Old Aug 22, 2008, 07:48 PM
Erik with a K
tvcasualty's Avatar
Toledo, OH
Joined Aug 2007
I have yet to find a really good way to attach a home made spinner... The way I did mine, while it works, is not optimal. Anyway, all you do is put some kind of backplate behind the prop, I ended up using the same PET-G plastic I make my canopies out of. When I made my 109, I used a peanut butter jar lid (pre-canopy era). Then I just hot glue the spinner onto the backplate. On the 109F it has a very large surface area to glue to so it will hold on pretty well in flight... The trick is to get it to stay on while landing. So it might be a good idea to have some hot glue available in the field if the look is important on future flights... I should also say that I ALWAYS had great difficulty landing my 109. Seems it would just stall suddenly, always subject to tip stalls, and when it didn't tip, it was nose first too late. Upon redesign, I will undoubtedly add flaps and lots of wash out to help this out, as I would recommend you guys do. Good Luck I can't wait to see some progress!!
tvcasualty is offline Find More Posts by tvcasualty
Old Aug 22, 2008, 10:43 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
109s are notorious for tipstalls. Just add 2 or 3 degrees of washout and they become little pussycats. My 42" ws E Model lost the washout when I glassed it due to shrinkage. It was a bear! Finally the LVC hit it when landing one time and when that prop stopped she turned turtle in a heartbeat. From about 12' up! After the fuse repair, I built a new wing with 3 degrees washout. It flies like a champ now and will NOT tipstall. has a couple of hundred flights on her too.
I made one large spinner from foam. Only hollowed out where the prop nut went. Then used 3 sets of magnets, backplate to foam spinner, to attach it. Worked real well. Easy to balance and easy on/off at the field. But I detest making spinners and will out source it to Jerry who does a fabulous job and does it right!
J
J Morgan is offline Find More Posts by J Morgan
Latest blog entry: F7F Tigercat from Palmer Plans
Old Aug 23, 2008, 12:21 AM
It's a trap!
GotrekGurnisson's Avatar
Brisbane, Australia
Joined Feb 2006
Damn I need to move to the US so I can tap into this network of skilled artisans.
GotrekGurnisson is offline Find More Posts by GotrekGurnisson
Old Aug 23, 2008, 07:07 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
You might as well GG, half of Mexico is up here already.
J
Old Aug 23, 2008, 10:10 AM
kdahlhaus's Avatar
USA, OH, Seven Hills
Joined Mar 2002
Thanks, that should be sufficient for a small park flyer. I'll do that with my 190 if I don't buy the parkzone spinner.
K
kdahlhaus is offline Find More Posts by kdahlhaus
Old Aug 26, 2008, 11:01 AM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Got my plans cut up for making parts today. Hope to get started on this this weekend.
J
Old Aug 26, 2008, 01:57 PM
Living a Dream
Hans-Joachim's Avatar
Winsen (Aller) Germany
Joined Oct 2003
J
That was fast!
I need to start cutting.
HJ
Hans-Joachim is offline Find More Posts by Hans-Joachim
Old Aug 26, 2008, 02:53 PM
Tashadra's Avatar
Bellville,Cape Town,South Africa
Joined Jul 2007
H-J, I sent you a PM.
Tashadra is offline Find More Posts by Tashadra
Old Aug 28, 2008, 11:50 AM
france
Joined Aug 2008
hi,
thanks to hans joachim ! I begin the construction. Or place you the engine and the servos ?
see you soon
marie3379 is offline Find More Posts by marie3379
Old Aug 28, 2008, 02:08 PM
france
Joined Aug 2008
hans joachim do you have pics of the construction of wing?
How much of servos are necessary ?
i think 4 ( two for ailerons)
thanks
Old Aug 28, 2008, 05:37 PM
Living a Dream
Joined Oct 2003
marie,
please, take a look at the P-51D thread. The first side. There are some construction pictures.
Now, I will and have to start my own BF-109 build this weekend.
2 aileron servos for the wing with extended wires, one elevator servo.
http://www.rcgroups.com/forums/showthread.php?t=578985
HJ
Old Aug 28, 2008, 09:19 PM
Ipoh, Perak Malaysia
Joined Jul 2006
Hans, how about adding scale-type flaps to it? What would be the proper position? Are they split flaps?
chewy
chewytm is offline Find More Posts by chewytm
Old Aug 28, 2008, 09:23 PM
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Originally Posted by Hans-Joachim
marie,
HJ
I'll start cutting foam tomorrow evening!
J
Old Aug 29, 2008, 09:36 AM
Living a Dream
Joined Oct 2003
It looks like a BF-109F weekend.
Here is the 3 view I´ve used,
with panel lines, flap positions and goodies.
HJ
Old Aug 30, 2008, 01:31 AM
france
Joined Aug 2008
Before to assemble the wing, I wonder if the size of ailerons owes identical in "size" or have to I make them bigger?
Thank you
Build Log P-51D Mustang Parkflyer 1/9 Scale Hans-Joachim Foamies (Scratchbuilt) 777 Apr 27, 2011 12:44 AM
Video F-16C*scale 1/9*speed test*e-flite park 480 Jan-Henrik Electric Plane Talk 3 May 29, 2007 04:27 AM
DELFIN in 1/9 scale scratchbuilt CaptDH Submarines 1 May 22, 2004 04:30 PM
1/4 scale FW190D-9 Wulfman Fuel Warbirds 0 Feb 03, 2004 01:36 PM
