Event Review: Visalia Fall Soaring Festival, Visalia California
Michael Heer visits the 35th annual Fall Soaring Festival in Visalia California to share the beautiful sailplanes and some of the emotion at this year's event.
Introduction:
Recently I attended the 35th annual Fall Soaring Festival. The pilots’ meeting was scheduled for 8:00 both days, and the first flight was scheduled for 8:30 in the morning. Saturday, each pilot was to fly four separate rounds in the order in which they were assigned of 3,5,7 and 9 minutes with a point per second penalty off the target time. Sunday had three rounds of 4,6 and 8 minutes with the same penalty.
I hope you enjoy this year's version of the Fall Soaring Festival as I observed it on Saturday of this two day event. There was even a sneak preview of a new electric glider that is coming soon from ParkZone!
Every Flight starts with a Launch
The first and last fifteen seconds of a flight were consistently the most exciting to see. The drama of being almost down early in the flight and catching a thermal at the last minute before heading in is hard to capture on tape. start my visit to Visalia with a collection of glider launches.
(BASICS) How they Launch Gliders
At Visalia, the flight starts with a launch using a battery powered winch. The winch is made with a car starter motor mounted on a frame with an aluminum drum attached to it that is filled with "line." The winch is connected to a 12-volt battery and has a pedal attached to it to activate the motor. The line from the drum is run down the field and goes through a "turnaround." The turnaround is like the hub of a bicycle mounted into a block or holder that can be secured to the ground or a pole in the ground so that it stays put. The line is then run back to the starting area. On the end of the line there is either a parachute or color marker followed by a metal loop. The loop fits onto a hook on the glider that is located on the bottom of the fuselage, under the wing area.
The launch is initiated by the launcher, usually the pilot but not always, stepping on the pedal connected to the starter motor and taking all of the slack out of the line. In Visalia, they keep rapidly pulsing the pedal and thereby the motor, and toss the plane forward and slightly up. The pull of the line pulls the plane forward, but the wing forces it mostly upward. The plane is pulled forward and upward until it is approaching the turnaround. There, most pilots do a short dip dive down, and then zoom upward as the loop falls off of the hook, and they transition much of their forward movement to extra altitude. The pilot then heads in the direction where they believe they will find lift.
Sneak Preview of the New ParkZone Radian Electric Glider
At the JR/Spektrum booth at the contest they had two of the new ParkZone 2-meter electric gliders out and they have been flying them and were going to fly them some more on Saturday after the contest was over for the day. Unfortunately, I couldn't stay and shoot a video of this new glider in action but I do have some photos to share.
Spektrum donated a lot of prizes to the Festival auction, but what i heard the most talk about was the special free drawing for a $500.00 cash prize. All you had to do to enter was use a Spektrum radio in the contest.
(BASICS) How you Score Points in a Thermal Competition
There are two ways to earn points in a thermal competition: the timed flight and the scored landing. In four rounds the first day and three rounds the second day, pilots are assigned a position. A timer starts the stop watch as soon as the loop of the winch line drops off of the hook on the plane. The pilot looks for lift so that he can stay up the prescribed amount of time for the round. If it is a 9 minute round, the pilot wants to fly exactly nine minutes - no less and no more! If the pilot can't find lift, or worse, launches when a sink cycle is over the field they may come down without making the time. Alternately, a pilot might launch and find great lift and get the glider so high that it can't be brought down in time. Points are lost for every second a pilot is short or over the required time. Finally, to get any points for the flight time, the pilot must land the glider on the field in a designated area. If the pilot goes out too far searching for lift and encounters strong sink or wind trying to get back to the field and lands off field, there are no points awarded for the round.
The second way to score points is to score the landing. Visalia is known for having small scored landing areas that are different every year. The nose of the plane has to stop and end up in the scored landing area to score landing points in each round. These landing areas are near the edge of the landing zone, and if a pilot comes in too hot and goes past the scored landing area and crosses the Disqualification Line, the pilot gets no landing or flying points for the round. Visalia's Fall Festival is not designed to be a beginner competition, but to separate the good from the very good and excellent pilots.
