thanks guys. This is very good info.
I was eyeing 3D Foamies plans a cpl of weeks ago. I might use them as a 3view. As for the rigity i am planing to use ordinary white housebuilding foam and Maybe dress it in oracover. So formers might be 3+cm thick and the skin 1-2cm thick, made up by several layers of 3-5mm foam slices. If this is not firm enough theres always packing paper that goes on good with diluted woodglue ![]() Not the lightest but UH has big motors too ![]() I choose this because a ARTF would cost about 1200$ here in sweden. I'll spend the money on United Hobbies instead ![]() Another reason is that i saw this 2.7m foam yak from Mr Claes Meijer. Look uner videos at http://www7.hemsida.net/meijermodels/indexx.htm Another thought would be to enlage the Micropitts plans by 760% which would make a span of around 240cm. Thats BIG for a bipe. /Ulf |
FOUND IT!!
An old thread on this subject. I put these old plans into cad last fall if your interested. Hope it helps http://www.rcgroups.com/forums/showthread.php?t=182433 |
