Old Aug 17, 2008, 01:27 PM
BoneDoc is offline
Find More Posts by BoneDoc
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Mini-HowTo
BoneDoc's 3D Clinic #8: Knife Edge Mixing
Hey Gang,
"Welcome to another 3D Clinic Session with Josh "BoneDoc" Young and my lovely wife, Inn."
This has been hotly requested, so though the video is a bit "raw", I'd thought I'd post it now, and when I have the time, refine it so that it's clearer.
Let's jump in:
KE mixing IMHO is one of the most important mixing you can do to make your aerobatic aircraft flies better and truer. In reality, it's really TWO mixes, as you need to mix out the roll coupling (rudder --> aileron) as well as pitch coupling (rudder --> elevator). Of the two, the roll coupling is the harder to fly out, and so it should be the first to be mixed out.
Some basic info on Mixing:
BEFORE YOU START, YOU NEED TO MAKE SURE THAT YOUR PLANE IS PROPERLY TRIMMED, AND THAT YOU'VE SET YOUR CG AT THE DESIRED RANGE.
Mixes are just pre-programmed actions you tell your transmitter to do when a certain stick input is entered. In this case, the stick input is the rudder (MASTER), and the computer is entered to add a certain amount of aileron / elevator (SLAVE). When you're new at this, add FIVE PERCENT at a time until you've overcompensated, then come back a couple of percent. The AJ Slick did not require much, but I had a 50cc Lanier Edge that required 20% Rudder - Aileron mix.
Mixing out the Roll Coupling
Most aircraft's roll coupling will be in the direction opposite of the rudder input. When you set the mix out on your radio, first wiggle your aileron in the opposite direction of your rudder to get the correct direction, then figure out which mix (whether positive or negative) will produce that result. Do this until you get the mix right in BOTH direction.
Mixing out Pitch Coupling
Pitch coupling is greatly influenced by your CG because your CG determines your elevator trim for a straight upright flight. In general, the more aft your CG is, the more pitch to the belly you get (because your elevator trim will be deflected downward more). The opposite is true for a forward CG. In general, majority of aircrafts will pitch to the belly, and you'll need the elevator to deflect UP with rudder input. This will usually mean that your mix will be POSITIVE in one direction, and NEGATIVE in the other direction (you'll see in the video what happened when I forgot that fact ).
Concluding words
Once you mix out your pitch and roll coupling, you'll be surprised how easy it will be not only to do KE, but also to perform precision rolling maneuvers, in particular, the point rolls. I shot some footages doing 4 and 8 point roll, and I was pleasantly surprised how much easier it was to do them with the Slick mixed out...
Without further ado, here's the video
3D CLINIC VIDEO #8a: Knife Edge Mixing
BoneDoc is offline Find More Posts by BoneDoc
Old Aug 17, 2008, 01:43 PM
Doc Austin is online now
Find More Posts by Doc Austin
Team Extreme Flight
Doc Austin's Avatar
USA, FL, Largo
Joined Dec 2005
Thanks, Josh. I was out playing around with my mixes just today and not getting anywhere, so I think this is going to help me a great deal.
Doc Austin is online now Find More Posts by Doc Austin
Old Aug 17, 2008, 01:51 PM
BoneDoc is offline
Team 3DHS
BoneDoc's Avatar
San Antonio, TX
Joined Sep 2004
Thanks Doc,
the file is HUGE 87 MB, but it's 12 min's worth of footage.
Old Aug 17, 2008, 01:52 PM
blucor basher is online now
Find More Posts by blucor basher
ExtremeFlight - 3DHS - Legacy
blucor basher's Avatar
United States, TX, Tyler
Joined Jun 2003
Great vid Josh -nice work, both of you!
You brought out a very important point here - LOOK at the surface you are applying a mix to! Which way is it moving? Is it the way you want it to move?
Usually, when (like Doc says) you "aren't getting anywhere" in mixing, it's due to one of two things:
1.You're not remembering what it is you need to do after you land.
2.Your mix is going the wrong direction and you don't realize it.
Handy tip: On virtually every 3D airplane set up for 3D flying, you need the elevator to move UP when the rudder is moving EITHER directions. I.E. - Right rudder gives you some UP elevator, and Left rudder gives you some UP elevator.
blucor basher is online now Find More Posts by blucor basher
Old Aug 17, 2008, 01:54 PM
Xpress.. is offline
Find More Posts by Xpress..
Team Hitec, Customer Support
Xpress..'s Avatar
United States, CA, Poway
Joined Oct 2007
With most of my planes, the case is down elevator, and opposing aileron. I have no idea why it is always down elevator.
But good vid Josh.
Xpress.. is offline Find More Posts by Xpress..