Some Thermal Views
Between the launch and the landing the pilots look for thermals to get lift and make their assigned time. Here are a few pictures of the planes in the air and some video.
Landing
Visalia has "gates" at one end of their landing area through which pilots are supposed to enter. This is away from the pilots and is a safety as well as a control factor. It would be far more dangerous if pilots could enter the landing area from any side, especially the side opposite the gates. Once a pilot has entered the landing area, he is seconds from landing. The scored landing area is traditionally small and challenging, and ideally it is where the pilot wants to end the flight. It is very near the end of the landing area, and if the glider crosses the DQ (disqualification) line behind the scored landing area, the pilot not only gets no landing points, he gets no points for that round. It is a pressure packed area for the pilot, and the better the pilot, the higher the expectation and often the greater the reaction to success or failure.
The Good
The Good landing  12.84 MB
The (too) Bad
The (too) Bad landing  13.22 MB
The Ugly
Conclusion:
If you want to know the results of the contests that make up the Fall Soaring Festival, they can be found on the website of the Central Valley Soaring Club. I was told there were 297 registered planes for each round, which means that on Saturday alone there would have been over 1100 flights. An individual pilot could fly multiple events in the contest such as open class, RES, 2-meter and Woody. After the formal rounds, there is electric and night flying. If you ever have a chance to attend the Fall Soaring Festival it is a very special event.
Old Oct 06, 2008, 10:12 PM
kwmtrubrit is offline
Find More Posts by kwmtrubrit
Be an organ donor
Little Rock, AR. U.S.A via U.K
Joined May 2004
Thanks so much for supporting silent flight with this review.
Keith
kwmtrubrit is offline Find More Posts by kwmtrubrit
Old Oct 06, 2008, 11:18 PM
Michael Heer is offline
Michael Heer's Avatar
Stockton, Ca. USA
Joined Apr 2001
Keith you are most welcome. Mike
Old Oct 07, 2008, 12:29 AM
FrogChief is offline
Find More Posts by FrogChief
Russian Federation, Sakha, Yakutsk
Joined May 2006
Keith
I'm with Keith. Great job! Love the videos. Hope to make it out to Visalia one day.
-Sean
FrogChief is offline Find More Posts by FrogChief
Reply With Quote  (Disabled)
Old Oct 07, 2008, 10:14 AM
ajbhatta is offline
Find More Posts by ajbhatta
Lexington, KY
Joined Jul 2003
Nice article and pics. Thanks for posting. Hope to make it there some day.
AJ
BSS, KY
ajbhatta is offline Find More Posts by ajbhatta
Old Oct 07, 2008, 10:39 AM
dlgdude is offline
Find More Posts by dlgdude
2013 US F3K Team Manager(ret)
Newbury Park, CA
Joined May 2005
Woohoo! Made the "good" video....
Thanks for putting this together. It will be a great place to point people who are interested in what we are doing.
-l
dlgdude is offline Find More Posts by dlgdude
Old Oct 07, 2008, 11:27 AM
Monster Mash is offline
Find More Posts by Monster Mash
Monster Mash's Avatar
Joined Sep 2007
I thought I made the "ugly" video because of one of the pictures, but you got someone else that did the same burm landing I did...
No mention of the after contest festivities?
Monster Mash is offline Find More Posts by Monster Mash
Old Oct 07, 2008, 11:51 AM
Stockton, Ca. USA
Joined Apr 2001
Monster it was hit and run this year with my wife. I was at a northern Ca Fun Fly on Sunday. Missed out on the Beer Garden and what I have heard were some great night flyers. I would have also liked to get some video of a test fly the Radian electric glider.
