Old Aug 15, 2008, 09:27 PM
Valid8r is offline
Find More Posts by Valid8r
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
Super Skids on a HBFP??? (not happy)
I'm new to heli's (not RC) and my HBFP is my first heli. I've spent a few days now busting up the stock skids and decided to buy a set of Super Skids. What I am disappointed in is the attachment of the skid to the stock HBFP chassis. The supplied screws are too short and the actual attachment point is not molded correctly to match up with the frame (at the point of where the screws attach.
Is it just me?
Jon
Valid8r is offline Find More Posts by Valid8r
Old Aug 15, 2008, 09:47 PM
Blade_Killer is offline
Find More Posts by Blade_Killer
innocent victim
Blade_Killer's Avatar
Houston TX
Joined May 2007
yes it is just you, you probably have th SSkids mounts turned around backwards so they dont line up. did you take off the stock skid mounts that are screwed to the frame? you need to do that and screw the SSkid mount to the frame.
Blade_Killer is offline Find More Posts by Blade_Killer
Old Aug 15, 2008, 09:52 PM
baratta930 is offline
Find More Posts by baratta930
United States, IL, Carbondale
Joined Jun 2005
They worked for me as well. If you're using the 3d version (i.e. without the boom support, I think it's called a knighthead?), make sure you reinforce the spot where the boom goes into the frame (search for picts on this site). Mine broke there, I was practicing my hard landing technique when it snapped (yeah that's it)
Berardino
baratta930 is offline Find More Posts by baratta930
Old Aug 15, 2008, 09:53 PM
Valid8r is offline
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
Probably right, but I did remove the stock skids and am screwing the new skids directly to the frame. I also turned them around so they are pointing forward. What bothers me is that I had to use the long screws to 'reach' the frame and that results in a gap between the frame and the SS attachment. It's as if the frame is 'suspended' between the SS attachment via the long screws...
Does this make sense?
Jon
Old Aug 15, 2008, 11:50 PM
Slyster is offline
Find More Posts by Slyster
Google 'Blade 400 bible'
Slyster's Avatar
Joined Nov 2006
They do fit and work VERY well! If anything.. drill out the holes and use nuts and bolts if your are somehow not right... they NEVER broke! My brother is not learning helis with my original Superskids!
Slyster is offline Find More Posts by Slyster
Old Aug 16, 2008, 07:33 AM
MGeo is offline
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
A picture might help...
MGeo is offline Find More Posts by MGeo
Old Aug 16, 2008, 08:26 AM
jazzy is offline
Find More Posts by jazzy
Joined Jan 2005
I think I know what you mean....
Using the short screws, they are only supposed to go into the tabs, not the actual frame itself - this is how the stock ones mount.
I have however, used the longer screws because the tabs on the frame broke.
jazzy is offline Find More Posts by jazzy
Old Aug 16, 2008, 01:08 PM
innocent victim
Houston TX
Joined May 2007
they should look like this
Old Aug 20, 2008, 11:28 AM
GTX_SlotCar is offline
Find More Posts by GTX_SlotCar
GTX_SlotCar's Avatar
Maine, USA
Joined Nov 2005
Is it just me?
It's not just you, Jon, but the reason the SuperSkids don't fit right is because your frame is broken. There are keyed posts that the stock landing gear slide over. Your posts are broken off your frame, so it seems like the SuperSkids mounts are too wide where they attach to the frame. Sometimes they break when you remove the stock landing gear because people don't realize they're keyed, and they twist them off. Sometimes they just break during hard landings. Since they are keyed, there's no room for movement (or give). SuperSkids mount to these posts, but are not keyed so there is some flexibility.
You might want to check your old landing gear and see if the posts are still in the holes. You can use them as spacers and still mount the SuperSkids. If you don't have them, you can use other spacers (or just none at all) and the longer screws that came with your SuperSkids kit. I installed SuperSkids on a HBFP frame with broken posts and flew it for 9 months that way with no problems.
Here are some pictures to help explain the broken mounting posts.
Gary
GTX_SlotCar is offline Find More Posts by GTX_SlotCar
Old Aug 21, 2008, 05:39 AM
Valid8r is offline
Valid8r
Valid8r's Avatar
Boston and Belgium
Joined Jul 2004
Gary - thank you for your very good explaination of my problem. You are exactly correct in your assumption of my situation. Have made numerous repairs to my original HBFP skids and apparently broken off all of the keyed posts, I had no idea they had ever been there to begin with. Now that I at least understand this, I no longer think I am crazy. I could not figure out how to explain this and it was too difficult to get photo's like yours that I just figured that I was doing something wrong.
I am much happier now with this information and can use it to improve the mounting that I have made without the posts.
Thanks again for taking the time to resolve this for me.
Jon
Wanted looking for Original Super skids or 3d superskids for hbfp siryan Aircraft - Electric - Helis (FS/W) 1 Apr 19, 2008 11:34 AM
Discussion Super Skids 3D for HBFP newhampshire Micro Helis 26 Feb 02, 2008 05:06 PM
Discussion Super Skids - Worthwhile Upgrade For HBFP ? Buckeye95 Micro Helis 20 Dec 04, 2007 04:15 AM
Wanted Super skids for hbfp siryan Aircraft - Electric - Helis (FS/W) 0 Apr 23, 2007 09:01 PM
Put fresh shoe on Monokote iron...... NOT happy! 1987tc The Builders Workshop 6 May 02, 2005 06:52 PM