Old Aug 17, 2008, 01:59 PM
Joined Jun 2003
More wisdom from the Pro.
Old Aug 17, 2008, 03:28 PM
Earthbound is offline
Find More Posts by Earthbound
Gravity brings me down
Earthbound's Avatar
Seattle, WA
Joined Sep 2003
BoneDoc,
That's an outstanding presentation.
Earthbound is offline Find More Posts by Earthbound
Old Aug 17, 2008, 03:32 PM
Get Real is offline
Find More Posts by Get Real
Flippin Multirotors
Get Real's Avatar
Illinois
Joined Feb 2006
Another very useful contribution to helping others learn 3D and set ups BoneDoc.
Thanks to the other poster for correcting there post .
Get Real is offline Find More Posts by Get Real
Old Aug 17, 2008, 04:58 PM
Threshold is offline
Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
I haven't seen the vid but I'm assuming you are showing a linear mix? I have often been tempted to try a curve mix with more anti-coupling as rudder increases, I seem to note that you need progressively more mix as rudder increases, ie at the bottom of a KE loop using full rudder you have to override your mix and add more opposite aileron
Threshold is offline Find More Posts by Threshold
Threshold's Avatar
London UK
Joined Jul 2004
I haven't seen the vid but I'm assuming you are showing a linear mix? I have often been tempted to try a curve mix with more anti-coupling as rudder increases, I seem to note that you need progressively more mix as rudder increases, ie at the bottom of a KE loop using full rudder you have to override your mix and add more opposite aileron? what do other people feel and has anyone used a curve mix?
Old Aug 17, 2008, 06:51 PM
goflyhighrc is online now
Find More Posts by goflyhighrc
Just go with the flow
goflyhighrc's Avatar
Joined Nov 2006
By the one of two things :
Do you mean make adustment after observing your flight and making corrections in the mix ??
goflyhighrc is online now Find More Posts by goflyhighrc
Old Aug 17, 2008, 07:12 PM
R/C_Addict is offline
Find More Posts by R/C_Addict
That's me.
R/C_Addict's Avatar
San Francisco Area, CA
blucor_basher meant that when you land, you forget which way the plane was coupling so you end up making the wrong correction and worsening the problem, or you have to go up and try it again.
Great videos BoneDoc. They have helped me tremendously while learning 3d.
R/C_Addict is offline Find More Posts by R/C_Addict
Old Aug 17, 2008, 07:47 PM
Angry Hornet is offline
Find More Posts by Angry Hornet
flying yellow and black
Co Spgs, CO
Joined May 2008
Great video Josh. The more of your videos I watch, the more I have been able to get out of them. I took my Velox out this afternoon and tried to mix out the very little coupling it has. I went the wrong way with a couple of settings but I figured out what I was doing and I think I have it right now. Either way it was a good learning experience. I brought the Velox home, which is always good I wish I could try to mix the coupling out on my SHP, but that is another story...
Angry Hornet is offline Find More Posts by Angry Hornet
Old Aug 17, 2008, 09:54 PM
Joined Jun 2003
R/C Addict is correct, what I meant is that often, after we land, we don't remember what changes we need to make to our mixes. For the record, when mixing a new plane, I try to have a helper handy. Josh has done this job for me before - the helper scribbles notes while I fly so I can remember what it was I wanted to mix out.
Old Aug 17, 2008, 10:12 PM
TexasFlyer is offline
Find More Posts by TexasFlyer
TexasFlyer's Avatar
Houston, TX
Joined Sep 2005
Blucor Basher and Xpress,
I wonder if the reason why your planes need differing elevator mixing is due to differences in where you like your CG. I think the take-away is that the Rdr-->Elv mix should be in the same physical direction for both rudder deflections.
Alan
TexasFlyer is offline Find More Posts by TexasFlyer
Mini-HowTo BoneDoc's 3D Clinic #2: KE Spins & Blenders BoneDoc 3D Flying 70 May 09, 2015 06:20 AM
Mini-HowTo BoneDoc's 3D Clinic #1: Upright AND INVERTED Harrier - NEW SECTION & VIDEO ADDED BoneDoc 3D Flying 101 Jun 14, 2014 06:11 PM
Mini-HowTo BoneDoc's 3D Clinic #5: Rolling Harrier BoneDoc 3D Flying 115 Sep 18, 2011 03:48 AM
Discussion BoneDoc's 3D Clinic #4 - Hovering - New VIDEO ADDED - Hovering in the wind BoneDoc 3D Flying 138 Feb 21, 2010 10:53 PM
Mini-HowTo BoneDoc's 3D Clinic #3: All About the Knife Edge BoneDoc 3D Flying 81 Oct 13, 2008 02:38 AM