Old Oct 07, 2008, 03:40 PM
FDNYJERY is offline
Find More Posts by FDNYJERY
FDNYJERY's Avatar
LONGWOOD, FLORIDA
Joined Aug 2003
Just a great Job . hope to get out that way one year to see this awesome thermal contest..fdnyjery
FDNYJERY is offline Find More Posts by FDNYJERY
Old Oct 07, 2008, 03:55 PM
Bill Henley is offline
Find More Posts by Bill Henley
Try the Truth for a change
Bill Henley's Avatar
home on the range
Joined Apr 2007
Thanks for posting the downwind launch Video with me in it! (Plane with the silver and orange tail) Now I can prove to my wife where I was!!!
Bill Henley is offline Find More Posts by Bill Henley
Old Oct 07, 2008, 09:54 PM
Jflyer1 is offline
Find More Posts by Jflyer1
Joined May 2006
Thanks Mike for getting one of my landings on video under the "good landing" heading at about 0:54 seconds into the video - very cool!
Jflyer1 is offline Find More Posts by Jflyer1
Old Oct 08, 2008, 03:50 AM
Kamyczek_PL is offline
Find More Posts by Kamyczek_PL
Poland, Lower Silesian Voivodeship, Jelenia Góra
Joined Jul 2008
Very nice but landing its not javelin throw. Can you normal landing ? More people f3b , f3j cant landing perfect only "javelin throw" its foolishly.
Kamyczek_PL is offline Find More Posts by Kamyczek_PL
Old Oct 08, 2008, 07:40 PM
Jflyer1 is offline
Joined May 2006
Hey Kamyczek PL,
No one is stopping you from showing the world how you do it and still be able to hit a spot with precision. If you like to "slide your plane in" on approach more power to you. Again, no one is stopping you here. There are all kinds of approaches and landing styles out there - believe me I've seen them first hand! All of them combined is what makes it so much fun to watch and participate in. Lighten up and land as you please. Besides, in the end we're all trying to hit a designated area or tape etc., it doesn't really matter how you get there, just as long as you get there!
Old Oct 08, 2008, 08:33 PM
lenci1938e is offline
Find More Posts by lenci1938e
Glider Geek!
lenci1938e's Avatar
Escalon, CA
Thank you Jflyer1
Jason,
I want to tell you "Thanks again" for the great job you did at the landing zones all weekend. You and your club did an outstanding job, as usual, with a lot of adverse conditions this year. Congrats as well on your top ten finish! You are one of the West Coasts top flyers. Consistently at the top. Well done!
Shawn Lenci
lenci1938e is offline Find More Posts by lenci1938e
Old Oct 08, 2008, 08:36 PM
jrerickson is offline
Find More Posts by jrerickson
jrerickson
jrerickson's Avatar
Valencia, CA
Joined Jan 2005
Not too many of us land downwind if given a choice. At Visalia it's always downwind in the morning. This year was worse than usual. I came in with my Topaz in RES and burned off as much speed as I could. Remember that you have to maintain some airspeed or you'll fall out of the sky. I kept the plane about a foot off the ground for the last 25' and put the nose into the spot.
Instant flip. I didn't even have time to complain. I then watched 7 other planes IN A ROW flip over. It had to be some record. Nobody could figure out how not to flip. Finally a plane came in crosswind and made it to the ground without flipping over. Out of the landing zone, but right side up.
In open class I could slow the plane down at the last second using flaps and I managed to hit the bullseye in that downwind round. I'd like to see anyone slide into that spot, intentionally. You had to put the nose down hard.
JE
jrerickson is offline Find More Posts by jrerickson
Discussion Thermal Competition doublesixes Thermal 4 Mar 30, 2006 02:46 PM
Discussion Elexaco Rules, a fresh look at a simple thermal competition graham_mca Electric Sailplanes 47 Jan 08, 2006 06:52 AM
Skegs or no skegs for Thermal competition in US fprintf Sailplane Talk 2 Jan 27, 2003 10:30 AM
