses 4. I wonder how that other combo ESC/RX that Great Planes has handles this..... |
Latest blog entry: Diverted from R/C to Free Flight (of a...
On the bottom side the mod is a bit more tedious. The photos do not readily reveal that everything is very small.
I had to invert the output of the TA31136 FM detector IC. I used a tiny three terminal digital invertor IC (essentially an NPN transistor with intergrated resistors). I had to add a pullup resistor too (as seen by the SMT resistor). I placed polyimide tape over the ground plane to create an isolated work surface. I CA'd the two new parts to the tape. The jumper wires are 40 AWG magnet wire. Most of the soldering work was performed under a magnified light source. This mod is only shown for those that are curious as to what I did. I do not expect anyone else to be nuts enough to repeat my work. Instead, lean on Plantraco to release a JR compatible Rx. ![]() Regards, Mr. RC-CAM |
| Thread Tools | |
| For Sale Plantraco DSP4-SC Receiver/10A ESC w/micro antenna and lipo alarm | PerfectStranger | Aircraft - General - Radio Equipment (FS/W) | 5 | Mar 07, 2006 04:14 PM |
| Sold Like New Plantraco DSP4-SC Rx/ESC | sgil2001 | Aircraft - General - Radio Equipment (FS/W) | 4 | Oct 14, 2005 07:45 PM |
| Article Plantraco DSP4-SC Receiver with ESC | Morb | Electric Plane Talk | 26 | Dec 21, 2004 10:15 PM |
| FS- (2) Plantraco DSP4-SC Rx's(ones with intergrated 10 amp ESC) with ch 19 xtals | Etonic | Aircraft - Electric - Airplanes (FS/W) | 3 | Jul 19, 2003 08:36 PM |
| DSP4-SC Receiver with built-in 10 AMP ESC | Plantraco | Parkflyers | 72 | Feb 10, 2003 10:17 AM |
