Old Aug 30, 2008, 11:49 AM
Hans-Joachim is offline
Find More Posts by Hans-Joachim
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
I go with the original aileron size on my 1/7 scale BF-109F version
and started cutting and gluing the parts, today. 210g /7.41 oz so far.
The wing is glued under the fuselage and Iīve used two carbon tubes inside on the vertical V- form. One on the left side in front of the 6mm depron V-wing-profile and one on the right side, behind the 6mm V-profile, overcrossing in the centre.
The wing span is 1420mm / 55.9 inc, the 3mm carbon tubes (couldnīt get 4mm) are both cut down to 900 mm / 35.4 inc to stay inside the wing.
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Aug 30, 2008, 04:42 PM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
And here I thought I was making good progress. I'll post pics later, just started today. You're just too fast for me Hans.
J
J Morgan is offline Find More Posts by J Morgan
Old Aug 30, 2008, 07:06 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Here's my start. The tubes are in for elev and rudder. Skinned majority of the port side. I'll wait to skin the firewall section until Jerry sends me the spinner. Meanwhile more skinning tomorrow and hopefully start on the airfoiled wing. Like I said, I'm not as fast as "The fastest builder in Germany"!
J
Old Aug 31, 2008, 03:50 AM
Living a Dream
Joined Oct 2003
Good morning, John,
NO PRESSURE!! Letīs enjoy this BF-109 adventure!!
The construction bar is a very good idea!
Iīve cut out the rudder from the vertical fin, to get the elevator in place
and noticed that the slot in the vertical fin has to be 2cm/0.79inc longer.
HJ
Old Aug 31, 2008, 06:40 AM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Good morning Hans! I am enjoying it! I will cut off the rudder to since it is to be workable. Sure makes the stab placement easier.
J
Old Aug 31, 2008, 09:23 AM
glenn7e is offline
Find More Posts by glenn7e
glenn7e's Avatar
leicestershire uk
Joined Sep 2006
Love seeing these models take shape
Glenn
glenn7e is offline Find More Posts by glenn7e
Old Aug 31, 2008, 06:56 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Thanks Glenn!
I made pretty good progress today. About 80 % of the fuse covered. Both rudder and elev servo installed. Stab cut out an balsa edges/reinforcement glued on. Rudder cut off and shaping just started on it. Center section of the wing built. Setup the right wing panel and got a good start on it too. The left will go faster, not much figuring out on it, just a flip image.
I weighed the fuse( w/servos), center section, stab, rudder and it all weighs 9.5 oz so the weight is staying in check.
I think I will poly/glass this one instead of epoxy/glass. It will be quicker. Vegas is really coming up fast now.
J
Old Aug 31, 2008, 09:59 PM
Xanadu is offline
Find More Posts by Xanadu
Xanadu's Avatar
Canada, MB, Winnipeg
Joined Nov 2006
What are you using to glue the blue foam sheeting on with?
Xanadu is offline Find More Posts by Xanadu
Old Aug 31, 2008, 10:25 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Foam safe CA.
J
Old Aug 31, 2008, 10:31 PM
corsair nut is offline
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
sweeeet!!!!! AWOSME build as always gramps! hows the flying beer keg doing!
corsair nut is offline Find More Posts by corsair nut
Old Aug 31, 2008, 10:43 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I've gotten wrapped up in this build and need to get back on the Wildcat. It has the fuse about 90% skinned. Needs a wing center section and it will be about the same stage as the 109. When I finish the 109 wings I will go back to the F4F while I wait on the spinner.
J
Old Sep 01, 2008, 01:07 AM
Tripod333 is offline
Find More Posts by Tripod333
Joined Jun 2008
is it possible to build a wing like this out of EPP? (I have 6mm)
Tripod333 is offline Find More Posts by Tripod333
Old Sep 02, 2008, 05:25 AM
Dreamcatcher is offline
Find More Posts by Dreamcatcher
Warbirds Lover
Dreamcatcher's Avatar
South of France
Wooooww !
What a nice bird HJ !
For me, the late BF-109 F & early G versions were the bests OKL fighters from 1941 to 1943 and even the best fighters of the world at the begining of WWII.
Thank you very much to share this beauty with us... I think my WWII warbirds squadron will grow up next winter !
Are the B&W pictures you posted are pictures of the famous German ace Hans Joachim MARSEILLE ?
I'm sure that "Master MORGAN" will build another flying jewel
Dreamcatcher is offline Find More Posts by Dreamcatcher
Old Sep 02, 2008, 06:47 PM
J Morgan is offline
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
I hope to Dreamcatcher!
Don't see why you couldn't use EPP. It will need good support though. I don't like EPP because it's so hard to get a decent finish.
Finally finished the airfoiled wing. It's pretty close to a scale airfoil thickness wise but I used a modified Clark Y. Only thing left before glassing is tapering the LE of the ailerons. That is two 4' long tables pulled together, shows just how long this wing is!
J
Old Sep 02, 2008, 07:03 PM
fuelsguy is offline
Find More Posts by fuelsguy
fuelsguy's Avatar
Seattle
Joined Dec 2001
Hi J,
Nice build as usual; it's going to end up looking a lot like my Tony. About the same wingspan, and mine ended up at 22 oz. flying weight.
What colors cheme?
Ivor
fuelsguy is offline Find More Posts by fuelsguy
Build Log P-51D Mustang Parkflyer 1/9 Scale Hans-Joachim Foamies (Scratchbuilt) 779 Oct 22, 2014 10:39 PM
Video F-16C*scale 1/9*speed test*e-flite park 480 Jan-Henrik Electric Plane Talk 3 May 29, 2007 04:27 AM
DELFIN in 1/9 scale scratchbuilt CaptDH Submarines 1 May 22, 2004 04:30 PM
1/4 scale FW190D-9 Wulfman Fuel Warbirds 0 Feb 03, 2004 01:36 PM
