Old Aug 14, 2008, 12:05 AM
zaskarkid is offline
Find More Posts by zaskarkid
what it do everybody?
zaskarkid's Avatar
a swamp naturally
Joined Mar 2008
Help!
My a-4 bounces on landing
Having a hard time landing this jet. I use up the whole runway and drop altitude a few inches at a time to come in as soft as possible - almost like a touch and go without the so much throttle. I keep some throttle until I'm less then a foot off the ground. But as soon as the wheels hit the ground, it'll sometimes bounce up and then float for a foot or two and then nose into the ground, which bends my nose gear, and once broke the nose clean off. Out of 8 flights, I think I've only managed to stick the landing about half the time. I've already replaced the landing gear once with 2mm wire and here is how it sits.
I can touch down soft with no bounce on my edf belly landers. But this jet does have some weight at 1200g or 2.5lbs. Should I do full elevator down as soon as the wheels hit the ground? Or should I make the wing landing gear sit a lot lower then the nose?
zaskarkid is offline Find More Posts by zaskarkid
Old Aug 14, 2008, 12:27 AM
corsair nut is online now
Find More Posts by corsair nut
fly like an EAGLE ;)
corsair nut's Avatar
tehachapi, CA
Joined Jan 2006
you need to keep it nose high on touch down...if the nose gear hits before/same time as the mains, youll probably bounce...touch down on the mains first, and try to hold the nose off. this should get rid of the bounce. youll have to land with some power on, and nose high.
corsair nut is online now Find More Posts by corsair nut
Old Aug 14, 2008, 11:54 PM
RCAV8R13 is offline
Find More Posts by RCAV8R13
I'm goin' Falcon nuts
RCAV8R13's Avatar
White Salmon, Wa
Joined Oct 2003
Your A4 is skipping because it's happy that it looks so good!
Nice plane.
RCA
RCAV8R13 is offline Find More Posts by RCAV8R13
Whoops! Watch me get nailed by my plane on landing...from the planes point of view rmeflyerkid Aerial Photography 32 Feb 10, 2006 11:41 AM
Discussion help with were to mount light on my R-4 burro breath Scale Kit/Scratch Built 1 Feb 06, 2006 07:31 PM
Question Help!!! I spilt fuel on my Futaba (4-ch YF) radio srbangash Radios 17 Jun 24, 2005 11:33 AM
thinking of going seprats on my dragonfly#4 help wonted davidb1 Micro Helis 2 May 04, 2005 05:06 PM
Aveox 3 turn or 4 turn on my (just arrived) NSP stinger? argarre High Performance 6 Jun 23, 2004 01:35 AM
