Old Aug 12, 2008, 11:21 PM
bottomofth9th is offline
Find More Posts by bottomofth9th
Joined Aug 2008
Question
vapor binding troubles
i recently bought a parkzone vapor bind and fly. i went with the bnf version because i already own a blade cx2 transmitter. i bound the tx and the vapor and all went well except my rudder was not getting the full play it was supposed to be getting. im not sure what to do here and need a little help figuring out how to get the rudder to turn completely.
any help possible would be greatly appreciated.
bottomofth9th is offline Find More Posts by bottomofth9th
Old Aug 12, 2008, 11:35 PM
darksiede is offline
Find More Posts by darksiede
Foaming at the mouth..
darksiede's Avatar
USA, KS, Topeka
Joined Jul 2008
EDIT: Didn't realize this was a repost from another thread, hence my "vanishing post".. just FYI, its not recommended to post the same thing in multiple threads.. pick a spot and ride it for 24 hours before posting elsewhere if you did not receive help
Yet again, I do not know why I had a post vanish, but to paste it in again:
Watch the rudder servo, see if it appears to be binding up, or if it is getting unobstructed travel. Mine heading both directions, is within 2 millimeters of the end of the groove the slider travels down.
Also, for your vapor when using the LP5DSM, set all dips under the hatch (by red light) to be down.. BEFORE you do that, write down where they currently are, so you can reset them before using on your CX2 (assuming you have one)
~Kev
darksiede is offline Find More Posts by darksiede
Discussion Vapor binding leliommarino Scratchbuilt Indoor and Micro Models 3 Jul 05, 2008 07:58 PM
