Old Aug 17, 2008, 11:42 AM
paulyboy is offline
Find More Posts by paulyboy
Alabama
Joined Jun 2007
Question
Hardwire or Plugs??
i just recieved my ammo motor and thunder-bird esc ...the motor has plugs but the esc doesn't..should i hard wire them, or find a set of plugs for both of them..........or could you tell me the plugs to get for the esc that will fit the motor plugs.
thanks, paul
paulyboy is offline Find More Posts by paulyboy
Old Aug 17, 2008, 12:40 PM
pompebled is offline
Find More Posts by pompebled
Boaters are nice people.
Sneek, Netherlands.
Joined May 2004
Most motors come with a set of (female) plugs, you can solder onto your ESC.
In some pics the vendor has put them onto the males, so it looks a solid piece of brass, I'd check and if there's nothing, ask the vendor to get you some for free.
Regards, Jan.
pompebled is offline Find More Posts by pompebled
Old Aug 17, 2008, 02:45 PM
paulyboy is offline
Alabama
Joined Jun 2007
what do you mean by vendor,,,the place i ordered it from or the manufacturer?
Old Aug 17, 2008, 04:07 PM
Sneek, Netherlands.
Joined May 2004
Both, the manufacturer 'should' provide them with the ESC, otherwise the vendor should add them as 'service'.
These connectors are usually sold in pairs. (male + female)
Just give it a try.
Otherwise take a caliper and measure the connectors diameter to know which connectors you need.
Regards, Jan.
Old Aug 17, 2008, 06:21 PM
paulyboy is offline
Alabama
Joined Jun 2007
problem solved...found some pugs that will fit it
